DLSS as antialiasing?
31 (6.20/day)
Spain
System Name "Nave Espacial"
Motherboard MSI B650M Project Zero
Cooling Corsair H150i Elite LCD XT
Memory Corsair Vengeance RGB 64GB (2x32GB) DDR5 6000MT/s CL30
Video Card(s) MSI GeForce RTX 4090 GAMING X SLIM
Storage Samsung 990 PRO 4TB + Acer Predator GM7 4TB
Display(s) Corsair Xeneon 27QHD240
Case Corsair 2500X (black)
Audio Device(s) Corsair HS80 Wireless Headset
Power Supply Corsair RM1200x Shift
Mouse Corsair Darkstar Wireless
Keyboard Corsair K65 Pro Mini 65%
Software Windows 11, iCUE
I heard somewhere that you can use DLSS as an anti-aliasing method by rendering the image above native resolution then downscaling it, and that it allegedly produces a superb result.
  1. How can I apply this in a game? Is it the same thing as DLAA?
  2. What do you think is the best overall anti-aliasing method in terms of absolute quality? And the sweetspot quality-performance?
2,123 (1.03/day)
Hungary
Mouse Canyon Puncher GM-11
You can go to your Nvidia driver 3D settings and enable DSR to upscale higher than your monitor's native res and then enable DLSS in the game or however you prefer it.
DLAA is basically the AA part of DLSS w/o the upscaling part so its just 100% native with the AI AA of Nvidia. 'ofc you can still enable this over DSR but thats gonna be heavy to run'
Personally I use DLSS Quality or DLAA if I have the headroom in every single game I play cause to me it looks better than any form of TAA or FXAA in modern games but thats just me.:) 'obviously with a 3060 Ti I have to make sacrifices and limited to how far I can push things so its simply what works best for my use case'
29,282 (6.89/day)
That's an interesting thought. The technical specs imply that it would work. I personally don't use AA, as such I can't speak as to how well it would work.
1,071 (0.61/day)
System Name S.L.I + RTX research rig
Processor Ryzen 7 5800X 3D.
Motherboard MSI MEG ACE X570
Cooling Corsair H150i Cappellx
Memory Corsair Vengeance pro RGB 3200mhz 32Gbs
Video Card(s) 2x Dell RTX 2080 Ti in S.L.I
Storage Western digital Sata 6.0 SDD 500gb + fanxiang S660 4TB PCIe 4.0 NVMe M.2
Display(s) HP X24i
Case Corsair 7000D Airflow
Power Supply EVGA G+1600watts
Mouse Corsair Scimitar
Keyboard Cosair K55 Pro RGB
That means DLAA is just SMAAx1 then in reality?
Every type of AA has a different purpose, the issue is that everyone just wants to use only "one type" as a catch all, when each on has problem in other places where others were better at.
Example
SMAA excels at enhancing fine details & solid textures, but it doesn't handle transparent areas very well. TAA, on the other hand, is effective for transparent areas & reducing flickering, but can cause ghosting on solid textures, especially during movement
474 (1.91/day)
System Name XPS, Lenovo and HP Laptops, HP Xeon Mobile Workstation, HP Servers, Dell Desktops
Processor Everything from Turion to 13900kf
Motherboard MSI - they own the OEM market
Cooling Air on laptops, lots of air on servers, AIO on desktops
Memory I think one of the laptops is 2GB, to 64GB on gamer, to 128GB on ZFS Filer
Video Card(s) A pile up to my knee, with a RTX 4090 teetering on top
Storage Rust in the closet, solid state everywhere else
Display(s) Laptop crap, LG UltraGear of various vintages
Case OEM and a 42U rack
Audio Device(s) Headphones
Power Supply Whole home UPS w/Generac Standby Generator
Software ZFS, UniFi Network Application, Entra, AWS IoT Core, Splunk
Benchmark Scores 1.21 GigaBungholioMarks
2,899 (6.40/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
No. One is a temporal algorithm, another is a post-processing filter. They work fundamentally differently.
