Display port cable from motherboard to gpu?
289 (0.31/day)
Processor Ryzen 5 7600X
Motherboard Asus Proart B650
Cooling Noctua U12S
Memory Corsair Vengeance DDR5 32GB (2x16GB) 5600MHz C36 AMD Expo
Video Card(s) Sapphire RX 7800 XT Nitro+
Storage Samsung 990 Pro 1Tb
Case Fractal Design Pop Silent
Audio Device(s) Edifier r1900tII
Power Supply Seasonic Prime Platinum 650W
Never heard of this but appears my motherboard user manual suggests connecting display port from motherboard to graphics card? Why? Never heard of this before.
3,192 (2.27/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
That particular motherboard model is apparently designed to passthrough a DisplayPort video signal to USB-C.
By following the instructions on this manual page, you can use just one USB-C cable for both video and USB data from the PC to the monitor rather than two cables.
289 (0.31/day)
Cooling Noctua U12S
13,949 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
"IF" your monitor uses USB-C for its video input, you can get the video signal there by connecting that cable. That is not a common scenario - yet. I can see it being use to display on a projector or perhaps to multiple monitors in a sports bar to stream games.
If you have a standard computer monitor, you don't need this.
289 (0.31/day)
Cooling Noctua U12S
Sooo video information goes brrr from the gpu THROUGH the dp cable into the motherboard AND then out from the motherboard's usb-c into the monitor?
Anyway sounds like something I wont be using.
13,949 (2.04/day)
Nebraska, USA
Mouse Logitech M190
