[Case Gallery] Domina (Laurijan´s rig)
2,696 (0.42/day)
Oulu, Finland
System Name Enslaver :)
Processor Ryzen 7 7800X3D
Motherboard ASUS TUF Gaming B650-Plus
Cooling CPU: Noctua D15 G2, Case: 2 front in, 1 rear out
Memory 2x16GB Kingston Fury Beast RGB 6000MHz
Video Card(s) ASUS TUF RTX 4070Ti OC
Storage Samsung Evo Plus 1TB NVMe , internal WD Red 4TB for storage, WD Book 8TB
Display(s) LG CX OLED 65"
Case Lian Li LANCOOL II Mesh C Performance
Audio Device(s) HDMI audio powering Dolby Digital audio on 5.1 Z960 speaker system
Mouse Logitech G700
Keyboard ASUS Strix Tactic Pro
Software Windows 11 Pro x64
Specs:
CPU: Intel Q6600 G0 Stepping @3GHz
Mobo: DFI LanParty Dark P35-T2RL
Fans: Cpu - Arctic Cooling Freezer 7 Pro,
Case - 3x12cm Antec standart
Ram: 4x1GB OCZ Reaper HPC - 800MHz
@3-4-4-15
GPU: Inno3D 8800GT 512MB - OC Edition
HDD: 2x Maxtor 500Gb 32Mb - Raid 0
DVD: Samsung Super-Writemaster - Lightscribe - DVD-RW/RAM
CRT: 21" Nokia 445PRO - TrueFlat Trinitron - 1024x768@150Hz
Case: Antec P182 - Gunmetal Black Edition
Sound: Realtek ALC885 - High Definition -
8-channel audio output
PSU: Termaltake Thoughpower 750W -
Cable management
OS: Windows XP 32Bit
INet: Anonymous VPN 10Mbit/10Mbit(Relakks.com)
Mods:
CLICK ON THE PICS WHICH MIGHT BE DISTORTED - THAT WILL MAKE THEM NORMAL AGAIN!
Installed 2x cold-cathode lamps (one blue and on red) the blue one is in a plexi tube to protect it and did a lot of cable management with this cable management friendly case (Antec P182).
I installed an OCZ ram cooler with blue lights too..
Also i bought a 6 lamp disco light which i put on one of my front speakers to round the look up - which can be seen in action in youtube http://www.youtube.com/watch?v=u784M6rpONs
Hope you enjoy it!
sneekypeet
not-so supermod
29,489 (4.36/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Reverse airflow...nice idea with the Reapers blocking the CPU fan install.
Clean, simple , and tidy....great work!
Edit: its too new...will be back later to vote!
2,696 (0.42/day)
Oulu, Finland
Mouse Logitech G700
I install a second cold-cathode lamp on top on monday or so..
Cold Storm
Battosai
15,010 (2.41/day)
In a library somewhere on this earth
System Name Haro
Processor AMD 1700x
Motherboard AsRork x370 Taichi
Cooling EK Custom Loop - CPU only
Memory 32gb G-Skill Trident Z
Video Card(s) EVGA 1080 Superclock 2
Storage Too Many
Display(s) Viewsonic VX2450WM-LED 24" & LG 32 IPS
Case Cooler Master Cosmos II
Mouse SteelSeries Rival 500
Software Win10 Pro
Benchmark Scores i5 750 4.62ghz pi runs // Evga FTW p55
Pretty nice set-up you have there! How does your Dark board handle for ya?
47,129 (7.58/day)
Reverse air flow? Did he change the polarity of the fan or is it blowing towards the RAM?
If not, the polarity of the CPU fan could be changed, so it pulls hot air off the fins.