11,024 (1.75/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
DLSS has built in anti-aliasing tho. Also DLAA is very good. DLAA + nvidia sharpening is the best quality but can be a bit stuttery.
1,071 (0.61/day)
Display(s) HP X24i
You're both wrong they're both post processing filters to be applied to the already rendered frame
They still work fundamentality the same way.
Temporal algorithm only looks for different areas compared to the A.I.
If resolution of AA is 100% it's still 1x.
It doesn't matter if A.I is picking out where to put the AA to less the performance.
It's still the same effect in the end even with a temporal algorithm.
They still work the same at the end process for the rendered image.
7,629 (5.02/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
DLAA stands for Deep Learning Anti Aliasing and it's pretty much the DLSS algorithm applied to a native resolution image. The objective, instead of rendering at a lower resolution and reconstructing the image, is to simply enhance it - by running it through the CNN or transformer model, preserving as much detail as possible, so it doesn't look as smeared as regular TAA does.
1,071 (0.61/day)
Display(s) HP X24i
Here is what is listed a post processing.
Post-Processing Anti-Aliasing Techniques:​
  1. FXAA (Fast Approximate Anti-Aliasing)
  2. SMAA (Subpixel Morphological Anti-Aliasing)
  3. TAA (Temporal Anti-Aliasing)
  4. DLAA (Deep Learning Anti-Aliasing)
Non-Post-Processing Anti-Aliasing Techniques:
  1. MSAA (Multisample Anti-Aliasing)
  2. SSAA (Supersample Anti-Aliasing)
AI-Based Upscalers:​
  1. DLSS (Deep Learning Super Sampling): Post-processing
  2. XeSS (Intel's Extreme Super Sampling): Post-processing
Algorithmic Upscalers:​
  1. FSR (FidelityFX Super Resolution) Post-processing
  2. NIS (NVIDIA Image Scaling) Post-processing
7,746 (3.29/day)
California
System Name His & Hers
Storage lots of SSD.
My prefered method is DLDSR 2.25x combined with DLSS quality. To my eyes on a 34 inch ultrawide that gives me the best image quality and is only15-20% more demanding than native+taa depending on game of.
DSR 4x with DLSS quality/balanced can be good on a 4k screen but a 4090 can barely achieve that at a satisfactory framerate
DLAA is my preference if a game is too demanding at the above settings.
TAA needs to die.
1,071 (0.61/day)
Display(s) HP X24i
TAA needs to die.
It's over use needs to die. It has its purpose. The trouble is it's only being used so much, because it has the lowest performance hit of all AA methods.
31 (6.20/day)
Spain
This is the one I was referring to in the original post. How to apply this? I don't think I've ever seen it as an in-game setting.
474 (1.91/day)
It‘s not an in game setting, it‘s a driver setting.
1. Enable DSR in Nvidia control panel.
2. In game, enable DLSS. Set your resolution to a higher resolution than your monitor is capable of - such as 5K
3. Driver handles the rest to down sample to your monitor native resolution.
31 (6.20/day)
Spain
Got it.
I play at 1440p with a 4090, so I don't think this will be much of an issue. :D
474 (1.91/day)
Got it.
Same here. Set your in game resolution to 4K, Nvidia performs magic from there.
8K is still out of reach, I’ve tried.
31 (6.20/day)
Spain
Hahahahaha I figured, I don't think we'll be gaming at 8K anytime soon.
1,599 (2.12/day)
France
System Name KLM
Motherboard B-650E-E Strix
Video Card(s) 4070-ti PNY
Case 4000D Airflow
Power Supply Shift 1000
Mouse 502 Hero
Keyboard K68
VR HMD Steam Deck OLED
Software EMDB
Benchmark Scores 0>1000
DLAA llooks like fails some time with some games, but even there is a solution apparently (emoose says: DLSSTweaks ResolutionOffset):
BTW i will try that !:
(Visible Noise)​
