DVI-D to DVI-I adapter
177 (0.05/day)
Quick question:
My mobo is a msi gaming 5 z97 and has a DVI-I port for integrated graphics. I just sold my graphics card so I intend to use my on board graphics for a few weeks before I receive my new card.
Problem is: my monitor doesn't support anything but dvi-d. Which means when I hook up my dvi-d cable to my mobo and monitor I get no image.
Do you think that I could use a dvi-d to DVI-I adapter to get an image??
4,373 (0.95/day)
St. Paul, MN
System Name Bay2- Lowerbay/ HP 3770/T3500-2+T3500-3+T3500-4/ Opti-Con/Orange/White/Grey
Processor i3 2120's/ i7 3770/ x5670's/ i5 2400/Ryzen 2700/Ryzen 2700/R7 3700x
Motherboard HP UltraSlim's/ HP mid size/ Dell T3500 workstation's/ Dell 390/B450 AorusM/B450 AorusM/B550 AorusM
Cooling All stock coolers/Grey has an H-60
Memory 2GB/ 4GB/ 12 GB 3 chan/ 4GB sammy/T-Force 16GB 3200/XPG 16GB 3000/Ballistic 3600 16GB
Video Card(s) HD2000's/ HD 2000/ 1 MSI GT710,2x MSI R7 240's/ HD4000/ Red Dragon 580/Sapphire 580/Sapphire 580
Storage ?HDD's/ 500 GB-er's/ 500 GB/2.5 Samsung 500GB HDD+WD Black 1TB/ WD Black 500GB M.2/Corsair MP600 M.2
Display(s) 1920x1080/ ViewSonic VX24568 between the rest/1080p TV-Grey
Case HP 8200 UltraSlim's/ HP 8200 mid tower/Dell T3500's/ Dell 390/SilverStone Kublai KL06/NZXT H510 W x2
Audio Device(s) Sonic Master/ onboard's/ Beeper's!
Power Supply 19.5 volt bricks/ Dell PSU/ 525W sumptin/ same/Seasonic 750 80+Gold/EVGA 500 80+/Antec 650 80+Gold
Mouse cheap GigaWire930, CMStorm Havoc + Logitech M510 wireless/iGear usb x2/MX 900 wireless kit 4 Grey
Keyboard Dynex, 2 no name, SYX and a Logitech. All full sized and USB. MX900 kit for Grey
Software Mint 18 Sylvia/ Opti-Con Mint KDE/ T3500's on Kubuntu/HP 3770 is Win 10/Win 10 Pro/Win 10 Pro/Win10
Benchmark Scores World Community Grid is my benchmark!!
http://www.amazon.com/dp/B005EJQYZ2/?tag=tec06d-20
Next question.
:D
748 (0.18/day)
Oceania
Yes if the GPU has DVI it will be fine. Unless really old most cards are either dvi-i or dvi-d, not dvi-a.
Wait u get no signal with dvi-d, the port must be analogue then...what board do you have? You got on-board video enabled?
4,373 (0.95/day)
St. Paul, MN
Did you read the OP?
newtekie1
Semi-Retired Folder
28,473 (4.10/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
You do not need an adapter to use DVI-D with a DVI-I port. DVI-I is a DVI-D port that just had extra pins to carry a VGA signal as well.
2,707 (0.75/day)
On The Highway To Hell \m/
WTF are you smokin'? Excuse me...poppin'?
4,373 (0.95/day)
St. Paul, MN
748 (0.18/day)
Oceania
177 (0.05/day)
Ok let'S clarify things up a little:
I have an MSI GAMING 5 z97 motherboard with an i5 4690k cpu with NO GRAPHICS card atm because I just sold mine (quicker then expected) therefore whilst I wait for a new video card, I must use ON BOARD graphics.
Here is what I need to figure out: I have a Yamaksi Catleap Monitor. It ONLY has a korean dvi input. I'm 99% certain it'S dvi-d. As for my motherboard on board graphics, I'm guessing I should be getting an image but no I'm not getting any. Here is a list of my back panel ports:
- 1 x PS/2 keyboard/ mouse combo port
- 1 x LAN (RJ45) port
- 4 x USB 2.0 ports
- 4 x USB 3.0 ports
- 1 x VGA connector
- 1 x DVI-D connector
- 6 x OFC audio jacks
- 1 x HDMI port, supporting a maximum resolution of 4096X2304@24Hz/ 2560X1600@60Hz/ 3840X2160@60Hz/1920X1200@60Hz
As you can see, I have a dvi-d port there. Now for the sake of the argument, let's imagine that I somehow have my ON-BOARD graphics DISABLED. How would I turn them back on if I can't see what I'm doing lol?
(p.s. am I right in assuming most PC monitors have a DVI-I input? or is it DVI-A?....... cause I know the catleap monitor I have is supposed to come from Korea where they use an uncommon dvi connexion... which I can confirm to be dvi-d)
Aquinus
Resident Wat-man
13,171 (2.81/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
It should default to the iGPU when no discrete card is detected unless the BIOS is setup to force iGPU init first. DVI-D is fine. The only time you need DVI-I/A is when you plan on using an old school VGA monitor. Otherwise, it really doesn't matter.
177 (0.05/day)
I have a feeling I went into my bios (long ago) and disabled ON-board graphics. Is there a way to revert to bios defaults manully (Without needing to see what's going on on the monitor) ?