1,372 (0.21/day)
Chicago, IL
System Name Stealth 2 Duo Turbine
Processor Intel e6850 @ 3.8ghz
Motherboard Asus Striker Extreme
Cooling CoolerMaster V8 Modded With 2 white LED's & 100CFM fan
Memory OCZ DDR2 1066_ SLI Black-4GB
Video Card(s) 2xMSI 8800GT"s SLI
Storage <<HDD For OS>> 2x150GB_Western Digital Raptor_Raid 0. <<HDD For Storage>> 3 x 1TB
Display(s) ACER B273HU 27" LCD 2048x1152
Case Apex SuperCase_Custom 7 month Build
Audio Device(s) Striker Extreme Add-In Card HD-Audio
Power Supply EnerMax INFINITI 720watt
Software SE7VEN ULTIMATE 64bit
Benchmark Scores 3DMark01=NTTA, 3Dmark06=NTTA 3Dmark_Vantage=NTTA, Core Temp v0.99.5=28C
Superb wire management, very clean looking, Nice Build,, have u thought about an LCD monitor, they really have come a long way.
2,696 (0.42/day)
Oulu, Finland
Mouse Logitech G700
I had a DFI Blood-Iron before which i had to RMA and I decided to get the DFI Lanparty Dark one instead because it has UV reactiv slots and parts, Cmos Reloaded (Bios profiles) and all solid capacitors as well as an better layout of all connectors - from the performence side both are the same since the Dark is only better in above mentioned things.. I havent maxed out my oc for now but will update my system specs later on..
2,696 (0.42/day)
Oulu, Finland
Mouse Logitech G700
Which LCD gives me 150Hz refresh rate? If i could marry my CRT i would do it LOL
2,696 (0.42/day)
Oulu, Finland
Mouse Logitech G700
I dont care much about the airflow because my case is open all the time.. but the CPU cooler cools the ram too which i like very much.. PS I changed the fan direction of the case fan which is on the same height as the CPU cooler so it pushed air towards the CPU cooler.
47,129 (7.58/day)
If you reverse the fan, even then it could cool the RAM, perhaps even better, because then the fan will begin to draw air from the fins, and the fins themselves draw air from surrounding areas including the RAM, and the air surrounding the RAM is relatively cooler than if you blow air preheated by the CPU to it.
Cold Storm
Battosai
15,010 (2.41/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
Yeah, I remember what happened... dang it... but I'm glad your back and can't wait to see the oc on that baby!
1,372 (0.21/day)
Chicago, IL
150Hz refresh rate @ 1024x768, first of all Native (Recommended) Resolution 1600x1200 on your monitor, whats your refresh rate at the Native (Recommended) Resolution of 1600x1200, second of all theres no DVI, I'm sure your video card has dual DVI"s. so now you lose clarity with an adapter. Don't get me wrong I think it was a nice aperture grille crt for it's time but it has nothing on a Samsung 22" 226BW LCD,, I know this because My old IIyama 22'' vision master Pro 510, I payed $1000 for back then, that was set at 100Hz refresh rate @ 1600x1200. Has nothing on My Samsung 22" 226BW.
1,193 (0.19/day)
Bellevue, WA
System Name 0BL1V10N
Processor Intel Core i7 11700K @ 5.1GHz all-core turbo
Motherboard ASRock Z590 Taichi
Cooling Cooler Master MasterLiquid 360 (with stock CM fans), 12x Pccooler Moonlight Series ARGB 120mm fans
Memory (4x16GB) 64GB Mushkin Redline Lumina 3600MHz 16-19-19-39 XMP
Video Card(s) MSI RTX 4090 SUPRIM LIQUID 24G (not using stock fans) (+150MHz core, +1000MHz memory)
Storage Western Digital Black SN850X 2TB Gen4 NVMe
Display(s) 1x Alienware AW3821DW (3840x1600@144Hz), 2x Dell SE2717H (1080p@75Hz)
Case Phanteks Enthoo 719 Anthracite Grey
Audio Device(s) Schiit Modius + Drop THX AAA 789 + Custom Planar Magnetic Headphones
Power Supply Thermaltake Toughpower GF3 1200W (12VHPWR)
Mouse Logitech G502 X Plus
Keyboard Too many custom mechanical builds to list...
Software Windows 10 Pro 22H2
Agreed 100%. My Dell 2407WFP completely pwned my 21" Viewsonic Professional Series monitor in every way. I would never look back.
OP, Nice comp btw I really like those new DFI boards.
