- Nov 6, 2018
- 8 (0.00/day)
Anyone know how to actually disable MPO now since the old Registry tweak no longer works and hasn't for quite some time at least for the last ~12 months or so in W11.
Note: Since NVCleanstall adds the registry key that no longer works using that doesn't work either. Again in W11, I tested this myself a couple of days ago just to make sure.
If anyone knows how to disable them, after you've verfied it is actually disabled, can you let me know how?
Also those on older versions, again after you've verified they're disabled, can you let me know?
Thanks!
Thanks!
