Did I damage my netbook?
1,526 (0.28/day)
System Name Custom Built
Processor AMD Ryzen 5 3600
Motherboard Asus PRIME A520M-A
Cooling Stock heatsink/fan
Memory 16GB 2x8GB Corsair Vengeance LPX 2400MHz
Video Card(s) MSI 1050Ti 4GB
Storage KINGSTON SNVS250G 256GB M.2 + 2 data disks
Display(s) Dell S2421NX
Case Aerocool CS103
Audio Device(s) Realtek
Power Supply Seasonic M12II-520 EVO
Mouse Logitech MX Master 2S
Keyboard Logitech
Netbook is a Samsung N145P
2GB DDR3 RAM (upgraded)
Kingston 128GB SSD (upgraded)
Intel Atom N455
The netbook is almost 7 years old and is in mint condition, including battery.
I was trying to overclock the CPU a bit (to squeeze the maximum performance out of it) using SetFSB following tutorials around internet.
As I couldn't find what clock generator it uses (I opened it but I couldn't see it, probably hidden), I was trying each listed PLL until one that worked (listed the frequencies).
Most of them just gave the error PLL id error and nothing further happened but on one of them the computer froze and the screen became completely scrambled, flickered, and made weird noises through speakers
I rebooted it and everything works fine again
I will stop trying to OC it.
My question if I made long-term damage to it, by messing with SetFSB.
Thanks
785 (0.23/day)
System Name Fat NCASE
Processor Ryzen R9 3900X
Motherboard ASUS TUF GAMING B550M ZAKU (WIFI) Edition
Cooling Scythe Fuma with 3 SCYTHE Wondersnail 2400RPM + Arctic MX2
Memory Corsair Vengeance 128GB @3200Mhz Cl16 (32GB X 4)
Video Card(s) Palit RTX 3060 StormX ITX 12GB
Storage MX500 4TB SATA + Toshiba MG08 16TB HDD
Display(s) LG 27UL500 4K monitor
Case Jonsbo W2 black
Audio Device(s) Onboard realtek 1200 & Soundblaster G3 usb
Power Supply ASUS ROG STRIX 850W Gundam Edition
Mouse Elecom wireless mouse :)
Keyboard RK100 Royal Kludge
Software Windows 10 HOME
Benchmark Scores Don't know any benchmark. It runs good enough for me.
I don't think so, you hardly damage your netbook at all. I used to play setfsb with my toshiba nb200 notebook and acer 3820tg the later which I overclock to 3.0Ghz by changing the hex numbers which is unheard of for laptop in 2010/2011.
I never managed to find out how to overclock my netbook though as there is no example I can follow unlike the 3820tg. I recommend that you donate to setfsb maker to see if your laptop can be overclock. Setfsb is a very hit or miss thing. Some laptops need exact step like my 3820tg and I can't adjust with the slider only by typing number only.
Once you restart setfsb settings would be gone.
246 (0.05/day)
System Name Main Pc | Xeon rig
Processor Intel Core i5-4670 @3.6Ghz | Intel Xeon X5675 @stock
Motherboard Gigabyte GA-Z87-HD3 | Sabertooth X58
Cooling Noctua NH-U9B SE2 | Noctua NH-D14
Memory 16GB Crucial OC @ 2133mhz | 12 GB Various
Video Card(s) MSI RX480 | MSI R7970 TF III 3GD5 OC BE (Bios mod 1081 mV)
Storage 120GB Samsung Evo\ 4TB WD HDD | 120GB Samsung Evo
Case NZXT H440 | Fractal Design Define R5
Power Supply Seasonic 650 Watt| Nexus 450
Software Windows 10 Pro x64 | Windows Server 2016 Datacenter x64
the laptop is made for the specifications for a reason. So if you are going outside its normal configuration, you enter the danger zone. Ocing is always a risk. CPU's are OC'ed all the time. But they are very strong most of the time. If you overclock your graphics card to the max it will probably crash sooner then when you leave it at stock. Overclocking CPU's in cases with ample airflow is done by most tech enthusiasts. Overclocking netbooks and laptops with little to no room and airflow is not common. you're probably fine. but if you really need to use the netbook, I wouldn't take the risk.
6,832 (1.47/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
The old days of netbook overclocking was needed. These days processors are much better suited for almost everything. No need to mess with it.