2,696 (0.42/day)
Oulu, Finland
Mouse Logitech G700
Bump - because i changed all pics and because i bought a second cold-cathode lamp and a disco light - if you wanna vote please do it fair - i worked on this like a crazy horse
1,372 (0.21/day)
Chicago, IL
Maybe u could paint the inside of the case & monitor Black. If not,, my rating of 8 stays. New pictures & a disco light wont do it,, Other then all that, it's still a clean build with no mods.
2,696 (0.42/day)
Oulu, Finland
Mouse Logitech G700
8 is more than i ever thought to get for that thx
Cold Storm
Battosai
15,010 (2.41/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
Laurijan, the system is quite nice, need to get your sig updated, but the system is what counts! It's just a start of what you can possibly be able to do. 8 is what I gave ya, and glad to see it working for ya.
MikeJeng
551 (0.09/day)
United States - CA
System Name Nerd Command Center
Processor i5-2500K 3.3Ghz
Motherboard MSI P67A-GD55
Cooling Corsair H70
Memory Corsair DDR3 1600 (2x2GB)
Video Card(s) EVGA GTX570
Storage Ocz Vertex 2 60GB
Display(s) Samsung 2343bwx 2048x1152
Case CM Cosmos 1000: Matte black + window
Power Supply Thermaltake 700W Modular PSU
Software Windows 7 Ultimate
AHRGHADHAHH!!!!
A crt. lol
3,935 (0.65/day)
West Chester, OH
I like everything about your setup. Nice cable management, good air flow, nice components, etc. 8/10. Check mine out! (link in sig)
6,959 (1.05/day)
Australia, Sydney
Superb setup, 9/10
Anyway one thing I must comment on, your CPU cooler. Grab something like a Xigmatek HDT S1283, and a proper cooling solution for the RAM; if it runs that hot. You'll get better results than what you are getting with your Freezer PRO 7. The FP7 is actually longer than the Xiggy; the xiggy will fit properly without needing to resort to reverse airflow.
2,696 (0.42/day)
Oulu, Finland
Mouse Logitech G700
I forgot to mention that i changed the fan direction already in the early days of this rig..
2,696 (0.42/day)
Oulu, Finland
Mouse Logitech G700
Superb setup, 9/10
Thanks for posting in my humble gallery (not only tkpenalty).. I will save up some cash to make the proper investments.. maybe go even water.. i am happy that you try to max out my rig so that it gets more stunning..
3,296 (0.54/day)
System Name Thakk
Processor i7 6700k @ 4.5Ghz
Motherboard Gigabyte G1 Z170N ITX
Cooling H55 AIO
Memory 32GB DDR4 3100 c16
Video Card(s) Zotac RTX3080 Trinity
Storage Corsair Force GT 120GB SSD / Intel 250GB SSD / Samsung Pro 512 SSD / 3TB Seagate SV32
Display(s) Acer Predator X34 100hz IPS Gsync / HTC Vive
Case QBX
Audio Device(s) Realtek ALC1150 > Creative Gigaworks T40 > AKG Q701
Power Supply Corsair SF600
Mouse Logitech G900
Keyboard Ducky Shine TKL MX Blue + Vortex PBT Doubleshots
Software Windows 10 64bit
Benchmark Scores http://www.3dmark.com/fs/12108888
9/10!
Great specs, clean build.. CRT drags it down though ^^
4,520 (0.71/day)
Perth AU
Processor Intel Core i9 10980XE @ 4.7Ghz 1.2v
Motherboard ASUS Rampage VI Extreme Omega
Cooling EK-Velocity D-RGB, EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
Memory G.Skill Trident Z RGB F4-3000C14D 64GB
Video Card(s) Asus ROG Strix GeForce RTX 4090 OC WC
Storage M.2 990 Pro 1TB / 10TB WD RED Helium / 3x 860 2TB Evos
Display(s) Samsung Odyssey G7 28"
Case Corsair Obsidian 500D SE Modded
Power Supply Cooler Master V Series 1300W
nice system you need to grab your self a lcd man, and i don't care what any one says, i've had so so many problems with OCZ reaper ram with errors, dieing
2,696 (0.42/day)
Oulu, Finland
Mouse Logitech G700
Plexi tube for cold-cathode lamp installed and OCZ ram cooler.. Vote plz..
