Thank you. I didn't want to touch the optical output because I like dtsi + ddl, they both work properly in 5.1 channel and the receiver recognizes both formats as well .. I put dtsx and dts digital entertainment only on the analog which is enough for me, the sound is good on headphones as well as speakers. CheersVery noooice, well done!
Well done job. I was able to test other audio plugins on Windows 11 these days to see how it would work with the new OS and my conclusion is impressive, I didn't find any major problems and bugs and most of them work maybe a little better than on Windows 10, everything worked like butter..As for the double apo's you mentioned above I followed the trail to see if there were any conflicts between them or any errors in the work and I didn't find any errors, everything works perfectly. Maybe because I use them independently not at the same time. Thanks again for this fantastic work !!
System Name | It's just a computer |
Processor | i9-14900K Direct Die |
Motherboard | MSI Z790 ACE MAX |
Cooling | 2X D5T Vario, XSPC BayRes, 2X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD |
Memory | TEAMGROUP FFXD548G8000HC38EDC01 |
Video Card(s) | MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724 |
Storage | Samsung 990 PRO 1TB M.2 |
Display(s) | LG 32GK650F |
Case | Thermaltake Xaser VI |
Audio Device(s) | Auzentech X-Meridian 7.1 2G/Z-5500 |
Power Supply | Seasonic Prime PX-1300 |
Mouse | Logitech |
Keyboard | Logitech |
Software | Win11PRO |
Mouse | Logitech |
Mouse | Logitech |
Mouse | Logitech |
Good chance it wont work, I will have to get back to you on that one. If you want to try anyhow, make backups with FX config.
The DTS:X (APO4) system has more features than the previous versions of DTS APO's (1, 2, 3), it no longer uses virtual, or expand, but instead spatial.So, what advantage does DTS:X offer over DTS NEO and DTS Interactive that I am currently using; Digital coax connection to Z-5500?
DTS Interactive with DTS X Ultra is current crême de la fap.@snaker1, I had issues when Windows dropped support for my X-Fi, I imagine this is some of the reason. You should start you own thread for this X-Fi issue, many people have it working.
@Arctucas, you should be able to get this package to work if you had a HDAUDIO device on the system, such as in the guide, else no, I am sorry.
It also acts as a DSP, as well as an APO. The audio quality is far better than pervious APOs from DTS, mostly due to better technology.
The DTS:X Ultra system works on-with PCM, so even DTS Interactive is improved, without any additional hardware.
