- Oct 9, 2007
- 46,929 (7.61/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Yuri "1usmus" Bubliy over the weekend released the latest version of DRAM Calculator for Ryzen, the definitive tool for overclocking and optimizing memory on your AMD Ryzen-powered PC. The tool lets you calculate the best possible memory-related settings specific to your machine. Version 1.7.1 introduces several new changes. For starters, it now has updated presets for three of the most popular DDR4 DRAM die types obtained from hundreds of hours of re-testing various brands of memory modules on the latest version of AMD AGESA. These affect everything from procODT to VDDG settings, and the introduction of CL15t, which stabilizes problems encounted in finding timings with CL14t.
The R-XMP button (which attempts to translate your DIMM's XMP to AMD-compatible settings), and "Calculate EXTREME" buttons have been removed, and in their place, the "Calculate FAST" button has been optimized for the best possible stable settings; and "Calculate SAFE" for reasonably fast yet safe settings. DRAM Calculator for Ryzen now has DIMM PCB revision awareness. Several popular memory vendors have multiplie revisions of PCBs for the same DIMMs (and same DRAM chips, which can affect tuning headroom). This provides an additional layer of accuracy in calculating timings. In addition, there are several UI changes, such as a "compare timings" button with added functionality. Preliminary support is also added for future "Zen 3" based processors. Grab the tool from the link below.
DOWNLOAD: DRAM Calculator for Ryzen v1.7.2 by 1usmus
The change-log follows.
Update 09:07 UTC: The DRAM Calculator for Ryzen has just been updated to v1.7.2. Detailed below.
- Reworking of all presets for Samsung b-die, Micron e-die and Hynix CJR (DJR). Improved support for configurations with 4 or 8 RAM modules.
- R-XMP and Calculate EXTREME buttons removed.
- Added new Help and my reviews section, which provides links to my materials in addition to reference information.
- DRAM PCB Revision - select PCB RAM for more accurate calculation of timings. In most cases it is recommended to use "A0" for better compatibility.
- The "Compare timings (ON/OFF)" button has received updated functionality. It can read not only the timings, but also show the state of the timings in color. Your personal assistant for creating individual presets.
- Added "New version?" button, which allows you to visit the product homepage and read the materials regarding DRAM Calculator for Ryzen, check for updates or ask any question.
- Error fixes and some graphical adjustments.
- Timings read support for all Ryzen family processors (including future Zen 3 processors).
- Support OC assist for Micron E-die (A2) and CJR/DJR (A0 and A2)
- Some correction for OC assist (Samsung B-die)
- Additional presets for Hynix CJR / DJR (now A0 and A2)
- Error fix: "Parse data"
- Minor fix: voltage for Samsung B-die
- Minor fix: some timings for Micron E-die
- Minor fix: tWRRD for 4 DIMM configuration
- Other bug fixes
