Displayport Cable Advice - V1.2, V1.2a 1.3, 1.4 ??? For Freesync 75Hz at 3440 x 1440
10,885 (1.58/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
New monitor is an LG 34CB88-P 34" Ultrawide QHD 21:9 Curved IPS Monitor, 3440 x 1440 5ms, AMD FreeSync, HDMI, DisplayPort, USB Quick Charge - Paired with a Powercolor Vega 64.
The display included a 6' displayport cable that works fine, I'm getting 75Hz refresh with Freesync. Visuals are stunning.
I need a longer cable, like 10' and not sure what to get. I read that v1.2a supports Adaptive Sync (Freesync) OPTIONALLY, so I'm guessing that's a requirement and V1.2 itself may not get me 75Hz and Freesync.
Wiki article here: https://en.wikipedia.org/wiki/DisplayPort#1.4
Version 1.3 cables are hard to find and pricey. Can't even find version 1.4. Would there be any benefit to paying for 1.3? ... the bandwidth is much higher and does give more Hz at 4K and resolutions higher than 1080p
What to get for a 10' cable??? I haven't found any that explicitly state 1.2a... that also support Freesync
W1zzard
Administrator
27,569 (3.71/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
In my experience rated version doesn't matter as much as quality of the cable itself. I've seen sporadic black screens with cheaper cables, my solution was just to buy a bunch, keep the best one and return the other ones.
17,146 (2.36/day)
10,885 (1.58/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
From reading manufacturer specs on the 1.2 cables (amazon), it really is all over the place. I guess i'm surprised that there isn't any real standard. Also, getting more than 60 Hz at 4K is near impossible with a 10' v1.2 cable, so it somewhat defeats the purpose of a 144Hz 4k panel (not accounting for pixel speed)
Lindy makes very good cables - https://www.amazon.com/LINDY-41534-CROMO-Display-Cable/dp/B007PKPUNA/
The one review on there has the same resolution as you, but is running 100Hz, so I guess that confirms it works.
Not sure why they're so overpriced in the US though.
Ouch! lol ... some of the ones on Amazon state the speed and resolution their good for, most value cables hover around the $10 mark here. I'm going to poke around some more. For now thankfully, i know I have a cable that works.
43,598 (6.56/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
All you need is a 1.2 cable. Just find a cheap one on Amazon that has a good rating.... Maybe get a couple of them.
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.51/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
Yeah, there's only four types of cables now: RBR (DisplayPort 1.0), HBR1 (DisplayPort 1.1), HBR2 (DisplayPort 1.2), and HBR3 (DisplayPort 1.3). The next version of DisplayPort (1.5 or 2.0) will introduce HBR4.
2,960 (0.85/day)
Long Island
DP 1.0 - 1.1a supports up to 144 Hz @ 1080p, up to 75 Hz @ 1440p
DP 1.2 - 1.2a supports up to 240 Hz @ 1080p, up to 165 Hz @ 1440p, up to 75 Hz at 2160p
DP 1.3 supports up to 240 Hz @ 1080p and 1440p, up to 120 Hz at 2160p
DP 1.4 has the same limits w/o compression but with signal compression (DSC) can do 240 Hz at 2160p
Aquinus
Resident Wat-man
13,159 (2.84/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
You only need DP 1.2. 4k at 60Hz requires more bandwidth and 1.2 fits the bill for that.
76 (0.02/day)
System Name JUV3
Processor Intel Core i5 9400F
Motherboard EVGA Z370 Classified K
Cooling NoFan CR-95C Copper
Memory Kingston HyperX Fury DDR4
Video Card(s) ASUS ROG Strix GeForce RTX 2070
Storage WD_Black SN750
Display(s) AOC AGON AG273QX
Case Thermaltake Core P3 TG
Audio Device(s) Topping DX3 Pro+ with Beyerdynamic Amiron Home
Power Supply Seasonic Platinum Fanless
Mouse Logitech G Pro X Ultralight
Keyboard Durgod Taurus K320 with Cherry Silent Red switches
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.51/day)
IA, USA
System Name BY-2021
17,146 (2.36/day)
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.51/day)
IA, USA
System Name BY-2021
HBR3 is part of DP 1.3 spec which changed frequency but not cable design. It's not VESA certified. Of course it would probably work fine.
