[Case Gallery] Dragon Rage *Revisited*
427 (0.08/day)
The Netherlands
System Name Monolith // Fileserver
Processor Intel Core i7 2600K @ 3.4GHz // 2x Intel Xeon Nocona, @ 4x 2.8ghz
Motherboard ASUS Maximus IV Extreme-Z // ASUS NCCH-DL Socket 604
Cooling Corsair H60 // 2x Thermaltake Full Copper Blocks
Memory 16GB DDR3 1600MHz Corsair // 1.5GB of Kingston and Corsair @ 400MHZ
Video Card(s) ASUS GTX570 DCII // ASUS X800XT 256MB
Storage 2x Samsung 830 128GB, 1TB Samsung, 1TB WD Black // 74 WD Raptor, 120GB Seagate
Display(s) 3x 22" LG LCD Screen // Neovo 15" LCD Screen
Case Lian Li PC-A71F // Chieftec Big Tower
Audio Device(s) Creative F4tality Champion Series 7.1 // Onboard AC97 audio
Power Supply Corsair HX 1000W // BeQuiet 520w
Software Windows 7 Professional x64 // Windows XP Professional x86
Benchmark Scores Can play Pacman and Space Invaders. Lags a bit, but still playable :D
Specs:
CPU: AMD Phenom II 945 @3.0ghz
RAM: OCZ Gold DDR3 1600Mhz 4GB
Motherboard: ASUS M4A79T Deluxe
Videocard: 2x Sapphire 2GB HD4870 Vapor-X
HDD: 1x 320GB Maxtor 8MB, 1x 1TB Seagate 32MB, 1x 1TB WD Black 32MB
Cooling: Coolermaster V8 + 5 Coolermaster Red LED fans
Sucks that I got 1 RAM error. It isnt giving me to much problems but at times it shows itself by hanging up my PC. For the moment I'm not gonna RMA it since I dont have a clear indication if its my RAM, CPU or motherboard that is giving that error.
Duffman
1,011 (0.16/day)
Mt. Pocono, PA
System Name Black Knight
Processor Intel Xeon W3520 @4.2Ghz
Motherboard evga Classified 760
Cooling Prolimatech Mega Shadow with Dual Noctua NF-P12 fans
Memory 6GB Corsair Dominator GT DDR3 (3gb x 2) 1600
Video Card(s) Sapphire 5870 Vapor-X
Storage Corsair P128 SSD for OS, 4 Samsung 500GB in RAID10 For Storage
Display(s) Samsung SyncMaster T240HD
Case Corsair Obsidian 800d Twin Zalman ZM-MFC Plus fan controllers
Audio Device(s) HT|OMEGA CLARO
Power Supply Antec Truepower 1000
Software Win7 64bit ultimate
Pretty nice man. Is that a 690 Case? Putting a fan on that bottom intake really helps with temps.
970 (0.18/day)
Granby, Qc. Canada
System Name Loose nuts & bolts
Processor FX-8350 - EK Supreme HF full nickel
Motherboard ASUS Sabertooth 990FX R2.0
Cooling Water EK goodness all around 2xBlack Ice X-280
Memory 2 x8G HyperX Fury 1600 @ 9-9-9-24-1T
Video Card(s) 2 x XFX RX 480 w/EK-FC RX 480 nickel+Acetal
Storage Samsung 850 Evo + 2xWD Black 500GB in RAID0
Display(s) Crossover 27" 2560x1440 110Hz OC
Case Cooler Master HAF XB EVO
Audio Device(s) on board
Power Supply Corsair HX850
Software Win 10 Enterprise x64
I voted 9/10 because:
Nice and clean. I like it.
Keep up the good work Kenny
diesel700
Its a HAF 922, putting the bottom fan on, unless you make the front one slow, for some reason makes my graphics card run hotter, I don't use mine.
427 (0.08/day)
The Netherlands
Exactly, I had the old 120mm from my Aerocool on the bottom for a while, but the massive air displacement the 200mm front fan makes renders it useless. Its air hardly even reaches the memory heatsink of my bottom card.
All it contributes too is adding to the dust build up in my case.
I'm thinking of going for a ibig tower case, because the bottom card has very little room to breath. Do any of you have any recommendations below €150 / $180-200?
diesel700
On the subject of Dust, the bottom dust filter and plastic frame off a CM690 fits the HAF922, I run mine with just the plastic bit and filter (and no fan) in there, also helps route cables as it has guides attached to it.
I want to find a Lian Li Armorsuit, like this the PC60 Variant, bit hard to find though,
http://www.hardwarezone.com/articles/view.php?cid=22&id=2477
Not sure of price, were about £150 or 180 or so Euros some times back.
