Easy LED Lighting Tutorial
BigJunit
117 (0.02/day)
UK - Avon
Processor AMD Athlon 64 X2 5200+ @ 3.2Ghz
Motherboard Asus CROSSHAIR nForce 590 SLi
Cooling Custom Watercooled 1/2' Loop (CPU & GPU)
Memory OCZ 2GB PC2-6400C4 Platinum Revision 2 XTC Series DDR2
Video Card(s) Nvida BFG Geforce 8800GTS OC2 320mb
Storage 320gb Seagate SataII & 400gb Freecom External
Display(s) HP 22' Widescreen DVI 1650x1050
Case Asus Custom
Audio Device(s) Asus (5.1 came with board)
Power Supply Jeantech 600w Modular
Software Windows XP Pro
Thought I would post a quick guide to an alternative to using cathode tubes in your cases for lighting following a coulple of replys to my case in the case gallery.All the links are to English stores, but Im sure alternatives can be found in any country with a quick google search.
-Shopping List-
2 x 5mm 3.5v LEDs (I will be using super-bright blue)
2 x Suitable Resistors - 12 Volt or 5 Volt
2 x lengths of Wire (I am using solid core bell wire, black & Blue)
1 x Housing box - Maplins code JX56L is a good one to use
20cm heatshrink - Here
2 x 5mm LED holders - (I am using Maplins code N89AX as needed black)
1 metre of aquarium air hose (or cable braiding or your choice)
-Tools-
Wire Cutters
Needle Nose Pliers
Corded/less Drill - 3mm, 8mm & 9mm Bits
Ruler
Pen
Masking Tape
Ok thats everything you will need to make 1 lighting unit housing 2 x LEDs. This would be enough to illuminate a third of an average size case to the brighness of a cathode tube.
1st Step -
Mask the box you have chosen as the housing, measure and mark where each LED will sit. Drill a 3mm pilot hole then enlarge to 9mm.
Repeat this on the rear of the housing but enlarge to 8mm.
Remove masking tape
2nd Step -
Take the LEDs, heatshrink, resistors and LED holders
Join the resistor to the longest wire on the LED and apply heatshrink, repeat with second LED and Resistor.
Now join one wire to the resistor and another wire to the shortest wire on the LED, again apply heatshrink. I used back and blue so its easy to see which wire is positive (blue) and which is negitive (black).
3rd Step -
Now moving back to the LED housing, insert LED holders into the 9mm holes (if using different holders check mounting hole size)
Once inserted tighten the small nut to hold them securly in place.
4th Step -
Next twist the 2 wires together for neatness. As I am using solid core wire this is very easy and the wires stay together and keep thier shape very well.
5th Step -
With the LED holders in place and the wires twistes together, insert the LEDs through the rear 8mm hole on the housing and into the holders. Most LED holders will come with a small plastic plug to hold the LED inside the holder. I did not use this as I prefer to use a very small amount of superglue around the rim of the LED.
6th Step -
Thread the wires through the aqurium hose (or your choice of braiding) so that the end of the hose is inside the housing.
7th Step -
Screw the housing cover into place using the screws provided and the unit is complete, simple ehh.
Now all thats left is to instal it into your case using the mounting holes on the housng plate and connect the wires to your chosen power supply.
Here are a few pictures of the LEDs connected up. I think you will agree they go give a very nice effect for such a small price - £4.20 approx.
I have made 4 of these in total and they illuminate my whole case, but most importantly they allow you to only illuminate the areas of the case you want.
Hope some of you find this post useful, I know there are similar versions of this availible to buy, but its always nice to make something yourself for half the price you could have brought it for.
I personally think they look much better aswel.
Anyway it would be nice to know if anyone has had a bash at this and how they have turned out.
Thanks For Reading
-Product Links-
Heatshrink
5mmLED Holder
Blue 5mm LED
5v Resistor
12v Resistor
Zero Cool
1,197 (0.18/day)
Prague, CZ
Processor AMD Athlon 64 X2 4600+ Manchester BOX, 939 OC @ 2.7
Motherboard DFI LanParty UT NF4 SLI-DR Expert - nForce4 SLI
Cooling 3D Galaxy II, Gigabyte CPU idle below 35C
Memory 2x 1GB KINGSTON DDR Dual Channel
Video Card(s) EN7900GTX EXTREME EDITION 2DHT 512MB
Storage Seagate 200GB 7200rpm
Display(s) ASUS MW221 < 22" WideScreen / 1680x1050
Case Sunbeam Samurai Gaming Case, Half broken by mum
Audio Device(s) Intergrated within the Mother Board 7.1 surround sound
Power Supply Chieftec 500W MODEL: CFT-5000-A12S
Software Windows Vista Ultimate
oh I will buy the requirments tomorow and try it asap :) great work keep it up!
randomperson21
1,531 (0.22/day)
San Luis Obispo, CA
Processor AMD Athlon64 X2 3800+ @ 2.4Ghz
Motherboard ECS NForce4 A-939
Cooling CPU: Zalman CNPS7000B-AlCu GFX: Zalman VF-700AlCu, 2x120mm+5x80mm w/ Ultra 7ch Fan Controller
Memory Kingston 2x512MB DDR PC3200 Dual Channel 3-3-3-8
Video Card(s) EVGA Nvidia 7900GT KO Superclocked
Storage 2xSeagate Barracuda 7200.8/9 160GB SATAII NCQ in RAID0: 300GB total capacity
Display(s) Samsung SyncMaster 941BW (19" widescreen, 1440x900)
Case Antec P180B
Audio Device(s) Built in. 5.1Ch Logitech Z-5500 500w soundsystem, digital Coax connection
Power Supply Spire 500W
woah, thats slick. might make a few meself.
