DRAM LED
Naitaslan
6 (0.00/day)
Hi
So my brother bought a new pc in november 2019 and till feburary it was working correctly but one day for no reason it wouldn't boot and dram led lighted up. So we send his ram back to manufacturer and they gave us new ram but the same thing is happening. Any ideas?
His pc:
AMD ryzen 3 1200(was planned to upgrade)
Gigabyte B450 AORUS ELITE
Gigabyte GeFroce 1660ti
Ballistix Ballistix Sport LT DDR4, 16 GB,3000MHz, CL15 (BLS2K8G4D30AESBK)
SilentiumPC Vero L2 600W
193 (0.09/day)
System Name Zen4
Processor Ryzen 9 7950x
Motherboard Asus Strix B650E-E Gaming WiFi
Cooling Some oem 240 AIO
Memory 2xKingston DDR5 2x16GB (Hynix M die)@6000 CL26-35-35-27
Video Card(s) Gainward Phantom 4090 (@2.82GHz .95V UV, 350W PL)
Storage WD Black SN850X
Display(s) LG OLED C1 48"
Case Phanteks P600S
Power Supply Corsair RM1000i
Mouse Logitech G Pro X Superlight
Keyboard Corsair K70
VR HMD HP Reverb G2
Software Win11
Have you tried to clear cmos? You could also try one RAM stick at a time.
Naitaslan
6 (0.00/day)
Yes I tried both of them before and after sending them back and nothing seems to work. ;/
AlienIsGOD
Vanguard Beta Tester
5,113 (0.86/day)
Kingston, Ontario Canada
System Name Aliens Ryzen Rig | 2nd Hand Omen
Processor Ryzen R5 5600 | Ryzen R5 3600
Motherboard Gigabyte B450 Aorus Elite (F61 BIOS) | B450 matx
Cooling DeepCool Castle EX V2 240mm AIO| stock for now
Memory 8GB X 2 DDR4 3000mhz Team Group Vulcan | 16GB DDR4
Video Card(s) Sapphire Pulse RX 5700 8GB | GTX 1650 4GB
Storage Adata XPG 8200 PRO 512GB SSD OS / 240 SSD + 2TB M.2 SSD Games / 1000 GB Data | SSD + HDD
Display(s) Acer ED273 27" VA 144hz Freesync |TCL 32" 1080P w/ HDR
Case NZXT H500 Black | HP Omen Obelisk
Audio Device(s) Onboard Realtek | Onboard Realtek
Power Supply EVGA SuperNOVA G3 650w 80+ Gold | 500w
Mouse Steelseries Rival 500 15 button mouse w/ Razor Goliathus Chroma XL mousemat | Logitech G502
Keyboard Corsair K65 Mini w/ Cherry MX brown keys | Logitech G513 Carbon w/ Romer G tactile keys
Software Windows 10 Pro | Windows 10 Pro
B450 aorus elite can be finicky with memory, is it on the qvl list? Also is the board under warranty still? Maybe a mobo RMA is in order
2,963 (0.84/day)
Long Island
Hi
1. Bought assembled or bought the parts and built ... just want to make sure as you sent RAM back to RAM manufacturer rather than system builder.
2. If you bought it built, get them on the phone and have them walk you through the troubles hooting process.
3. Ram in 2nd and 4th slots to right of CPU ?
4. Three reasons why I don't like using the low budget chipsets:
a) Typically substandard audio and LAN subsystems ... Old ALC 892 used here...ALC 1220 standard
b) Limited storage / other options
c) Weak troubleshooting capabilities in the way of troubleshooting LED trouble lights of diagnostic code LCDs.
5. CPU Fan power / rpm sensor cable plugged on
6. Paperclip tested the PSU ?
Naitaslan
6 (0.00/day)
Okey so:
1. Bought the parts.
2. Doesn't matter bec 1
3. Yes it is
4. Always more knowledge
5 and 6 i need to ask him to check that out and let you know later on.
It is not listed but many people said they work for them and sticks were for a good price so we decided to go for them.
42,040 (6.62/day)
Ga boards tend to be tempermental with ram acriss the board.
silentbogo
5,540 (1.38/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 4x8GB Samsung DDR4 ECC UDIMM
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Have you ever updated BIOS on that thing? Initially the 400-series AORUS boards were awful with memory. My x470 Ultra Gaming used to freeze on older firmware versions w/ my Vulkan Z DDR4-3000.
I think only on F41 and up it became adequately stable.
AlienIsGOD
5,113 (0.86/day)
I also own the board in question and am, guess I'm lucky that even on bios f5 my team group vulcan t-force ran fine with xmp on. I'm on F50a atm but for other users there are plenty of improvements in the last 7 or 8 for the aorus elite
Naitaslan
6 (0.00/day)
How can I update bios in other way than traveling to him with my own ram and hope that they will work? Because i don't think he ever updated bios apart grom that one time when we built it.
silentbogo
5,540 (1.38/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
Just make him clear CMOS so it'll revert back to JEDEC profile instead of XMP. This way he can use his PC normally.
Afterwards he needs to download the latest firmware from Gigabyte's product page, and simply copy it to a formatted USB drive.
Few notes, though:
1) If his current version is below F40, he first has to update to F40, and then go on with the latest version.
2) I don't remember the exact version, but I think it was on F31, I had trouble updating from USB. Had to use a separate small FAT32 partition on my SSD as a workaround.
3) After updating and rebooting it's recommended to clear CMOS once again, and redo all settings
4) any overclocking/fan profiles will be erased.
AlienIsGOD
5,113 (0.86/day)
Bios f32 is what is needed 1st along with EC firmware update tool
Naitaslan
6 (0.00/day)
Few notes, though:
So you think that he didn't clear CMOS correctly? And if he would did it correctly it would boot?
silentbogo
5,540 (1.38/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
There is no "correct" way to clear CMOS. Only one way - drain power to CMOS.
Just to be on the 100% sure side, make him unplug the power, press the power button for a few seconds, take out the CMOS battery and wait a minute or so before putting it back.
BTW, have you tried his RAM in another PC? Or have you tested his PC with a known good DDR4 stick(s)?
Naitaslan
6 (0.00/day)
The problem is we live on different towns and i never had time to test it with mine and current situation and restrictions aren't making things easier.