10,885 (1.58/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
633 (0.13/day)
System Name Smooth-Operator
Processor AMD Ryzen 7 3800x
Motherboard Asrock x570 Taichi
Cooling AMD Wraith Prism
Memory 2x16GB 3200MHz CL16@CL14 DDR4
Video Card(s) Sapphire Radeon RX 580 8GB NITRO+
Storage 2x4TB WD HGST 7K6 7200RPM 256MB
Display(s) Samsung S24E370DL 24" IPS Freesync 75Hz
Case Fractal Design Focus G Window Blue
Audio Device(s) Creative X-Fi Titanium PCIe x1
Power Supply Corsair HX850 80+ Platinum
Mouse Gigabyte Aorus M3
Keyboard Zalman ZM-K300M
Software Windows 10 x64 Enterprise/Ubuntu Budgie amd64
I see here discussion about 4k, higher refreshrates and freesync.... Currently i'm using r9 380 4GB, samsung S24E370D and delock display port cable, to be specific this one:
http://www.delock.com/produkte/G_82585/merkmale.html?setLanguage=en
I have impression despite being enabled in monitor and drivers freesync very rarely works, at least i think it doesn't work in rainbow six siege and assassin's creed black flag. Also when i use VSR some games can set 75Hz at 3840x2160 and others can just 60Hz at this resolution (freesync ultimate mode enabled in monitor) but at lower resolutions: 2560x1440 and 1920x1080 they can enable 75Hz.
Do you think changing to club3d cable would solve these problems? If yes do you know any similar capable cable but shorter? Up to 2m is what i need as i have monitor almost directly over pc case, 4m would be too long.
1,211 (0.26/day)
Arcadia
System Name Xeon build X58 / Main Rig X79
Processor Intel Xeon x5650 @ 4.2Ghz with HT / Xeon E5 1650 v2 @4.5Ghz
Motherboard Asus Rampage II Extreme socket 1366 / Asus P9X79 Pro socket 2011
Cooling Thermalright Archon +Ty 140mm|Fans : 2 front-1top-1rear-1bottom/ Gelid Phantom Twin Tower
Memory 16gb DDR3 1600mhz Kingstone Hyper x Quad Channel / 16gb DDR3 1600MHZ Patriot Viper 3
Video Card(s) Sapphire hd 7950 3gb Boost edition dual fan X / ZOTAC 1080 Ti Blower Edition
Storage INTENSO ssd sata 3 240gb+Seagate B 2Tb+WD g 1tb+WD g 3tb+WD r 3tb+Seagate B 4tb+Lexar 2Tb NVMe
Display(s) AOC E2460S 24" 1080p 60hz 1ms / LG 32UK550B 32" UHD 4K HDR 10 with Freesync
Case Enermax Phoenix / Fractal Design Arc midi
Audio Device(s) SoundMaxHD+5.1 BHT1100 BLUESKY,Fiio E10 Olympus+SuperluxHD668b+KZ HBB pr2,Superlux E205.
Power Supply Sharkoon WPM Gold Zero 650W semi modular / Corsair RM 850 Fully Modular
Mouse Generic Mice / Corsair M90
Keyboard Generic Keyboard / Microsoft WK600
Software Windows 10 Pro 64 /Windows 10 Pro 64
Don't buy it longer that 1.80 cm .
The one i have come with the monitor and they say that longer is going to give you latency .
10,885 (1.58/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
Club3D seems to be the one of the few that goes out on a limb to say what their cables support. See the Amazon link above. You may have luck, though it sounds a lot more game specific for VSR in your case, so that may not be the cable. The Adaptive sync support in v1.2a is OPTIONAL... so you may want to contact Club3D directly about that. I have only played Tomb Raider 2013 on my rig with FS @75Hz. No tearing at all on max settings.
In reading reviews on Amazon for other 1.2 cables, the LENGTH comes into play in a big way as to Hz supported.
Seems VESA certification doesn't really exist.
633 (0.13/day)
10,885 (1.58/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
633 (0.13/day)
10,885 (1.58/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.51/day)
IA, USA
System Name BY-2021
It does but only about 50 cables were ever certified and of those, 10'/3m is the longest certified. I think the specificiation says 15'/5m is the longest without requiring a powered repeater.
VESA said the cables they tested, some were literally wired wrong so they wouldn't function right in specific use cases.
10,885 (1.58/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
It definitely is up to the honor system if they are not "certified" I did a search and found some gold...
This is a good article on Displayport versions and VESA:
HOW TO CHOOSE A DISPLAYPORT CABLE, AND NOT GET A BAD ONE!
https://www.displayport.org/cables/how-to-choose-a-displayport-cable-and-not-get-a-bad-one/
LIST OF VESA CERTIFIED CABLES AT DISPLAYPORT.ORG
https://www.displayport.org/product-category/cables-adaptors/?ps&pcat[0]=cables-connectors
There's roughly 30 of them listed there. The longest I saw was 10'
