#dualSPEC-X
192 (0.05/day)
System Name #projectEVO v4
Processor AMD R9 3950X
Motherboard ASUS X570 Crosshair Impact
Cooling EK Supremacy EVO CPU, Alphacool Monsta 240, Alphacool UT60 360, Aquacomputer Aqauero 6X
Memory GSkills Trident Z Neo 32GB DDR4 CL16 @3600MHz
Storage Samsung 970 500GB NVME M.2, Seagate 4TB 7200rpm HDD (x2)
Display(s) Samsung G9 Odyssey 49" Ultrawide @240hz | ASUS MG279Q 1440P @144hz | HTC VIVE
Case CaseLabs Mercury S5
Audio Device(s) Marantz PM7000N | Schitt Stack UBER | Beyerdynamic DT1990 | Sennheiser HD6XX | HiFi Man HE4XX
Power Supply EVGA 1600 Watt T2
Mouse HyperX Haste, Logi GroX Superlight, Logi GPro Wireless, Razer Viper Ultimate
Keyboard Drop ALT , HHKB Pro 2, RealForce Topre 104UB, Topre Realforce RGB
Software Windows 10 PRO
Specs:
Case: CaseLabs Bullet BH8Motherboard: ASUS Z370 Maximus X HeroCPU: Intel i7 8700K 6 CoreGPU 01: AMD VEGA 64 8GB HBMGPU 02: AMD VEGA 64 8GB HBMRAM: Corsair Dominator 16GB DDR4 3200mhzSSD: Samsung 860 NVME 250GB mounted in an Aquacomputer kryoM.2 EVO PCIESSD: Samsung 850 250 GBHDD: Seagate 4TB PSU: EVGA 1600 Watt T2 PSU Cables: Ensourced Custom CablesCPU Block: EK Supremacy EVO Pump + Reservoir: EK-SBAY DDC 3.2 PWMGPU Block: EK VEGA64 (x2)Radiator: Alphacool XT45 240mmRadiator: Alphacool ST30 240MMRadiator: Alphacool ST30 240MMFittings: BitspowerFittings: Primo Chill RevolverSXFan: Nidec Servo Gentle Typhoon 2150RPM PWM 120MM (x6)Fan: Noctua NF-R8 1800RPM PWM 80mm (x2)Fan Controller: Aquacomputer Aquaero LT 6
Mods:
Copper TubingModify front radiator support to accommodate Aquaero 6 LT
New Year, new build! This was my quest to build the most compact dual GPU ATX HTPC Gaming machine in a CaseLabs BH8 44 liter beast. Let's call this an HT(G)PC overkill build targeting 4K 60FPS+. This is my second CaseLabs chassis after a Mercury S5 with copper tubing (#projectEVO), figured I invested in copper tubing hardware and materials in that build it would be a good opportunity to run with it here. The goal was to make this somewhat portable and standby in my home theater setup.
dgianstefani
TPU Proofreader
4,859 (1.98/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Motherboard ASUS ROG Strix X670E-I, chipset fans removed
Cooling Optimus Block, HWLABS Copper 240/40 + 240/30, D5/Res, 4x Noctua A12x25, 2x A4x10, Mayhems Ultra Pure
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front panel pump/res combo
Audio Device(s) Audeze Maxwell Ultraviolet, Razer Nommo Pro
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper Pro V2 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Keyboard Wooting 60HE+, TOFU-R CNC Alu/Brass, SS Prismcaps W, Jellykey, Lube/Mod, TLabs Leath/Suede Wristrest
Software Windows 10 IoT Enterprise LTSC 19044.4046
Benchmark Scores Legendary
It's very nice, and I think the copper tubing is great.
I just can't understand why you would use Vega 64 over a 1080 or 1080ti.
