Digitizer pen
Durkhead
29 (0.01/day)
I bought my son a cheap windows tablet onn 10.2 from Walmart he wants something to draw on but I'm not sure wat kind of stylus to get for it I'm very confused anybody have any info or suggestions
Mussels
Freshwater Moderator
58,413 (7.95/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
The tablet needs to support the pen in the first place, or it wont work. You havent even listed the model tablet you got.
Durkhead
29 (0.01/day)
All it says is onn 10.1 windows tablet with Celeron n4000 I guess that's kinda the prob I tried googling but there's not much info on it
Mussels
58,413 (7.95/day)
Oystralia
then it wont have support for a true digitizer pen, just the really simple cheap ones that mimic a finger - no pressure sensitivity or anything fancy
95Viper
Super Moderator
12,957 (2.21/day)
If it has a USB port... you may be able to connect a digitizer pad/pen to it.
PeteColeman
3 (0.00/day)
If your tablet is Windows OS, then you may can get a drawing tablet which compatoble with windows OS devices. such as wacom, huion and XPPen. the cheapest drawing tablet with a digital pen is as low as $20 such as xppen star g430s screenless model.
534 (0.08/day)
West Bend, Wisconsin
System Name DELL Inspiron 5400 AIO / HP 17 ca1065cl
Processor 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz / Ryzen 5 3500u
Memory 16GB /12GB
Video Card(s) NVIDIA MX 330 / Radeon Vega 8
Storage 1TB +SSD
Display(s) 23.8 inch touch screen 17.3 touch screen
Case DELL AIO / HP LAPTOP
Mouse Dell Wireless /LOGITECH
Keyboard Dell Wireless / HP LAPTOP
Software WINDOWS 11
Yep I’m sad to say that tablet probably doesn’t have that kind of pen support.
41,963 (6.61/day)
Being onn (walmart budget line like bestbuy insignia) nope, not at all.
