Does overclocking reduce life span/damage cpu
jacoba14
2 (0.00/day)
I really want to overclock my 5820k and my asus pro mobo but I do want to damage or shorten life time or reduce the liability. I am using a corsair h110i gt cpu cooler. I will be using it for at least 4 years
21,432 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
It can, but generally is not an issue if you have good cooling and keep to a reasonable voltage (I hear less than 1.25v is safe).
I am not however, an expert at overclocking the 5820k. My overclock is extremely conservative and I use the low voltage of 1.2v as my limit. I'll let some more experienced people give you advice on the rest of this.
4,290 (1.11/day)
Texas
Mouse Logitech G5
Keyboard Logitech G19S
In reality, it can but as stated by @R-T-B as long as you keep the temps below for your chip 80C your not going to do it by enough that you would notice in a reasonable timeframe. Normally on these chips (Haswell-E) keeping around 1.3 and below if the safest without causing degrading of the chip. Normally when you hear degradation of a chip its caused by extreme over-volting for extreme periods of time which cause the chip to overtime become unstable and require more voltage to handle the clock speeds it had before. Even so the time it takes normally is about the lifespan of the chips anyway (From a performance look).
A friend of mine has a 2600K i7 that has been overclocked to 4.7ghz for years on end constant under liquid and has not shown one problem yet (Circa 2011).
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (2.00/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Power Supply Corsair
Mouse cheap
Keyboard under going restoration
Why did you buy a K edition if you didnt plan to o/c it?
In answer to your question..........i would and you will be fine, watch your temps and wherever you are stable drop it back a bit, you wont notice any difference at all in 50/100mhz
dorsetknob
9,106 (1.27/day)
18 years on the p2 300 (SLOT 1 )i bought with the specific intent of overclocking is still running at 550Mhz ( now inherited by my friends daughter for her personal computer)
19,371 (3.57/day)
Yes... but with reasonable voltages and temperatures, it should last through the useful like of the CPU.
9,019 (1.41/day)
System Name Black Panther
Processor i9 9900k
Motherboard Gigabyte Z390 AORUS PRO Wifi 1.0
Cooling NZXT Kraken X72 360mm
Memory 2 x 8GB Corsair Vengeance RGB Pro DDR4 3600Mhz
Video Card(s) Palit RTX2080 Ti Dual 11GB DDR6
Storage Samsung EVO 970 500GB SSD M.2 & 2TB Seagate Barracuda 7200rpm
Display(s) 32'' Gigabyte G32QC 2560x1440 165Hz
Case NZXT H710i Black
Audio Device(s) Razer Electra V2 & Z5500 Speakers
Power Supply Seasonic Focus GX-850 Gold 80+
Mouse Some Corsair lost the box forgot the model
Keyboard Motospeed
I don't think so. I had bought an E4300 nearly on release, oc'd it to 3Ghz for more than 5 years+. Today it's retired, no longer oc'd but on one of our work pc's and still going strong.
1,019 (0.21/day)
Porto
System Name No name / Purple Haze
Processor Phenom II 1100T @ 3.8Ghz / Pentium 4 3.4 EE Gallatin @ 3.825Ghz
Motherboard MSI 970 Gaming/ Abit IC7-MAX3
Cooling CM Hyper 212X / Scythe Andy Samurai Master (CPU) - Modded Ati Silencer 5 rev. 2 (GPU)
Memory 8GB GEIL GB38GB2133C10ADC + 8GB G.Skill F3-14900CL9-4GBXL / 2x1GB Crucial Ballistix Tracer PC4000
Video Card(s) Asus R9 Fury X Strix (4096 SP's/1050 Mhz)/ PowerColor X850XT PE @ (600/1230) AGP + (HD3850 AGP)
Storage Samsung 250 GB / WD Caviar 160GB
Display(s) Benq XL2411T
Audio Device(s) motherboard / Creative Sound Blaster X-Fi XtremeGamer Fatal1ty Pro + Front panel
Power Supply Tagan BZ 900W / Corsair HX620w
Mouse Zowie AM
Keyboard Qpad MK-50
Software Windows 7 Pro 64Bit / Windows XP
Benchmark Scores 64CU Fury: http://www.3dmark.com/fs/11269229 / X850XT PE http://www.3dmark.com/3dm05/5532432
This is incredible!
