Does my motherboard have a PCI Express slot?
Susanta420
10 (0.00/day)
System Name Asus Motherboard
Processor Core 2 Duo E4500
Motherboard Asus P5G41T-MLX
Cooling CPU Fan Available
Memory 4 GB Ram
Video Card(s) Don't Have Grafic Card
Storage 500 GB Hardisk
Display(s) AOC F19S
Case Normal
Audio Device(s) 4.1 Speker
Power Supply 450 watt Power Supply
Mouse Normal Mouse
Keyboard Normal Keyboard
Software Windows 7 64 bit
Benchmark Scores J
Please Help me.thats my motherboard and I don't know my Motherboard have PCI Express slot or Not ?? Below mention Screenshot please tell me I need PCI Express 2.0 Slot
INSTG8R
Vanguard Beta Tester
8,031 (1.11/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
Wrong tab. Shot of the Graphics tab shows that information.
9,781 (2.24/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
cant you lean over and look in the case??
are you trying to determine IF you have a PCI-e slot?
post your PC's model/make info
6,862 (1.13/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Benchmark Scores https://www.3dmark.com/spy/34962882
No it doesn't. The OP has the right tab showing (mainboard), but the graphics interface is blank.
@Susanta420 is this a laptop or desktop computer? What model computer is it?
22,048 (6.01/day)
Mouse XTRFY M42
Is this a Thinkpad W520? If so, then yes, it should have because these are regularly fitted with discrete GPUs
1,867 (0.61/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
It has Intel 9xx series chipset, so it can't have a PCIe 2.0.
It should have PCI-e 1.x tho.
INSTG8R
8,031 (1.11/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
You're right, my bad. No Graphics for you! Thats what I get for looking at pictures on my iPad...
Susanta420
10 (0.00/day)
Memory 4 GB Ram
Display(s) AOC F19S
Case Normal
Mouse Normal Mouse
Benchmark Scores J
This is a Lenovo Desktop
6,862 (1.13/day)
S.E. Virginia
since the graphics interface section of CPUZ is blank, and that this is a socket 775 system, I'm going to say no, you do not have a PCI Express slot on that motherboard.
Susanta420
10 (0.00/day)
Memory 4 GB Ram
Display(s) AOC F19S
Case Normal
Mouse Normal Mouse
Benchmark Scores J
Ok Thank you for Help...if pciE 2.0 have then I install gt710 but my bad luck not support...
Thank your for help..:):):):)
221 (0.08/day)
behind you
Processor Threadripper 1950X (4.0 GHz OC)
Motherboard ASRock X399 Professional Gaming
Cooling Enermax Liqtech TR4
Memory 48GB DDR4 2934MHz
Video Card(s) Nvidia GTX 1080, GTX 660TI
Storage 2TB Western Digital HDD, 500GB Samsung 850 EVO SSD, 280GB Intel Optane 900P
Display(s) 2x 1920x1200
Power Supply Cooler Master Silent Pro M (1000W)
Keyboard Corsair K70 MK.2
Socket 775 doesn't support integrated graphics.
The best way to find out if you have a PCIe slot is to take the side panel off and look for it. It would look like any of the top 4 connectors in this picture. It should be quite visible if it's there.
26,871 (6.54/day)
The 945PL/GZ is a desktop chipset that has one PCIE 16x 1.0a slot. However at that point in time OEMs, including Lenovo, had a habit of not including an actual slot to plug in a GPU to, relying instead on the Intel graphics.
https://www.intel.com/Assets/PDF/datasheet/307502.pdf
@Susanta420 You will need to open your PC's case and look inside to see if you actually have a slot installed. If you do, then you can add in a video card(guessing that's what you want to do). If not and you want to do some decent gaming, you'll need to upgrade your PC.
The one you want to look for will look like one of the dark gray slots or the blue one and not one of the ivory slots(which are standard PCI) in the picture above.
Um, that is very incorrect. The socket 775 platform most certainly does support IGP. See the reference PDF from Intel listed above.
  • Like
Reactions: hat
221 (0.08/day)
behind you
My mistake, it was on the northbridge.
BTW 775 is a pretty old platform and you only have a dual core Pentium in it. If you are wanting to install a graphics card to play the latest games your CPU or even the PCIe interface itself will be a bottleneck. Some games won't even run on a dual core machine.
5,523 (1.03/day)
Gougeland (NZ)
System Name Cumquat 2021
If your lucky it'll have an PCIe slot of the 1.1 version variety if you're unlucky it'll be AGP 3.0
newtekie1
Semi-Retired Folder
28,473 (4.13/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Unfortunately software is not going to be a reliable way to determine if you have a PCI-E slot with a machine of that era. The reason is that OEM manufacturers(Dell, HP, Lenovo, etc.) were cheapening their boards by not actually soldering the PCI-E to the motherboard, even though it was wired to be there. So software will sometimes say there is one there, but when you open the computer it physically isn't.
