OleksiiTech
- Jan 5, 2025
- 10 (1.67/day)
I want to run Dual GPU system, where My main GPU is RX 7600 XT 16GB, and another is 470 8GB. After using DDU, I boot in windows. Before Windows manages to install something by itself, I quickly rush to Auto-detec AMD's utility. https://www.amd.com/en/support/download/drivers.html It works great, detect both GPUs, install drivers successfully. Device manager after driver installation says it's fine, no errors. Moreover, GPUs work as they should and how I wanted them to. Problem: Black screen after reboot, I hear windows boot sound but can't enter system. Can fix this only by unplugging 470 from PC. All displays are connected to RX 7600 XT. Also, I previously used RX 550 2GB on a place of 470 8GB and it worked fine with two different drivers just like in this case. Motherboard is Asrock B550M Pro4.
Goofy picture of build is included for your amusement. Sorry if question is silly.