4,373 (0.95/day)
St. Paul, MN
I may be WAY OFF here but, I thought, once the PCI-e slot is vacated, on-board graphics would run automatically, I have an older board here and the on-board d-sub cable and DVI from the GPU both work at the same time. I can plug them both in, and then switch from one to the other, via my monitor's input menu.
IDK, I know some people turn it off on the Haswell's to save heat? Or whatever. So, yea, could be a bit screwed without a loaner/donor/paperweight GPU around to turn it all back on.
:confused:
newtekie1
Semi-Retired Folder
28,473 (4.10/day)
Indiana, USA
Yes, there should be a reset cmos jumper on your motherboard. Use that, or just pop the battery out for 10 seconds and put it back in. Do this with the power to the PC diconnected.
Also, the Intel graphics might not support your monitor.
It works like that if it is set to auto, but on some boards if you manually set it to disable it won't automatically come on.
2,707 (0.75/day)
If he connects a DVI-D cable to a DVI-I port and gets no signal, the port must be analogue What part of that isn't logical?
Ohhh...just the parts where you assume that connecting a DVI-D cable to a DVI-A port is even possible. And/or that DVI-I doesn't combine digital and analog signals in the same connector. Stuff like that.
4,373 (0.95/day)
St. Paul, MN
Um...about that BIOS...Don't think it is possible to Blindly go through that monster. Good Luck!
About CMOS, I was just reading in another Forum, MSI did not ship a CMOS Jumper with the board.
So, like was said above, unplug, remove battery, have some toast and maybe a beer. Put battrery back in and plug it in, Should work.
We are talking MSI...:p
177 (0.05/day)
Quick question about hard resetting the bios:
Let's imagine I hard reset the bios (which would set on board graphics back to enabled or auto) would this procedure make me lose the Bios OC profiles I had created???
748 (0.18/day)
Oceania
There, fixed them both for you, hint: scroll up.
:p
Also, he asked for an adapter. I assumed he had a DVI cable. So, perhaps he has a DVI-D cable...
Yes and I didn't read the tthe post
What do you mean? I'm highly insulted, it makes perfect sense to me...?
Dude, I was referring to the port on the monitor....as he was using a DVi-I port on the card..;) Albeit I am assuming.
289 (0.04/day)
vt
System Name Money Guilt / immortal X58
Processor 5600X / X5660
Motherboard MSI B550 GAMING PLUS / MSI-x58-PLAT
Cooling Cooler Master - Hyper 212 / Monsoon 3 Dual 120 fans
Memory OLOy WarHawk 2x8 / 2x4 gig Gskill 1600
Video Card(s) EVGA 3060 Ti FTW3 / R9 290 Powercolor PCS+
Storage Crucial P5 1TB / 128gig Samsung D830 2x1 Terabyte Seagates Raid0
Display(s) VIOTEK 32-In 2560x1440 Curved 144Hz / Acer 22in 1920x1080 120Hertz
Case NZXT - H510 Compact / Thermaltake V9 Black Edition
Audio Device(s) Soundblaster Audigy FX
Power Supply CORSAIR - RM Series 750W / Ocz 700 Modular
Mouse G403 / basic
Keyboard G15 / basic
Benchmark Scores http://www.3dmark.com/spy/18067733, http://www.3dmark.com/fs/24836348 http://www.3dmark.com/fs/11606
I have not looked into those higher resolution monitors in a long time, but the last time i looked they needed a video card of certain requirements. I think you will need a different monitor. I have not looked into this, again this was last year when i looking to get one of that brand Yamaksi Catleap Monitor. Cannot use on-board or APU graphics chipset.
177 (0.05/day)
Oh... Yeah that would totally make sense. I think I'm just gonna buy a PC monitor at the local best buy and hook it up with Hdmi on board and just refund the said monitor once I buy my new card.
I'm waiting for the other non reference gtx 980ti models to come out
748 (0.18/day)
Oceania
@OP please disregard anything I said above , I'm doing about 8 things at once atm and not paying attention...or reading posts properly.. :)
This is what happens when I attempt multitasking...:p Sorry....
newtekie1
Semi-Retired Folder
28,473 (4.10/day)
Indiana, USA
DVI-I is both analog and digital, it can not be just analog. If it was just analog it would be a DVI-A port, that is why DVI-A exists.
A DVI-D monitor will work just fine with a DVI-I port.
Do you have an HDTV in the house? Just connect the HDMI on the computer to a TV and use the TV as a monitor until you get the new card.
However, that still may not work since some of the Catleap monitors don't work with Intel graphics. Some of the generic Korean monitors don't have a scaler board, so the GPU has to have a scaler, which the Intel GPU doesn't have.
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.46/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
Maybe you need one of these?
http://www.amazon.com/dp/B000NWIQLU/?tag=tec06d-20
It's an adapter that removes the analog pins:
You screw in a DVI-I cable to the DVI-I end and screw the DVI-D end into the DVI-D jack on the monitor.
Alternatively, just use a DVI-D (both ends) cable.
Install a graphics card, plug the monitor into the graphics card, go into BIOS, turn integrated video back on, turn off computer, remove graphics card, plug monitor into onboard, turn computer on.
748 (0.18/day)
Oceania
I know that, however I missed the "DVI-D monitor" part....I read DVI-I cable and assumed the monitor as A input since it was working with DVI-I... Afterward I noticed it was DVI-D only.
That's why I said disregard my comments. :)