peche
Thermaltake fanboy
6,709 (1.83/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
well… I have in the office a i5 2500K, overclocked to 4.5GHZ, working for 3 years, rebooted once every 45 days…. watercooled, under 65C everyday @100% of its potential, no problems so far, it came second handed for cheap… used… also 50 days ago was running stock due maintenance on that computer… no problems also running on stock settings,
the key: keep your processor under safe voltages, also properly chilled, the same for the motherboard, most people cares about properly cooling CPU but not motherboards, Power phases, memory dims and slots are hot zones, decent cooling will bring more lifetime to your hardware…!
apoe
29 (0.01/day)
Depends. If you have good temperatures and simply increase clocks without increasing voltage, any change in lifespan will be negligible. Unless you do extreme overclocking, you will almost certainly end up replacing/upgrading your CPU before this even becomes a consideration.
You could also extend lifespan by undervolting / underclocking. So the question is, is it worth it to you to have less (maybe significantly less) performance for a potentially longer lifespan?
Same thing with graphics card OC. Most non-reference cards are factory overclocked out of the box nowadays. I don't think anyone goes to buy a factory OC'd GPU, and then immediately underclocks them to reference clocks once installed. It's no different.
And if you bought K series CPU and H110i, it would be a waste if you didn't even plan on OCing to begin with.
dorsetknob
9,106 (1.27/day)
This is incredible!
Not really
When released this cpu was exactly the same silicon as the genuine 450 mhz Cpu same S-Spec code just remarketed as 300 mhz P2
read this in a tech mag and so i ordered a p2 300 with this given S-Spec code
when i got it i ghetto installed extra cooling fans then installed it in m/b and set the dip switches for a 450 mhz cpu
booted pc and Viola it ran and registered as a p2 450 later i changed the dip switches so it ran at 550mhz run it at this speed for a couple of years till i upgraded to P3 sold it to a mate who run it for years till he upgraded and he gave it to his little girl
never upped the voltage on the Cpu just changed the Multiplier ( they were all unlocked in those days it was only later that Intel started to lock the multiplier)
Early Celeron P2 could be overclocked even higher ( 700Mhz+)
Ah those were the days :)
hat
Enthusiast
21,745 (3.31/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
It can, but if you play it safe (don't use excessive voltage, keep temps under control) it won't be an issue. You'll upgrade again anyway before anything happens to the chip. The more likely story is the chip may degrade, meaning in time it may become incapable of running at the same speed at the same voltage. This should only happen/be noticeable if you push the chip to its limit, though.
Solaris17
Super Dainty Moderator
26,881 (3.82/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
cadaveca
My name is Dave
17,232 (2.54/day)
You can do what Solaris posted above, and then clock without fear, except when the CPU does die, it will take a few weeks to get the replacement, depending on where you are globally situated.
But let me clarify things for you... VOLTAGE doesn't matter. It is the CURRENT that will degrade a CPU.
See, every CPU is different. The crystalline lattice that makes up the CPU itself is not always perfectly aligned, or perhaps the process of etching the silicon did not go perfectly... all of which is normal. These differences require that certain frequencies require different voltages at the CPU... and so we have CPUs with differing voltage ratings, at "stock". The current, generally speaking, is consistent. Current is pulled by the chip, not given, so adjusting the CPU speed higher can cause it to draw more current... voltage changed or not. So a motherboard has current limits in place...
Yet since modern motherboards allow current limit levels to be changed as well, and often, this is done so automatically when you adjust voltage (depending on board and BIOS used), you need to be very careful and understand that this might be the case.
So, there is no cut-and-dry answer to your question, other than YES.
And to illustrate this idea even more, many boards on the X99 Express platform have added pins that other do not...do you know exactly what those pins do? Does your board even have them? Why is it that early in the launch, when only ASUS boards had this socket, that they were able to clock better, yet over time, many other boards do as well without the OC socket?
