EK Expands Torque Series Fittings With a Genuine Gold Finish
1,519 (0.86/day)
It has been about two years since EK introduced Torque fittings to the market, and since then, their popularity has been exponentially increasing. These fittings became the go-to solution for many high-profile modders and enthusiasts. EK, the premium water cooling gear manufacturer, has promised to continue evolving and expanding its fitting lineup with new models and finishes. The latest addition to the Quantum Line fittings, named Gold, was just introduced. EK has expanded its fitting portfolio with 30 new products and more is yet to come since every single extender and new fitting will become available with the Gold plating. The entire lineup of fittings and adapters is made of CNC-machined brass and then treated with nickel-plating, followed by a second, genuine gold plating.
EK-Quantum Torque Gold HDC Fittings
EK-Quantum Torque HDC are hard-tube compression fittings designed for use with solid tubing such as Acrylic, PETG, and glass. They are available in three dimensions compatible with 12, 14, and 16 mm outer diameter hard tubing.
EK-Quantum Torque Gold STC Fittings
EK-Quantum Torque STC are soft-tube compression fittings compatible with PVC, EPDM, Norprene, silicone, or any other type of flexible tubing. They are available in three dimensions compatible with 10/13, 10/16, and 12/16 mm diameter (ID/OD) soft tubing.
EK-Quantum Torque Gold Rotary Angled Adapters
The EK-Quantum Torque rotary angled adapters have a cylindrical shape. They are made to be very sturdy with a tight revolvable joint to avoid flex, thanks to customers' feedback. Machined out of a solid piece of brass, they use G1/4" threads and have three variations - revolvable 90° adapter fitting, revolvable 45° adapter, and revolvable T adapter fitting with G1/4" threads that all serve a different purpose. The T adapter fitting can be used for setting up drain ports or for parallel connection between components.
EK-Quantum Torque Gold Static Extenders
They are commonly used to extend a G1/4" port from a block, radiator, or any other liquid-cooling component in order to ease the process of connecting to other components and having fewer bends or inaccessible fittings at tight places. Available in several different lengths, and in male-male, male-female, and female-female G1/4" port configurations.
EK-Quantum Torque Gold Rotary Extenders
Premium revolvable extender interconnects with male threads on both ends. Used for connecting two water cooling components. Available in male-male and male-female configurations.
EK-Quantum Torque Gold Plugs
Premium Quantum G1/4" plugs for closing the unused ports on your water cooling equipment. They come in several forms, one with an EK-Badge.
EK-Quantum Torque Gold Splitters
Simple cylinder-shaped adapter fitting with 3 (three) G1/4" Female threads. This product is useful for splitting or combining the liquid flow in your loop.
EK-Quantum Torque Gold Static FF Angled Adapters
These adapters allow the connection of two fittings, adapters, or extenders with male G1/4" threads to extend tubing possibilities in your water-cooled system. Often used to avoid bending tubes or make fewer bends by utilizing these adapters as an interconnect. They come in 45 and 90-degree angles.
EK-Quantum Torque Gold Rotary Offsets
Premium revolvable male+female threaded offset adapter fittings. Commonly used to distance or offset G1/4" ports in tight spaces or to perfectly align hard tubing to another port in order to have aesthetically pleasant parallel tubing. They come in 3, 7, and 14 mm in length.
EK-Quantum Torque Gold Micro Static Extenders
Just as regular static extenders, used to extend a port from a water cooling product, only in an even smaller diameter when the width of the extender really matters to clear an obstacle.
EK-Quantum Torque Gold Micro HDP 12
Push-in hard-tube fittings designed for use with 12 mm solid tubing such as Acrylic and PETG. They are stealthy and made to be as small as possible, and with NO added branding at all. They are engineered specifically for captive tubing - like runs between two GPU water blocks, or from a GPU to the distro plate.
Availability and Pricing
The EK-Quantum Torque Gold series fittings are made in Slovenia, Europe, and are available for pre-order through EK Webshop and Partner Reseller Network.
