Double radiator setup with GPU fans on top
Monso
24 (0.08/day)
Hello :)
CPU: Ryzen 9 4950X3D + Corsair H150i Link
GPU: MSI Geforce RTX 4090 SUPRIM LIQUID X
I've seen some claims that a GPU radiator should be set as intake. But on the MSI page for sample configurations, they set the GPU radiator as exhaust on the side:
I would prefer to put the GPU radiator on top and the CPU radiator on the side. Something like this (excuse the paint skills):
Would this work? Or is there any reason not to do this? Thanks.
444 (0.69/day)
System Name Computer
Processor Intel 12700K
Motherboard Asus Prime Z690-A
Cooling Twin radiator open loop
Memory Corsair Dominator 32GB DDR5
Video Card(s) eVGA 3080 FTW3 Ultra
Storage Sabrent Rocket 4 Plus 2 TB
Display(s) Asus PG348Q and two Asus VN279Q monitors
Case Corsair 4000D Airflow
Audio Device(s) Sennheiser GSX 1000 with Sennheiser HD599 SE
Power Supply Asus Thor 1200P
Mouse Corsair Scimitar Elite RGB Wireless
Keyboard Keychron Q3 Max
VR HMD Oculus Rift CV1
Overall, the difference should be negligible, like a couple of degrees difference at most for either component. If you feel like prioritizing, put whatever generates the most thermal load under expected usage on the exhaust side so it dumps less heat into the case (this should be the 4090).
ir_cow
4,858 (0.80/day)
USA
If you have good airflow your looking at 2-3c difference depending on which is intake and out. can't go below room ambient temperature anyways.
Personally I'd make the GPU and CPU outtake in possible and draw the air from the bottom. Otherwise pick a direction and have air come in and go out like a air cooled case.
Don't worry about that odd second image layout. It's not going to be much bigger hassle and not worth it.
9,763 (3.26/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Whatever you put as intake will run cooler and whatever is set to exhaust will run hotter. I'd put the CPU rad in front in your case since the GPU wont really benefit from better cooling but the CPU might.
de.das.dude
Pro Indian Modder
9,198 (1.71/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad | Old Monke
Case Ant Esports Tempered case | Thinkpad | NZXT Guardian 921RB
Audio Device(s) Logitech Z333 | Jabra corpo stuff | Some USB speakers
Mouse Logitech G400 | nipple | Dell
VR HMD ;_;
GPUs generate a lot of thermal energy compared to CPUs. So any air passing over the GPU rad will heat up, and your other components will run hotter. and CPU will get hot air to cool down it. Not ideal.
1,142 (1.71/day)
You need to put the GPU rad on top as an exhaust. These GPU AIOs run the water pretty warm, thus warming the air considerably and you do not want such warm air in your case.
Ruru
S.T.A.R.S.
13,559 (3.03/day)
Jyväskylä, Finland
Ah so you have AIO-cooled ones, at least it's easier to try different setups than as me with a custom loop. :D
I'd also have the GPU rad in top as it's most likely way better as it dumps its heat straight out of the case.
Monso
24 (0.08/day)
Can you ellaborate why it's not worth it? Some people seem to agree that the GPU rad should be on top. This is even in the manual for the SUPRIM LIQUID:
Seeing this, for me the only logical place for the CPU rad is on the side. Hence my drawing.
If I understand, you're saying that because the loop of the GPU rad goes over the CPU, it will warm its environment and make the CPU rad work harder. Isn't that taken care of by the airflow? The exhaust fan at the back is right next to the loop.
My reasoning is: since the GPU makes the most heat, it should have priority on the best exhaust position at the top.
9,763 (3.26/day)
Case Phanteks NV7
You put whatever you want to have priority as an intake, there is no point to have the GPU as an intake because it will run very cool anyway.
1,142 (1.71/day)
The GPU AIO will run the water at least 15°C warmer than ambient, will warm the air by at least 10°C and if you put it as an intake you will make your PC case an oven! Especially in summer. Keep in mind that this is a 4090 on a single 240 rad!!!
OP, follow the graphic card manual!
These GPU with built-in AIOs run not that much cooler than cards with air coolers, their main benefit is that you can move the heat outside the case and you make this happen only when you put the rad on top as an exhaust.
882 (0.14/day)
Pacific Coast
System Name Z77 Rev. 1
Processor Intel Core i7 3770K
Motherboard ASRock Z77 Extreme4
Cooling Water Cooling
Memory 2x G.Skill F3-2400C10D-16GTX
Video Card(s) EVGA GTX 1080
Storage Samsung 850 Pro
Display(s) Samsung 28" UE590 UHD
Case Silverstone TJ07
Power Supply Seasonic PRIME 600W Titanium
Mouse EVGA TORQ X10
Keyboard Leopold Tenkeyless
Benchmark Scores 3DMark Time Spy: 7695
