Driver Cleaner Utility?
Bokteelo
479 (0.08/day)
Does anybody know of a user friendly free driver cleaning utility? I've tried DH Driver Cleaner or something, Driver Magician, etc, and didn't know how to work any of them properly, I'm afraid of removing the incorrect drivers and screwing something up.
Driver Cleaner Professional 1.5 had a noob-friendly interface, where all I had to do was press scan and it'd find drivers I didn't need. Ended up with around 200 unused files that might be causing the issue I've been having which can be found here. But Driver Cleaner Pro 1.5 is a commercial software that requires $$!
43,628 (6.37/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Driver Sweeper at Guru3d works very well. Highly recommended.
5,226 (0.82/day)
System Name Addison Clark
Processor Ryzen 9 7950x3D delid
Motherboard Asus X670E Hero
Cooling Custom Bykski loop CPU, GPU, 2x 360 rads, and 1x 280 rad with Arctic P12 and P14 ARGB fans
Memory G.Skill DDR5-6000 64GB CL30
Video Card(s) Gigabyte 4090 Aorus Master
Storage Kingston Fury 2TB and 4TB NVME
Display(s) Samsung 57"
Case Lian Li O11 mini
Power Supply Thermaltake 1000w SFX-L
Keyboard Corsair K95 Platnium
Software Win 11 Pro
Bokteelo
479 (0.08/day)
Thank you, I'm going to try it now.
Edit: How exactly is this used? I can't seem to figure out what I should and shouldn't remove... >_>
Excuse me, noobie passing bye!
alexp999
Staff
8,012 (1.24/day)
Dorset, UK
System Name Gaming Rig | Uni Laptop
Processor Intel Q6600 G0 (2007) @ 3.6Ghz @ 1.45625v (LLC) / 4 GHz Bench @ 1.63v | AMD Turion 64 X2 TL-62 2 GHz
Motherboard ASUS P5Q Deluxe (Intel P45) | HP 6715b
Cooling Xigmatek Dark Knight w/AC MX2 ~ Case Fans: 2 x 180mm + 1 x 120mm Silverstone Fans
Memory 4GB OCZ Platinum PC2-8000 @ 1000Mhz 5-5-5-15 2.1v | 2 x 1GB DDR2 667 MHz
Video Card(s) XFX GTX 285 1GB, Modded FTW BIOS @ 725/1512/1350 w/Accelero Xtreme GTX 280 + Scythe sinks| ATI X1250
Storage 2x WD6400AAKS 1 TB Raid 0, 140GB Raid 1 & 80GB Maxtor Basics External HDD (storage) | 160GB 2.5"
Display(s) Samsung SyncMaster SM2433BW @ 1920 x 1200 via DVI-D | 15.4" WSXGA+ (1680 x 1050 resolution)
Case Silverstone Fortress FT01B-W ~ Logitech G15 R1 / Microsoft Laser Mouse 6000
Audio Device(s) Soundmax AD2000BX Onboard Sound, via Logitech X-230 2.1 | ADI SoundMAX HD Audio
Power Supply Corsair TX650W | HP 90W
Software Windows 7 Ultimate Build 7100 x64 | Windows 7 Ultimate Build 7100 x64
Benchmark Scores 3DM06: 19519, Vantage: P16170 ~ Win7: -CPU 7.5 -MEM 7.5 -AERO 7.9 -GFX 6.0 -HDD 6.0
Yeah driver Sweeper is the only one I found that actually works on X64 too :)
And I tick the box for the appropriate driver and let it delete everything!
43,628 (6.37/day)
What drivers are you looking to uninstall?
Bokteelo
479 (0.08/day)
Ya see, I've got no idea. After removing the mobo battery and resetting the CMOS, my computer no longer shuts off. I get a BSOD after Windows shuts down, error code 0xA. I'm guessing it's a driver problem, but I don't remember installing any drivers. I think I should remove the nVidia drivers from my onboard GPU and see what happens from there...
All info can be found here: http://www.techpowerup.com/forums/showthread.php?t=92202
5,226 (0.82/day)
Software Win 11 Pro
Did you just get that 4870?
If you installed it without removing the Nvidia Display drivers I could see you having problems but it would be long before shutting down. Here some steps I'd recommend when removing drivers.
Uninstall through Normal Mode
Reboot into Safe Mode
Once in Safe Mode run Driver Sweeper and check the intended driver('s) your wanting to remove
Once they are clean restart back into Normal mode
Bokteelo
479 (0.08/day)
I've had the 4830 for like a month now, and everything was fine until I reset the CMOS. I figured out why my monitor wouldn't respond on startup, because my primary video adapter was set to PCI and not PCI-E. (Or that's what I think it is, computer can restart fine now, but I still get the BSOD.)
5,226 (0.82/day)
Software Win 11 Pro
Bokteelo
479 (0.08/day)
If your board has onboard GPU then when the CMOS reset, onboard GPU could have enabled since alot of boards will do that by default.
GPU-Z reads my GPU as the 4800 series. I went into the BIOS and set the adapter to PCI-E. I think that fixed any problems that might've occured. Still, I'll uninstall the drivers.
Edit: Okay BAD idea. I removed ALL nVidia drivers including the ethernet drivers, and I couldn't go online. I had to run a system restore to the 22nd.
5,226 (0.82/day)
Software Win 11 Pro
When removing drivers off of a nvidia equiped motherboard you can select which driver to remove instead of removing all of them.
Bokteelo
479 (0.08/day)
Thanks, I did a rollback and it no longer gives me the option of selecting what to remove. It only says that it will remove the Ethernet drivers and everything connected to it, so I just denied. I'm going to remove all ATi drivers now and reinstall them.