  • EK-Quantum Torque HDC 12 - Gold 11.40 €
  • EK-Quantum Torque HDC 14 - Gold 11.40 €
  • EK-Quantum Torque HDC 16 - Gold 12.40 €
  • EK-Quantum Torque STC 10/13 - Gold 11.40 €
  • EK-Quantum Torque STC 10/16 - Gold 11.40 €
  • EK-Quantum Torque STC 12/16 - Gold 12.40 €
  • EK-Quantum Torque Rotary 45° - Gold 15.90 €
  • EK-Quantum Torque Rotary 90° - Gold 15.90 €
  • EK-Quantum Torque Rotary T - Gold 15.90 €
  • EK-Quantum Torque Extender Static MF 7 - Gold 7.40 €
  • EK-Quantum Torque Extender Static MF 14 - Gold 8.40 €
  • EK-Quantum Torque Extender Static MF 28 - Gold 9.40 €
  • EK-Quantum Torque Extender Static MM 7 - Gold 7.40 €
  • EK-Quantum Torque Extender Static MM 14 - Gold 8.40 €
  • EK-Quantum Torque Extender Static MM 28 - Gold 9.40 €
  • EK-Quantum Torque Extender Static FF 14 - Gold 8.40 €
  • EK-Quantum Torque Extender Rotary MF 14 - Gold 11.90 €
  • EK-Quantum Torque Extender Rotary MM 14 - Gold 11.90 €
  • EK-Quantum Torque Plug w/Badge - Gold 8.40 €
  • EK-Quantum Torque Plug - Gold 8.40 €
  • EK-Quantum Torque Splitter 3F T - Gold 10.40 €
  • EK-Quantum Torque Static FF 45° - Gold 9.40 €
  • EK-Quantum Torque Static FF 90° - Gold 9.40 €
  • EK-Quantum Torque Rotary Offset 3 - Gold 15.90 €
  • EK-Quantum Torque Rotary Offset 7 - Gold 18.90 €
  • EK-Quantum Torque Rotary Offset 14 - Gold 19.90 €
  • EK-Quantum Torque Micro Extender Static MM 7 - Gold 6.40 €
  • EK-Quantum Torque Micro Extender Static MF 7 - Gold 5.90 €
  • EK-Quantum Torque Micro HDP 12 - Gold 7.40 €
  • EK-Quantum Torque Micro Plug - Gold 4.90 €
dgianstefani
TPU Proofreader
5,193 (2.01/day)
Swansea, Wales
System Name Silent/X1 Yoga
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front, LINKUP Ultra PCIe 4.0 x16 white
Benchmark Scores Legendary
14,196 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
309 (0.18/day)
A lot of big words for a very common plating type.
There's probably 5 other vendors making gold plated fittings.
1,890 (0.78/day)
Cusp Of Mania, FL
Processor Ryzen 9 3900X
Case NZXT H710
Keyboard HyperX Alloy Pro
Wearing out gold plated fittings? No thanks.
Seriously... why do it when the 'gold' coatings used on things like jewelry, metal home adornments, what have you look absolutely opulent but don't have the softness or durability drawbacks of real gold? The applications reach far and wide, reaching everything from handrails to critical internal chemical valve parts. PVD and DLC coatings are a fairly ubiquitous thing for products and parts made out of metal, as they greatly enhance the look and durability. Hell, what is wrong with brass all polished-up with a nice clear coating on it?
Like, go ham with the carbonized stuff, even. DLC coatings are expensive, but they look cool and the tech is cool. And they're actually good. Overkill for an LC fitting, but damn, the marketing that could go into that coating man! At least it makes some sense.
Listen... these things are PARTS. Fittings are PARTS. You do not plate them in gold. That's the last thing you want for anything that ever does anything but sit there. If you wish to color them, I say use a coating that actually gives them some serious durability, like literally everyone else. That's all. Putting gold on them doesn't make them better. Nobody will know if you don't tell them. They could straight up just be brass with a nice finish, look the same in-build, and be easier to handle as fittings. I'm sure the plating is only like 10K, so it probably has some durability to it. But it still just detracts from the durability of the fitting while adding nothing that can't be gotten without that downside. It's something to scratch and ruin for no good practical or aesthetic reason at all.
What I'm saying is... these basically exist for the 'wow, REAL gold!' factor and not much else. To me, anyway. I can't see buying them over plain brass unless it just HAS to be real gold, in your own mind. That's the only reason I can think of to buy this.
2,355 (0.46/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
Gold doesn't tarnish easy.
259 (0.14/day)
Non-tarnishing being of particular use in electrical reliability with small signal electrical connectors. For plumbing ... not so much.
