EK Announces ROG Strix Z790-I Mini-ITX Quantum Monoblock
47,300 (7.53/day)
EK, the premium PC liquid cooling gear manufacturer, is launching the EK-Quantum Momentum² Strix Z790-I Gaming D-RGB - Plexi, the latest Intel LGA 1700 socket-based monoblock. The new Quantum line monoblock is engineered specifically for the ASUS ROG STRIX Z790-I GAMING motherboard. The addressable D-RGB LED in this monoblock is compatible with ASUS Aura Sync RGB control, offering complete lighting customization for every single diode at any given time. This Momentum² monoblock is also EK-Matrix7 compatible and doesn't require removing the factory-mounted heatsink before installation.
This is a complete, all-in-one (CPU + motherboard) liquid cooling solution for 12th and 13th gen Intel Core processors, compatible with LGA 1700-socket ROG Strix ZZ90-I Gaming ITX motherboard. This water block directly cools the Intel 1700 socket-type CPU and the heatsink of the power regulation (MOSFET) module. It doesn't replace the stock heatsink but instead complements it. It connects with the preinstalled heatsink through thermal pads between them and cools the heatsink instead of directly cooling the VRM.
The main issue with mini-ITX boards' VRM is usually the lack of space to fit a larger heatsink. Even with high-quality VRM, small heatsinks have limited surfaces for thermal dissipation. During EK's testing phase, this monoblock lowered the temperature of the VRM by more than 20°C on an open test bench. Inside a case, and especially in a small form factor (SFF) case, where other components raise the ambient temperature, users can expect even more significant improvements in thermals when using this Momentum² monoblock.
The new monoblock uses the latest generation of EK Velocity² cooling engine to ensure the best possible CPU cooling without reducing the flow to other components. This water block directly cools the Alder Lake or Raptor Lake CPU, with the coolant passing over the monoblock parts that touch the factory-mounted heatsink, dissipating heat away. Liquid flows directly over all critical areas, providing enthusiasts with an excellent cooling solution for high and stable overclocks.
Like all other EK monoblocks, the EK-Quantum Momentum² ROG Strix Z790-I Gaming features a high-flow design and can be easily used in systems with weaker water pumps or operate at lower pump speed settings. This latest Quantum Momentum² monoblock also comes with sophisticated D-RGB (addressable) lighting with a total of 6 LEDs. They connect to the ROG Strix motherboard's standard 3-pin 5V D-RGB addressable header called the "Aura Gen2 header."This product is compatible with ASUS Aura Sync RGB control software. The arrow marking on the 3-pin D-RGB LED connector should be aligned with the +5V marking on the AURA Addressable Gen2 header.
The base of the monoblock is made of nickel-plated electrolytic copper, while the top part is made of quality cast acrylic material. The nickel-plated brass screw-in standoffs are pre-installed and allow for easy installation.
6,106 (2.87/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Mixed metal corrosion included as a free bonus.
6,106 (2.87/day)
Poland
826 (0.21/day)
Poland
System Name Proper
Processor 5900X + OC
Motherboard GB X570s Elite AX
Cooling WC Heatkiller 3.0 LT
Memory G.Skill 3600 CL16
Display(s) GB M32Q
Case Fractal Define R6 USB C
Mouse Log G502 X LS
Software Win10 Pro
Last incident has shown that what they say isn't always what they do.
How much of that is EK's fault and how much Asus's, we don't know. However, looking at the technology the block was made in (cut alloy base + soldered copper fins) I don't think EK made that one - wouldn't make sense with all those CNC machines they own.
Still, slapping their logo on a botched solution doesn't help them either and some blame lies with them.
8,339 (3.91/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
Until one of them accepts full fault, both companies are tarred and feathered for watercooling.
deu
493 (0.16/day)
System Name Bo-minator (my name is bo)
Processor AMD 3900X
Motherboard Gigabyte X570 AORUS MASTER
Memory G-SkiLL 2x8GB RAM 3600Mhz (CL16-16-16-16-36)
Video Card(s) ASUS STRIX 1080Ti OC
Storage Samsung EVO 850 1TB
Display(s) ACER XB271HU + DELL 2717D
Case Fractal Design Define R4
Audio Device(s) ASUS Xonar Essence STX
Power Supply Antec HCP 1000W
Mouse G403
Keyboard CM STORM Quick Fire Rapid
Software Windows 10 64-bit Pro
Benchmark Scores XX
Damn it could look sick with a custom ITX case fully optimized for the board, SFX and a 4080. too on water (hence the custom case potentially with a build-in radiator.)
186 (0.10/day)
System Name Donnager
Processor 13900KS, lapped and contact frame
Motherboard Asus Z790 Hero
Cooling Heatkiller IV CPU block, Heatkiller V GPU block, GTX 480mm radiator, D5 pump
Memory 32GB Kingston Fury 7200C38
Video Card(s) eVGA RTX 3080Ti FTW3
Storage Optane 380GB M.2 OS drive, M.2 2TB game drive
Display(s) Alienware 34" Ultrawide 120Hz 3440x1440
Case Fractal Meshify 2 XL
Audio Device(s) Outlaw RR2150 stereo receiver driving DIY kits, Schiit Asgard for Sennheiser HD6XX headphones
Power Supply Seasonic Prime 1000W
The proof of the performance will be VRM temps, but it strikes me as a little lazy to not replace the heat sinks completely and go with the block on the fets.
9,340 (5.28/day)
Louisiana
Keyboard G710+x3
Nickel + copper is fine, alu + copper is not.
Yeah nickel plating aluminum must of been a test that failed
826 (0.21/day)
Poland
System Name Proper
Display(s) GB M32Q
Mouse Log G502 X LS
Software Win10 Pro
Because anodised alloy worked back in the day, huh? :p
The theory was there, but there was one little detail - the anodising had to be 100% spotless which is impossible IRL.