So pop the computer open and take a look.
  • Like
Reactions: hat
26,871 (6.54/day)
My mistake, it was on the northbridge. BTW 775 is a pretty old platform and you only have a dual core Pentium in it. If you are wanting to install a graphics card to play the latest games your CPU or even the PCIe interface itself will be a bottleneck. Some games won't even run on a dual core machine.
True, but that chipset does support the OG Core2 Quads and in the case of most of the Lenovo's that came with that series of Pentium Dual Core CPU, the 9000 series of Core2 Quad. The Core2 Quads are showing their age but still do a decent job of gaming when paired with a decent video card. As long as that system has an actual PCIE slot and they're willing to do a CPU upgrade(which is not expensive) they can get some more life out of it.
That Intel chipset did not have AGP support. The last Intel chipset that did was the 800 series. From the 900series on it was all PCIE.
Susanta420
10 (0.00/day)
Memory 4 GB Ram
Display(s) AOC F19S
Case Normal
Mouse Normal Mouse
Benchmark Scores J
Suggest me a Lowest Price Grafic Card For this Desktop.. just for play some small games...
26,871 (6.54/day)
If you do have a slot, then an important thing to remember is that you also need to make sure you have a PCIE power cable from your system's power supply. It'll look like this;
If you have one of those as well, you can use a card that has only one power jack. If you don't, but you have a couple spare 4pin molex power jacks you'll need an adapter like this;
If one or the other of those applies than you can consider one of the following;
Geforce GTX450, GTX460, GTX550, GTX650, GTX660, GTX750, GTX 950 or GTX1050 if you prefer Nvidia.
If you prefer Radeon's there are the HD5750, HD5850, HD6750, HD6850, HD7850, R7-265, R9-270, R7-360, R9-370 or RX-470.
In either case, while there are many other cards to choose from, lower end cards will not give you the performance you'd likely be looking for and higher end cards will require more power than your system's power supply can deliver. The list I've offered has the optimal balance of performance and electrical power requirements.
1,703 (0.26/day)
Oshkosh, WI
System Name ChoreBoy
Processor 8700k Delided
Motherboard Gigabyte Z390 Master
Cooling 420mm Custom Loop
Memory CMK16GX4M2B3000C15 2x8GB @ 3000Mhz
Video Card(s) EVGA 1080 SC
Storage 1TB SX8200, 250GB 850 EVO, 250GB Barracuda
Display(s) Pixio PX329 and Dell E228WFP
Case Fractal R6
Audio Device(s) On-Board
Power Supply 1000w Corsair
Benchmark Scores A million on everything....
You can get by with a card that does not require an extra power connector, as well. Depending on the games that you want to play. Some GTX 1050 models don't require a power plug.
41,482 (6.58/day)
Open the case and take a picture, if you are not comfortable doing that take it to a shop
hat
Enthusiast
21,744 (3.33/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
I agree with those saying to open the case and look. @lexluthermiester 's post shows you what a PCI-E looks like. If you're unsure, you can take a picture and post it here, someone will be able to tell you.
His other post however doesn't seem to mention that you can get by with a card that doesn't actually require a power plug like @Basard 's does. There should be plenty of cards like that available that would be a good fit for your system.
That said your system is probably starved for memory too. You'd be best served by just getting an entire new computer, but if you can't or don't want to do that right now, you can squeak by in older games with a low power video card.
26,871 (6.54/day)
While these points are true, the point of not including a list of cards like that is that it can be difficult and confusing for someone who doesn't know what they're looking for to buy a good performer in the low power class of cards. Generally, if a card requires a power connector, it's at least a decent performer.
You guy's are correct though as there are plenty of good video cards that have no need of an extra power connector.
silentbogo
5,533 (1.39/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 3800X
Memory 4x8GB Samsung DDR4 ECC UDIMM
Video Card(s) Inno3D RTX 3070 Ti iChill
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Software Windows 11, Ubuntu 20.04 LTS
26,871 (6.54/day)
It's a Lenovo ThinkCentre A55. All specs are available on Lenovo website.
https://support.lenovo.com/ua/en/solutions/migr-67155
It should only have one full-length PCIe x1 (rev.1.1).
Agreed, based on the pictured bios revision in the OP. @Susanta420, you should have no problems installing a video card on that board;
Based on the Intel 946GZ, it will only take first gen Core 2 Duo CPU's, the E4xxx and E6xxx. Those CPU's are often very inexpensive and will give a decent boost over the E2160 you have now.
