EAC (Easy Anti Cheat) detects cheat in Lost Ark
M3TALH3AD
10 (0.01/day)
The latest version of NvCleanStall cannot be used with Lost Ark as it detects a cheat with the nvidia driver.
The game crashes after an "EAC Detected" popup occurs and will not let you play the game.
Reverting back to the stock nvidia gpu driver 511.79 vs the tweaked telemetry disabled nvcleanstall version worked. This happens in Win10 and Win11.
Please have someone look into testing this with games that use easy anti cheat.
2,995 (2.04/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
i stopped using NVCleanstall half a year ago.
it does nothing at best...
8,226 (2.13/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
try reporting this to EAC to see if telemetry is really needed. This is the first I've heard about it, I played other games with EAC and never had a problem with telemetry disabled. However I dont recall if it was actually disabled for blocked internet access to it.
W1zzard
Administrator
28,179 (3.72/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
You have to select the "use method compatible with EAC" checkbox on the tweaks page, i've been playing lost ark just fine
3,811 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
It gives you the new control panel on LTSC without the store. :)
456 (0.41/day)
Ah, I'm sure all the entrepreneurs using LTSC for their business care about NVIDIA's control panel. Oh, what do you mean you don't run a business?
3,811 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
I do work on my desktop actually, it is possible to use one machine for both,
456 (0.41/day)
If you have an actual use case for LTSC, that's cool. My point is that most people don't and they use the (most of the time pirated) LTSC version of Windows for either placebo or no performance gain at all
3,811 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
I don't use it for performance reasons, I could achieve the same by stripping down consumer windows (if there is an advantage), the decision was to escape feature updates as they are disruptive and risk breaking stuff.
animepfpsRidi0t
1 (0.00/day)
I've registered only to reply you. LTSC is way more responsive in terms of general usage and without the bloat that constantly runs in the background, yeah one can tweak it by stripping down Win10Pro but why do the hard work when you literally have the same sheet on your hand. LTSC 2021 is a godsend, using pirate Windows did no harm to anyone (except 1%) since forever. Your opinion is therefore invalid. Further discussions about this topic will not be checked by me.
Your further comment aiding to almost no particular problem with a ridiculously sarcastic tone is really worth noting. One can use a whole software for sole purpose of one thing and it does not concern you.
Keep in mind that it is as easy as writing down "wsreset" on a powershell to get the Store up and working on LTSC'21 if you want store as well. I was really surprised when I found out.
Have a good day.
321 (0.15/day)
no it isn't.
456 (0.41/day)
No it isn't, but okay. Sure, don't check further replies because you have no way to prove it genuinely matters on any device that isn't ancient by today's standards. None of these devices care about Windows' """bloat""" - it has been tested again and again. Tweaking the OS does nothing. You people are high on placebo.
Judging by your name though, I can say the same about you in that nothing you say matters. Have a good day, hope to never see you in this forum again, since you're not welcome.
Yeah, there is none.
Never had a problem with them being an insider constantly since October 2014 but fair enough.
This is my last reply on this matter since we're just derailing this thread massively at this point...
21,732 (3.40/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 64GB (2x 32GB) G.Skill Flare X5 @ DDR5-6200 CL30
Case Thermaltake Core X31
No it's not. We don't allow discussion of piracy here. End of story.
Whether or not every LTSC version used is indeed pirated is trickier, but make no mistake: Piracy is not an "OK" topic here.
196 (0.03/day)
Mexico
System Name HTPC
Processor AMD Ryzen 7 5800X
Cooling BeQuiet Dark Rock Pro 4
Memory Kingston Fury Renegade RGB 32GB Kit (2x16GB) 3600Mhz DDR4 CL16
Video Card(s) Sapphire NITRO+ RX 5700 XT
Storage Acer Predator GM7000 4TB / WD Blue SN570 1TB / TOSHIBA HDWD130 3TB
Display(s) LG Oled 42C3
Case Lian Li O11 Air Mini
Audio Device(s) Creative Labs Sound BlasterX G6
Power Supply EVGA SuperNOVA 850 P2
Mouse Logitech G900
Keyboard SteelSeries Apex Pro
Software Microsoft Windows 11 Pro
piracy?, what is that?, never heard of it :confused:
EAC works fine on my wife machine running Lost Ark (using clean install)