The only person that can say no, that OC is safe if you stay within limits... is your board maker, and their BIOS programmer.
But wait... all brands say that OC can damage parts and will void warranty... Perhaps they say this for a reason? Perhaps in a court of law, if they did not, you could prove that OC does damage parts, and this would hold them liable, so they have a default disclaimer?
Sure, some chips can survive w/ OC... but the exact details, the physical makeup of that silicon, the design etched into it, and how the motherboard supplies power are the factors that dictate this, and nearly no one has the equipment to confirm or deny such things.
~A Wise Old Goat. ;)
Mussels
Freshwater Moderator
58,413 (7.95/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
keep the voltages within reason and the temps low, and it'll last forever.
If you overclock at stock or near stock voltages, it should be fine.
11,966 (1.72/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
I had a P4 Prescott overclocked and running F@H for years with no degredation and 3 months of the year it would run just below thermal throttle.
I have never experienced a newer CPU degrading at reasonable temperature.
39 (0.01/day)
System Name Bird's Monolith
Processor Intel i7-4770k 4.6 GHz (liquid metal)
Motherboard Asrock Z87 Extreme3
Cooling Noctua NH-D14, Noctua 140mm Case Fans
Memory 16 GB G-Skill Trident-X DDR3 2400 CAS 9
Video Card(s) EVGA 1080ti SC2 Hybrid
Storage 2 TB Mushkin Triactor 3D (RAID 0)
Display(s) Dell S2716DG / Samsung Q80R QLED TV
Case Fractal Design Define R4
Audio Device(s) Audio Engine D1 DAC, A5+ Speakers, SteelSeries Arctis 7
Power Supply Seasonic Platinum 660 W
Mouse SteelSeries Rival
Keyboard SteelSeries Apex
Back in 2009 I obtained a Core 2 QX9770 Extreme Edition and overclocked the crap out of it, ran it pretty hard throughout its lifetime. As time went on I noticed keeping that overclock stable started requiring a bit more voltage every once in a while and it got to the point where I ended up disabling the OC completely at the end. Granted, the end was in 2013 and by that time the Core 2 architecture was vastly outpaced by i7 architectures and prompted be to upgrade. So, in short, yes, overclocking can have a detrimental effect on the lifetime of your processors. However, it depends on how much you modify the voltage and how much thermal cycling or excessive temps your device experiences.
However, in my experience, from what I've seen in my own systems and friend's systems, said decrease in lifetime span often goes unnoticed as the device will outlive its usefulness and need to be replaced before noticeable degradation occurs. My Core 2 Extreme was kind of an outstanding case, and it could be that maybe something on my motherboard or power supply was degrading in the system, not the CPU, hard to tell.
Go ahead, overclock to your heart's content, just make sure you do your research, keep the temps and voltages in the safe range and be patient and do it right. It's a lot of fun and can give you lots of free performance!
Mussels
58,413 (7.95/day)
Oystralia
that degradation could also have been the VRM's on the board, or the PSU.
1,259 (0.25/day)
Not really if you overclock it on stock voltage and make sure the temps won't go too high, but Yes if you also increase voltage, but even then it doesn't matter because the shortened lifespan is still way to long to wait it out without upgrading. To give you an example, your CPU will last 15-20 years without overclocking and might only last for 10 with overclocking... Even if the other parts in your PC won't "break" by that time, you would probably still be able to buy a faster and more efficient computer (a stick :-] ) ten years from now for less then $100 or for even much cheaper.
2,693 (0.43/day)
System Name panda
Processor 6700k
Motherboard sabertooth s
Cooling raystorm block<black ice stealth 240 rad<ek dcc 18w 140 xres
Memory 32gb ripjaw v
Video Card(s) 290x gamer<ntzx g10<antec 920
Storage 950 pro 250gb boot 850 evo pr0n
Display(s) QX2710LED@110hz lg 27ud68p
Case 540 Air
Audio Device(s) nope
Power Supply 750w superflower
Mouse g502
Keyboard shine 3 with grey, black and red caps
Software win 10
Benchmark Scores http://hwbot.org/user/marsey99/
from my exp not really no xD
i have had chips never been oc die for no reason and have chips that have been ran oc for nearly a decade still going fine. i sold an e4300 which has ran 3.2ghz min since i got in 06 at the end of last year. had a few in its life which just died for no reason :s
go figure.
