Direct compute 5.0 unchecked? GTX 860M Win7 64 bit
alisina92
12 (0.00/day)
In GPU-Z Direct Compute 5.0 is unchecked for Nvidia card how can I make sure its checked?
As you can see its checked on lntel but not for Nvidia?
765 (0.15/day)
Germany
System Name Acer Nitro 5 (AN515-45-R715)
Processor AMD Ryzen 9 5900HX
Motherboard AMD Promontory / Bixby FCH
Cooling Acer Nitro Sense
Memory 32 GB
Video Card(s) AMD Radeon Graphics (Cezanne) / NVIDIA RTX 3080 Laptop GPU
Storage WDC PC SN530 SDBPNPZ
Display(s) BOE CQ NE156QHM-NY3
Software Windows 11 beta channel
Try older GPU-Z versions or other driver versions.
alisina92
12 (0.00/day)
I will try older version of gpu z to see if makes any difference and let you know thanks.
i have tried with gpu z 0.7.7
now cuda is unchecked
this is with manufacturer drivers
manufacturer drivers with latest gpu z
765 (0.15/day)
Germany
Memory 32 GB
Here are some old demos to check if DirectCompute is properly installed on your rig.
http://users.skynet.be/fquake/
Force the NVIDIA GPU via control panel or right-click executables and select "run with dedicated GPU"
alisina92
12 (0.00/day)
Dear Stefan,
The fluid program didn't work
but the other programs did run as expected.
maybe there is a bug within gpu-z i will attach some screen shots later
Thank you
W1zzard
Administrator
28,054 (3.71/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
It's possible that this is due to how the laptop turns off the NVIDIA GPU. Can you set GPU-Z to "run with dedicated GPU" ?
alisina92
12 (0.00/day)
I Always Run GPU-Z With nvidia GPU but as you can see DirectCompute 5.0, is Only Checked with Intel but with nvidia is Unchecked.
14,202 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Do you have Cuda drivers installed as part of the GPU driver package?
Maxwell should be Direct Compute 5.0/ 5.2 ready.
alisina92
12 (0.00/day)
how can I install Cuda Drivers? I normally run setup.exe. to install nvidia drivers.
W1zzard
Administrator
28,054 (3.71/day)
Memory 48 GB
14,202 (3.79/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
CUDA is always installed with the NVIDIA drivers
Not if you select custom install, it is optional. ( I think, or perhaps I confused it with something else)
W1zzard
Administrator
28,054 (3.71/day)
Memory 48 GB
14,202 (3.79/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
Thanks, I must have been thinking of PhysX instead. o_O
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
alisina92
12 (0.00/day)
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
alisina92
12 (0.00/day)
I have Already used DDU to wipe both drivers. and re install the Drivers but nvidia doesn't show up.
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
There's always a possibility the uninstall didn't go right. I'd recommend running it again, restarting the computer, and reinstalling the already downloaded file. Aside from that, you could verify that the Nvidia GPU is indeed enabled inside your bios options. Other than this, im out of ideas.
other than the missing direct compute, what symptoms are you encountering? Are games running on the 860m?
alisina92
12 (0.00/day)
everything is normal in game only in gpu z is checked is unchecked on gtx 860M but as you can see its checked on intel gpu.My BIOS Doesn't have GPU Option unfortuately. yes games running on GTX860M.
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
If a problem only manifests itself in a program as a reading, then it's not a problem , its an inaccurate reading, so ignore it.
alisina92
12 (0.00/day)
Thanks, I am waiting for the new driver as you may know driver 397.31 had some issue. In my laptop disabled the Nvidia optimus when it's out I will use DDU to wipe the drivers out and then re install intel and nvidia Drivers then let you know the outcome Jboy thanks.
alisina92
12 (0.00/day)
guys I have Installed the drivers again using DDU to whip them.
using GPU-Z version 0.7.9 as you can see Direct compute is checked with nvidia card now lets compare it with GPU-Z version 2.9.0 lastest
W1zzard
Administrator
28,054 (3.71/day)
Memory 48 GB
View attachment 100699View attachment 100700
Nice find! So this is a GPU-Z problem indeed. Can you go back a few versions to find out which is the last version that works correctly?
alisina92
12 (0.00/day)
yes I can confirm that the Latest version that shows correctly is gpu z1.20.0 compare it GPU-Z 2.0.0
little notice guys when you use DDU to uninstall GPU Drivers run it in Safemode and run it as Administrator:
1 download Chipset Driver Intel and Nvidia from manufacturer and gpu's website.
2 - uninstall Nvidia GPU DO NOT reset or exit the program
3 -uninstall Intel GPU with a restart option after restarting in a normal mode
Boot in safe mode again repeat the step 1 and 2 to make sure its clean.
after back into normal windows for second time.
1- reinstall the Chipset Driver.
Restart pc
2- install Intel GPU
Restart pc
3- install Nvidia GPU(choose Advanced options preform a clean install)
Restart pc
I have done the following steps to make sure my GPU drivers installed correctly.
Thank you guys for helping me to Idenify this bug. hope this post be useful for others who were wondering like me.
1,094 (0.22/day)
Botevgrad, Bulgaria, Europe
System Name Main PC/OldPC/3rd PC
Processor Intel Core i7-3770K Ivy Bridge/Core i5-3470 Ivy Bridge/Core i3-4330 Haswell
Motherboard ASUS P8Z77-V/ASRock Z68 Pro3 Gen1/ASUS H81M2
Cooling Cooler Master Hyper 212 EVO/Intel Box cooler/Intel Box cooler
Memory 32GB Corsair Vengeance/32GB ADATA/16GB ADATA
Video Card(s) SAPPHIRE R9 290 Tri-X OC 4GB/MSI RX 480 8GB/SAPPHIRE R9 390 8GB
Storage 2x1TB ADATA SSDs in RAID0+3 HDDs/2xCrucial 1TB SSDs in RAID0+3 HDDs/Samsung 1TB SSD+8TB+4TB HDDs
Display(s) Philips 274E5QHAB@HDMI + Philips 273EQH@DVI (both 27")
Case Fractal Design Define R4 Titanium
Audio Device(s) Kenwood Mini HiFi system/Microlab speakers/Philips HDMI (main)+LG TV monitor HDMI + Apple headphones
Power Supply Cooler Master Silent ProM 600 W (modular)
Mouse Microsoft Ergonomic Sculpt Desktop 2.0 (combo)@Razer Goliath mousepad (Medium speed)
Keyboard Microsoft Ergonomic Sculpt Desktop 2.0 (combo)
Software Win10 64-bit (Main PC v.1809 RTM Enterprise/2nd PC v.1903 Insider Preview Pro/3rd PC - same as 2nd)
DX 11 is not something you can install, it ships with the OS (some of them - Windows 7 or newer have it, WinXP for example does not).