10,885 (1.58/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
r9
3,300 (0.56/day)
System Name Primary|Secondary|Poweredge r410|Dell XPS|SteamDeck
Processor i7 11700k|i7 9700k|2 x E5620 |i5 5500U|Zen 2 4c/8t
Memory 32GB DDR4|16GB DDR4|16GB DDR4|32GB ECC DDR3|8GB DDR4|16GB LPDDR5
Video Card(s) RX 7800xt|RX 6700xt |On-Board|On-Board|8 RDNA 2 CUs
Storage 2TB m.2|512GB SSD+1TB SSD|2x256GBSSD 2x2TBGB|256GB sata|512GB nvme
Display(s) 50" 4k TV | Dell 27" |22" |3.3"|7"
VR HMD Samsung Odyssey+ | Oculus Quest 2
Software Windows 11 Pro|Windows 10 Pro|Windows 10 Home| Server 2012 r2|Windows 10 Pro
Intel Atom N455
Thanks
You be fine.
I think the PCIE clock was linked when you raised the FSB and basically overclocked the PCIE bus which can cause such artifacting on the screen.
High clocks don't damage anything, higher volts and temperature do.
No oc on stock volts can do anything but make the computer crash.
silentbogo
5,533 (1.39/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 3800X
Memory 4x8GB Samsung DDR4 ECC UDIMM
Video Card(s) Inno3D RTX 3070 Ti iChill
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Software Windows 11, Ubuntu 20.04 LTS
You are fine and there will be no permanent damage.
Atom N450 is a bad overclocker. Even if you are lucky and can get +10% FSB, it won't make it fast enough to make a difference.
It's biggest problem is being a single-core hyperthreaded CPU with low clocks. That generation was relatively bad at hyperthreading (only 15-20% benefit from single-threaded depending on load).
There isn't much you can do to fix that, except keeping the SSD, selling the old puppy and buying a new[er] netbook.
1,526 (0.28/day)
Case Aerocool CS103
Keyboard Logitech
Thanks to all
I won't try further to OC it, I will leave it as is
I simply wanted to squeeze a bit of performance out of it, but it's still usable :)
You be fine.
The artifact screen occured just after hitting the "Get FSB" button after selecting a Clock Generator (to read the frequencies) I hadn't time to set clock :)
My bet is you loosened or damaged something by doing that.
The scrambled screen happened just after hitting the "Get FSB" button it works fine otherwise
[...]I recommend that you donate to setfsb maker to see if your laptop can be overclock. [...]
Unfortunately the program seems to be EOL :(, maybe because FSB is dead and now it's QPI, HyperTransport, DMI...
OneMoar
There is Always Moar
8,791 (1.66/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
no harm done the scrambled screens means you got close to the right pll gen
it would't matter if you wound that atom up to 3Ghz its still slower then frozen dogshit
brandonwh64
19,542 (3.55/day)
LOL you are right, We bought some of those intel compute sticks (latest gen) and They are only worth web browsing and RDP to other machines.
1,526 (0.28/day)
Case Aerocool CS103
Keyboard Logitech
Meh it's still enough for my needs
For more intensive tasks I use my desktop or a bigger laptop.
I only wanted to extract more performance for a possible windows 10 update.
3,505 (0.62/day)
Have you tried one with Core m3/m5? Have always wondered how good they were.
silentbogo
5,533 (1.39/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
His N450 is about 1/10 of the computestick(in terms of performance) in a hotter package. Imagine what that's like.
Haven't tried Computestick yet, but from what I've heard is they throttle a lot, and most likely not just from heat, but from reduced power cap on SoC package. I've tried Z8300 on an ASUS netbook w/4GB RAM, and it was quite adequate.