5,244 (0.88/day)
System Name [Daily Driver]
Processor [Ryzen 7 5800X3D]
Motherboard [MSI MAG B550 TOMAHAWK]
Cooling [be quiet! Dark Rock Slim]
Memory [64GB Crucial Pro 3200MHz (32GBx2)]
Video Card(s) [PNY RTX 3070Ti XLR8]
Storage [1TB SN850 NVMe, 4TB 990 Pro NVMe, 2TB 870 EVO SSD, 2TB SA510 SSD]
Display(s) [2x 27" HP X27q at 1440p]
Case [Fractal Meshify-C]
Audio Device(s) [Fanmusic TRUTHEAR IEM, HyperX Duocast]
Power Supply [CORSAIR RMx 1000]
Mouse [Logitech G Pro Wireless]
Keyboard [Logitech G512 Carbon (GX-Brown)]
Software [Windows 11 64-Bit]
Technically speaking, yes straining a part outside of stock specs will shorten the lifespan.
But realistically as long as you're not doing absurd voltages and temps you'll be upgrading before it dies.
561 (0.11/day)
System Name Salamander
Processor Ryzen 5 3600 @ 4.325ghz 1.206v
Motherboard Asrock X370 Taichi
Cooling EK Supremacy Evo | Black Ice Nemesis 360GTS XFlow | Noiseblocker BlackSilent Pro 120mm x 3
Memory Team T-Force Xtreem 2x8GB DDR4 3733 @ 3733mhz c16 1.4v | IF @ 1866mhz
Video Card(s) XFX RX-470 RS Single Fan flashed to RX-570 @ stock water-cooled
Storage Samsung 850 Evo 256gb M.2 | Crucial M4 128GB | WD Blue 1TB | WD Blue 500GB 2.5" | Toshiba 2TB 2.5"
Display(s) LG 27MP68VQ 27" 1920x1080 75hz IPS Freesync monitor
Case Fractal Design Define C
Power Supply Seasonic Prime Gold 650w
Mouse Steelseries Kana White
Keyboard Steelseries 6GV2 Cherry MX Black
Software Windows 10 Pro N
I haven't had a cpu die on me cause of overclocking. And those overclocked cpus got new owners now so dunno if they are still alive or has gone to hardware heaven ( no pun intended ).
9,906 (1.85/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
yea, you get higher risk damaging your hardware but as long as you do light OC and not playing the voltage it would be safe
and dont forget since you push your hardware you need better cooling
silentbogo
5,539 (1.38/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 3800X
Memory 4x8GB Samsung DDR4 ECC UDIMM
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
As long as you don't do anything stupid like LN2 you'll be fine. Excessive overclocking may sooner kill your motherboard, PSU or any other component, but the CPU is usually the last to stand :nutkick:
In all my years being around computers I can sum up 99.9% of CPU deaths to physical damage (broken die, bent pins, water etc.).
I even have a cool topic-related story:
Few years ago I was OCing an AMD Athlon 64 X2 on my BFG motherboard. The rig was placed in my garage and I've used a bunch of dry ice to keep it cool (first experience with DICE!!!).A storm was coming and we had a lightning strike somewhere nearby, which caused a crazy spike in mains all over the neighborhood. In a matter of milliseconds some light bulbs popped, circuit breaker powered off, smoke came out of my PSU and things went south. I've tested my MoBo afterwards and it was permanently dead (so was RAM), while CPU still served for another 4 years in my other rig (also OC'ed) until I sold it!
With all my recklessness I've managed to kill only 2 CPUs in my entire life: broke a die in Duron XP and un-successfully de-lidded Athlon X2 5200+
