- Feb 11, 2009
- 5,474 (0.97/day)
System Name | Cyberline |
Processor | Intel Core i7 2600k -> 12600k |
Motherboard | Asus P8P67 LE Rev 3.0 -> Gigabyte Z690 Auros Elite DDR4 |
Cooling | Tuniq Tower 120 -> Custom Watercoolingloop |
Memory | Corsair (4x2) 8gb 1600mhz -> Crucial (8x2) 16gb 3600mhz |
Video Card(s) | AMD RX480 -> RX7800XT |
Storage | Samsung 750 Evo 250gb SSD + WD 1tb x 2 + WD 2tb -> 2tb MVMe SSD |
Display(s) | Philips 32inch LPF5605H (television) -> Dell S3220DGF |
Case | antec 600 -> Thermaltake Tenor HTCP case |
Audio Device(s) | Focusrite 2i4 (USB) |
Power Supply | Seasonic 620watt 80+ Platinum |
Mouse | Elecom EX-G |
Keyboard | Rapoo V700 |
Software | Windows 10 Pro 64bit |
So Im kinda at my wits end here, maybe one of you has some imput.
I used to stream to friends quite a bit on discord, in the early early days it was terrible but then at some point, probably an update from discord, it became fine.
I noticed it made use of my RX480's Video Encoding via the task manager.
However now for some reason I cant properly stream anymore, I notice my Video Encoder is not used anymore, the stream is fine when im alt tabbed out, but as soon as I actually click to play the game the stream starts lagging badly, like 2 fps badly, just unwatchable.
And I have no clue what is causing this, I went for an complete fresh reinstall of the gpu drivers, actually went back to drivers from September but maybe I need to go further IF that is the issue....
idk like I said, i have no clue, I messed with all the settings regarding that in discord but they have absolutely zero influence in any way.
I also found information like this:
https://www.reddit.com/r/discordapp/comments/io8r9o
Basically I have found 2 reddit threads ot people with completely different rigs that have the same issue, now they managed to solve it but their changes did not help for me.
I know this is very vague and all but does anyone have any suggestions?
