does mobo limits choice of gpu?
117 (1.01/day)
System Name [ JUNE_2024 ]
Processor LGA1700 i5-12600K / 3.7Ghz / 10 cores
Motherboard Asus Prime Z790M plus D4
Cooling Abysm Snow 4 Duo120mm
Memory Kingston Fury Beast 2x16Gb DDR4-3600
Video Card(s) Asus RTX 4070 Dual white 12Gb
Storage M2 Corsair MP600 CoreXT 1Tb
Display(s) Hisense 32" TV @ 1080 / 60Hz
Case Cooler Master Q300L black
Audio Device(s) Sennheiser HD 599 SE
Power Supply Corsair RM 750w Modular white
...another dumb question from a ignorant noob LOL
in general, does a mobo limit the choice of a new gpu?
if mobo runs an intel cpu or amd cpu, does it need a specific gpu?
what database must i look at, on my mobo before chosing a gpu?
what is Gddr4, 5, 6, 6X ? is it related to my ram DDR4? thanks!
507 (0.28/day)
Processor i9-9900K @ 5.1GHz (H2O Cooled)
Motherboard Gigabyte Z390 Aorus Master
Cooling CPU = EK Velocity / GPU = EK Vector
Memory 32GB - G-Skill Trident Z RGB @ 3200MHz
Video Card(s) AMD RX 6900 XT (H2O Cooled)
Storage Samsung 860 EVO - 970 EVO - 870 QVO
Display(s) Samsung QN90A 50" 4K TV & LG 20" 1600x900
Case Lian Li O11-D
Audio Device(s) Presonus Studio 192
Power Supply Seasonic Prime Ultra Titanium 850W
Mouse Logitech MX Anywhere 2S
Keyboard Matias RGB Backlit Keyboard
Software Windows 10 & macOS (Hackintosh)
in general. not really. vast majority of GPUs will be x16, and much much less often some lower spec GPUs will be x8. This value is how many PCIe lanes they utilize electronically. However, every GPU I know of is physically x16. That means their "blade" (likely not the correct technical term) is always sized the same, but electronically, some only use 8 lanes instead of all 16 available to that PCIe slot. any motherboard you would be buying as a consumer would have at least one x16 slot so fits any GPU really
the brand of CPU does not impact what GPU you can use
a PC has system RAM, which if buying new now-a-days, the latest and greatest is DDR5 but many motherboards are still being sold with DDR4 RAM slots too.
if you're talking about VRAM, video RAM, that is the RAM on your GPU. they normally will have faster RAM compared to your system RAM, so it's fine to have a motherboard with DDR4 and a GPU with GDDR6X.
so no GDDR4, 5, 6, and 6X is not related to system RAM like DDR4. they are different components, on different pieces of hardware that make up your system. though they both serve similar purposes. one is RAM for your system, what the OS and processes running will utilize, the other is RAM exclusively used by the GPU
117 (1.01/day)
thank you, its easy to understand.
3,591 (0.68/day)
Portugal
A question is only dumb if you never actually ask it! ;)
In general, no.
Only specific application motherboards might have slots that could condition your choice, but in the general sense, no.
It does not. It's actually the other way around, some AMD or Intel CPUs actually require an additional GPU, because those lack integrated GPUs.
The old notion that you had to match AMD with AMD/ATi Radeon, and Intel with nVidia was based on early-internet misinformation.
Much like the comparison that a Intel Core 2 Duo running at 2.2GHz had the same performance as a Pentium 4 running at 4.4GHz.
Just the specification sheet in detail. If it lists a PCI-e slot with the width of x16 (or 16 lanes), you're good to go for the great majority of the graphics cards on the market.
If it is less, check if it is the case for the physical slot as it might be smaller and only some cards will fit. However in most cases, it will be physically x16, but electrically x8 or less.
That is more the case for expansion cards (Wi-Fi, Ethernet, Sound, etc.), though.
W1zzard did a good brief explanation of it here, as well 'scaling' which matters for performance: PCI-e Express scaling
(EDIT: Also, not to confuse you, but some graphics cards on the market might show a full PCI-e slot physically, and actually be configured for 8 or less lanes, meaning electrically x8. So nothing beats reading specifications sheets for all the hardware you're looking for, to be honest.)
That would be the "iteration" of the DDR standard for Graphics Memory and while it follows a similar reasoning to regular DDR RAM, both are not related in any other way.
6,050 (1.51/day)
Over here, right where you can't see me !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
Well, if you hadn't started your thread by acknowledging that you are a noob, my response may have been somewhat critical....
However, since you did & I wasn't, I'll just say that the only DUMB questions are the ones you DON'T ask....and the answers skizzo & Jp gave are spot on !
And FWIW, EVERYONE was a noob at one time, so the learning process of building/buying a computer and/or becoming familiar with it's inner workings is one that demands curiosity, as well as a little technical know-how, and the only way to gain that is through practical experience, so therefore: WELCOME THE WONDERFUL WORLD OF the PEECEE, heeheehee, and ask away... if 1 person here doesn't have an answer, someone else will.. :roll:
1,807 (0.57/day)
Processor Intel i5 8400
Storage 1TB 980 Pro
Software W11 Pro
It can.
Pairing RTX 3xxx with processor/mobo/chipset before 10th or 11th gen Intel can be BIOS limitation you won't overcome. Even then it might not be possible to get resizable BAR working.
3,591 (0.68/day)
Portugal
It can.
That does not limit the choice. It limits the performance which, in turn, limits the desired outcome if it was to be the full potential.
But nothing stops you from doing that combo, which is a choice. :)
1,807 (0.57/day)
Storage 1TB 980 Pro
Software W11 Pro
I'm not entirely sure if Z270/Z370 mobo can. H370 cannot.
Toothless
Tech, Games, and TPU!
9,534 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Z170 can run 30 series cards. Pretty sure z97 can too.
Edit, yes they can. You can go onto 3DMark results and look up pairings that people ran.
12,886 (1.94/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
The question was, does it limit the "choice". The answer is no AS LONG AS there are no physical limitations due to size. Some µATX motherboards may have components mounted in such a way as to interfere with very long graphics cards. If the µATX board is mounted in a SFF (small form factor) case, even the case may be a problem for a very large card.
The bigger concern, typically, is power. Many cards are very power hungry, even more so than CPUs.
This is a pretty good read on the subject: Graphics Card Compatibility – Here’s How To Check [Easy Guide] (gpumag.com)
3,190 (1.06/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Storage Too much
Case Thermaltake Core X9
Mouse G305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
So long as the motherboard has a full x16 PCIe slot, no.
No, choosing either AMD or Intel doesn't impact GPU compatibility.
GDDR is similar to DDR memory but optimized for graphics workloads. GDDR is a type of VRAM located directly on the GPU. DDR4 is a type of RAM that's used as main system memory. The easiest way to think about it is GDDR = GPU memory, DDR = system memory.
Yep, I feel it's unnecessary to confuse a beginner with a bunch of edge cases anyways.
117 (1.01/day)
thank you all, closed topic.
