dbookbinder
- Jun 7, 2024
- 8 (0.05/day)
I've been trying to create a low-power/low-heat setting for my i7-1355U HP laptop cpu, which appears to be largely locked down.
If I modify the PL1, PL2, and Time values in TPL, do I need to check Sync MMIO in order for them to be enforced, or will they be enforced anyway, as long as Throttlestop is running? Also, what effect does checking Clamp have? Does it more strictly enforce these values or do something else?
Also, are there any other values I can alter to prevent heat-related throttling of the power cores (especially one of them)? Adjusting the TPL Speed Shift Max value, which someone on reddit suggested, seems to have no effect.
Thanks!
Thanks!