It did handle well Chrome w/ 10+ tabs, LibreOffice, HD video playback, etc. Also worked flawlessly, when playing FHD content on TV or ext. monitor. Too bad that one did not support WiDi
816 (0.28/day)
Riverwood, Skyrim
System Name Storm Wrought | Blackwood (HTPC)
Processor AMD Ryzen 9 5900x @stock | i7 2600k
Motherboard Gigabyte X570 Aorus Pro WIFI m-ITX | Some POS gigabyte board
Cooling Deepcool AK620, BQ shadow wings 3 High Spd, stock 180mm |BQ Shadow rock LP + 4x120mm Noctua redux
Memory G.Skill Ripjaws V 2x32GB 4000MHz | 2x4GB 2000MHz @1866
Video Card(s) Powercolor RX 6800XT Red Dragon | PNY a2000 6GB
Storage SX8200 Pro 1TB, 1TB KC3000, 850EVO 500GB, 2+8TB Seagate, LG Blu-ray | 120GB Sandisk SSD, 4TB WD red
Display(s) Samsung UJ590UDE 32" UHD monitor | LG CS 55" OLED
Case Silverstone TJ08B-E | Custom built wooden case (Aus native timbers)
Audio Device(s) Onboard, Sennheiser HD 599 cans / Logitech z163's | Edifier S2000 MKIII via toslink
Power Supply Corsair HX 750 | Corsair SF 450
Mouse Microsoft Pro Intellimouse| Some logitech one
Keyboard GMMK w/ Zelio V2 62g (78g for spacebar) tactile switches & Glorious black keycaps| Some logitech one
VR HMD HTC Vive
Software Win 10 Edu | Ubuntu 22.04
Benchmark Scores Look in the various benchmark threads
I remember playing CoH on minimum settings at the lowest screen resolution one of the early atoms in a netbook with similar specs (apart from the SSD) and that was just bad (sub 25 fps and worse with local multiplayer)
1,526 (0.28/day)
Case Aerocool CS103
Keyboard Logitech
Anyway yesterday I got an Acer One 10 tablet/laptop with an Atom X5-Z8300 and an external hard drive, but I will keep the netbook, because it has proven to be a reliable and robust machine in its 6 years of use, including battery. even if it's heavier, blukier, hotter, and way less powerful than the tablet.
The only crash it had is the one of this thread, that machine is a tank. And after upgrading to 2GB of RAM and 128GB SSD the performance increased notably.
I hope the Acer One 10 is as reliable as it.
It's technology evolution :rockout:
FYI the netbook ran Visual Studio 2012 (with a small project), Office 2016, SQL Server 2014 with a small database, and XAMPP, and hosted a test Web Service, without any hiccups, but the screen res is too low to code comfortably LOL
It can surprise how a good optimization can help.
The only piece of software that kills it is Windows 10*, and that's why I wanted to overclock it.
*And SetFSB :D
Anyway we are derailing this thread this was about if I damaged my netbook not to talk about its performance.
18,585 (2.71/day)
System Name AlderLake
I got myself an Acer netbook years ago, also with an atom, it was running XP, made a XP/7 dual boot on it, worked well but just for surfing/email nothing more, it sucks for other productivity tasks....
It's still an Atom.
silentbogo
5,533 (1.39/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
I need to check my trash/parts pile... I might even have a non-working EEE PC 4G. Always wanted to strip its innards and turn into portable KVM switch.
1,526 (0.28/day)
Case Aerocool CS103
Keyboard Logitech
They don't have a "full" GPU, it's mostly software emulated (GMA 3150) with almost no allocated RAM not made for 3D gaming.
The only 3D games I could play on it was Half-Life 1 and Need for speed Hot Pursuit (both 1998)
That's why they lag with Windows 10, advanced hardware accelerated interface, DWM. that you can't disable unlike Windows 7.
1,533 (0.40/day)
Grunn
System Name Indis the Fair (cursed edition)
Processor 11900k 5.1/4.9 undervolted.
Motherboard MSI Z590 Unify-X
Cooling Heatkiller VI Pro, VPP755 V.3, XSPC TX360 slim radiator, 3xA12x25, 4x Arctic P14 case fans
Memory G.Skill Ripjaws V 2x16GB 4000 16-19-19 (b-die@3600 14-14-14 1.45v)
Video Card(s) EVGA 2080 Super Hybrid (T30-120 fan)
Storage 970EVO 1TB, 660p 1TB, WD Blue 3D 1TB, Sandisk Ultra 3D 2TB
Display(s) BenQ XL2546K, Dell P2417H
Case FD Define 7
Audio Device(s) DT770 Pro, Topping A50, Focusrite Scarlett 2i2, Røde VXLR+, Modmic 5
Power Supply Seasonic 860w Platinum
Mouse Razer Viper Mini, Odin Infinity mousepad
Keyboard GMMK Fullsize v2 (Boba U4Ts)
Software Win10 x64/Win7 x64/Ubuntu
If it still works, it works right? It's only damaged when it stops working again :D
Thing to remember with OCing these things is that if it doesn't run something, it's very likely that it doesn't by a *long* margin... And I doubt you would ever manage even 50% let alone 100% overclock on something like this. OCing is really only useful if you are either pushing benchmark scores, want a slight boost on some task like video encoding or file compression, or trying to bump up FPS a few % to get it above a certain threshold (my old laptop ran BF3 at 55-65 FPS without a GPU OC, with the OC I managed 60+ consistently)
