- Dec 24, 2008
- 2,062 (0.36/day)
- Volos, Greece
System Name | ATLAS |
Processor | Intel Core i7-4770 (4C/8T) Haswell |
Motherboard | GA-Z87X-UD5H , Dual Intel LAN, 10x SATA, 16x Power phace. |
Cooling | ProlimaTech Armageddon - Dual GELID 140 Silent PWM |
Memory | Mushkin Blackline DDR3 2400 997123F 16GB |
Video Card(s) | MSI GTX1060 OC 6GB (single fan) Micron |
Storage | WD Raptors 73Gb - Raid1 10.000rpm |
Display(s) | DELL U2311H |
Case | HEC Compucase CI-6919 Full tower (2003) moded .. hec-group.com.tw |
Audio Device(s) | Creative X-Fi Music + mods, Audigy front Panel - YAMAHA quad speakers with Sub. |
Power Supply | HPU-4M780-PE refurbished 23-3-2022 |
Mouse | MS Pro IntelliMouse 16.000 Dpi Pixart Paw 3389 |
Keyboard | Microsoft Wired 600 |
Software | Win 7 Pro x64 ( Retail Box ) for EU |
In my latest build with the Gigabyte GA-Z87X-UD5H, i wanted to have two 140mm PWM fans in synchronization, over the Prolimantech Armageddon.
But Gigabyte did the trickery to offer real PWM support exclusively at the CPU four pin plug, all other five DC fan connectors (output) this is DC voltage control.
So I though to make a DIY solution, this is a tiny bridge which deliver PWM signal (from CPU_FAN) at both 140mm PWM fan.
Also the PWM Fan No2, this deliver it speed signal at the header (CPU_OPT).
The outcome, both in synchronization, both deliver rotation speed signal at ( CPU_FAN) & (CPU_OPT).
Parts list:
Tiny PCB
Two motherboard headers (removed from damaged boards).
Two Intel stock fan, four pin plugs (free of charge too).
With a bit of hot-glue, it become a solid accessory.
Parts list:
Tiny PCB