PuMA
724 (0.11/day)
Finland
Processor lapped C2D e6850, 3600mhz
Motherboard ASUS P5N32-E SLI (680i SLI)
Cooling NOCTUA NH-U9, 3 2x120mm 1x180mm case fans
Memory 6GB A-DATA vitesta DDR2 900mhz (2x1gb + 2x2gb)
Video Card(s) LEASTEK GTX 260 (701/1408/1105)
Storage SAMSUNG F1 640GB SATAII/SEAGATE 250gb SATAII
Display(s) SAMSUNG 226BW 1680x1050 2ms
Case ANTEC three hundred
Audio Device(s) ASUS SupremeFX, SONY surround AMP
Power Supply XION 630W
Software VISTA ULTIMATE x64
Benchmark Scores 3dmark06:15126 (701/1408/1105) vantage: 11698
yay, I'll try that out, since I dont have a flashlight and my PC is in a dark place lol
2,481 (0.35/day)
Very nice tutorial.
Seems pretty easy so I might give it a go.
By the way can you post pics with these in your system.
Would be interested what it looks like and where you put them.
Thanks
1,052 (0.14/day)
Ards
System Name Jezebelle
Processor i5 4690K
Motherboard MSI Z97M-G43
Cooling Noctua NH-U12
Memory 2x8GB Ballistix Sport
Video Card(s) GTX 1070 Ti
Storage Sandisk Ultra II 480GB, Sammy 1TB F3
Display(s) BenQ Xl2411Z
Case Fractal Define Mini
Audio Device(s) Onboard Realtek 7.1 HD, does the job!
Power Supply Enermax Infiniti 720W
Keyboard Logitech G15
Software Winblows 10 Pro
They rock! Can u get UV led's like that? Also, I hear that mounting them one in either end of a glue stick from a glue gun is meant to be a nice way to diffuse the light :D
BigJunit
117 (0.02/day)
UK - Avon
Case Asus Custom
@ Bruins004 - Below is one mounted so it lights the motherboard and graphics card. The whole case can be seen Here
Mine are hooked up to the PSU via the 5volt power rail (red and black wires from molex connectors) but 12v can be used with the correct resistor.
@ rythemiester - Any LED will work with this method, flashing UV etc
3,558 (0.52/day)
Enschede, The Netherlands
System Name Lian Li Carbon fiber ed.
Processor Intel i5 2500k 4.6Ghz 24/7 Max OC 5Ghz
Motherboard Asrock Z68 Extreme3 Gen3
Cooling Swiftech blocks, 360 Xflow rad, Swiftech 120 rad, Liang with XSPC res/pump top.
Memory 8Gb Mushkin 1600Mhz 8-9-8-24
Video Card(s) Sapphire HD6950 2Gb
Storage OCZ Vertex 4 128 / Western Digital 160
Display(s) ASUS 25,5" wide VW266h
Power Supply Corsair HX620 modular
Software Windows 7 64
Nice one man. I will try it this weekend. :toast:
Zero Cool
1,197 (0.18/day)
Prague, CZ
is ur GFX is 16x slot?
BigJunit
117 (0.02/day)
UK - Avon
Case Asus Custom
Yes Zero Cool, although I have moved it to the other 16x slot since the picture was taken (both PCI slots are 16x on that motherboard)
J0N
448 (0.07/day)
England
Processor Celeron M 1.50Ghz
Memory 512mb DDR
Video Card(s) 128mb Intel
Storage 60Gb
Display(s) 15" Widescreen
Audio Device(s) Korg 1212i/o - Needs A Home...
Software Windows Xp SP2
Nice tutorial dude! Good effort! :toast:
2,481 (0.35/day)
It looks really nice :)
Esp. with the watercooling kit in your case.
I am still a little confused though.
I am new to mods and customization so please bear with me.
First off, besides buying the different resistor what is the difference between the 12V and 5V rails (I know it hits a different rail in the PSU, I more mean of how will it differ the directions).
Now computer components are all hooked up using Molex connectors.
I do not see a molex connector on the end of these so how does it hook up?
Sorry if the answer is right in front of me.
I am interested in making this my first mod and want to understand it obv.
Thanks again
BigJunit
117 (0.02/day)
UK - Avon
Case Asus Custom
Using either 12v or 5v will not make any difference to the light thats given off as the resistors will reduce the voltage to 3.3v either way. Thats the rated power needed to light to LEDS.
To join to the PSU with a molex all you would need to do is buy an 'empty' molex connector and join the two wires to it, then plug the molex into your PSU. That would be the easiest way to connect the power, but as you say its all about customizing. I ran one molex connector from the PSU and then split it about 8 ways to power various components in the case, lights, LCD & fans etc.
1,052 (0.14/day)
Ards
Processor i5 4690K
2,481 (0.35/day)
Awesome.
Thanks for all the help.
Now is there a specific order I must put the wires in the Molex?
Bc computer components usually have 4 wires (since they hit the 12V line) all in a specific order.
So where should I put the blue and black lines?
Your rock man :rockout:
BigJunit
117 (0.02/day)
UK - Avon
Case Asus Custom
take blue as positive and black as negative - line the blue up with either the red (5volt) or yellow (12volt) on the molex depending which you have chosen. The line the black up to the black on the molex next to the positive (red/yellow) you have chosen.
Hope that makes sence
2,481 (0.35/day)
Yea that does.
Excellent job and thanks for all your help.
I am prob. going to get the parts this weekend and put it together next week.
I am also going to get some UV sleeves to clean up the case a bit.
Hey if you ever have any other small mods like this please post here and let us know.
I am always looking for small mods like this to do.
