Discrete case for dual GPU
610 (0.93/day)
Brazil
Processor 5950x
Motherboard B550 ProArt
Cooling Fuma 2
Memory 4x32GB 3200MHz Corsair LPX
Video Card(s) 2x RTX 3090
Display(s) LG 42" C2 4k OLED
Power Supply XPG Core Reactor 850W
Software I use Arch btw
Howdy my fellow techies.
So, I'm in the process of building a new system (9950x + PA120SE + 256GB RAM) and moving my GPUs (2x3090s) over to this new system, while leaving my current system still working in a headless manner and I will figure later a GPU for it later.
I really dislike the idea of those windowed cases or RGB stuff, I prefer my desktop to just be a black box that I can shove under the desk.
My current case was a cheap one (got it for ~$60) that apparently is local to my country, and the only windowless case that I could find back then. It's really nice since its side panel is a full mesh one, which helps the temps of my stacked GPUs after I shoved some fans on the side, as you can see below.
However, it's not available for sale anymore, and the only windowless options I could find in my country are the ones from Fractal. Specifically the following models, with converted pricing:
- Fractal Design Meshify 2 Compact ($210)
- Fractal Design Torrent ($380)
- Fractal Design North XL Mesh ($380)
As you can see, pricing is awful, but it is what it is.
So, any opinions or alternatives on what would be the best idea for such a setup?
653 (0.13/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper, Logitech G600
Keyboard Razer Huntsman Elite
Those are 3-slot cards right?? or are they 4-slot??
7,419 (1.04/day)
Video Card(s) Sapphire Radeon RX 590 Nitro+ SE (Wishes for RX 9070 XT Pulse) | Intel® Iris® Xe Graphics
It would be awesome if @igormp should actually read down the maker and model of their RTX 3090's so it will be easier to help. They already filled out System Specs but left it out :confused:
610 (0.93/day)
Brazil
Processor 5950x
Cooling Fuma 2
Oops, sorry for leaving that out!
I believe they are 2.75 slots each. Both from gigabyte, one is a Vision and the other is a Gaming OC.
7,419 (1.04/day)
653 (0.13/day)
St. Louis, MO
System Name Desktop
Depending on spacing, layout, and your personal preference, I would go with the North XL Mesh. It has a version without the window and RGB if it is available in your country.
It also has that structure across the motherboard expansion slot area for additional fans it looks like so you can get some air to both GPUs.
North XL — Fractal Design
610 (0.93/day)
Brazil
Processor 5950x
Cooling Fuma 2
That's one of my options, and the one I was considering most given that it's the only one with a mesh panel.
It's also the most expensive one, but it should last quite some time.
