EK Launches Water Blocks for AORUS's Xtreme 3000 Series Graphics Cards
1,519 (0.84/day)
EK, is introducing a whole series of Vector² liquid cooling products for AORUS's Xtreme graphic cards. We made sure that powerful AORUS GeForce RTX 3080, 3080 Ti, and 3090 Xtreme cards get their Vector² water block with passive backplate, new synergistic active backplate, and other aesthetic pieces to customize your water-cooled 30-series AORUS GPU to your own desires. The EK-Quantum Vector² AORUS Xtreme RTX 3080/90 D-RGB is a complete liquid cooling solution that includes a new Vector² water block, black-anodized aluminium backplate, and mounting mechanism. Minimalistic straight lines dominate the new look of the next-gen water blocks.
The 3rd-generation Vector cooling engine combines the jet plate with a 3D machined Plexi insert to improve flow distribution and thermal performance. This new cooling engine is still based on an Open Split-Flow cooling engine design, which proved to be a superior solution for GPU water blocks. It is characterized by low hydraulic flow restriction, meaning it can be used with weaker water pumps or pumps running on low-speed settings and still achieve top performance. We went to great lengths to achieve a symmetrical flow domain by utilizing an internal bridge to secondary components. This was done to ensure the cooling of secondary components without sacrificing flow distribution over the GPU core.
All Vector² GPU water blocks use a thick 11 mm copper coldplate with an acetal terminal attached directly and a robust single O-ring top design. This simple construction provides confidence during customization and maintenance. Tactile magnetic covers conceal the terminal screws, which allows rotating the branding when the GPU is inverted in the case.
EK-Matrix7 Standard
EK-Matrix7 standardizes the dimensions of the products, including the port position and spacing, making liquid cooling loop assembly easier and more intuitive. All Vector² products feature full EK-Matrix7 compliance in every axis, ensuring ease of integration and alignment with all other EK-Matrix7 products. This brings perfect alignment of ports in both horizontal or vertical positions, meaning less time spent planning the loop and bending tubes while still having an epic build as the final product.
EK-Quantum Vector² Xtreme RTX 3080/90 ABP Set D-RGB
This ultimate cooling set consists of a high-performance GPU water block and the latest generation of Active Backplate cooling solutions as a single enclosure. The GPU backside cooling is now provided by a full-blown water block with its own copper cold plate and a full-length acrylic top. The connectivity is also taken to another level with the "Direct Link" terminals that implement a conventional 4-port layout that allows serial and parallel connections from adjacent or opposing sides of the block.
This is the ultimate combination of a Vector² water block, Active Backplate, and mounting mechanism, available in Nickel + Plexi It includes an EK-Quantum Vector² Xtreme RTX 3080/90 ABP Side Cover in the anodized-black finish. The side cover is placed between the GPU water block and active backplate to conceal the GPU PCB. This offer allows users to buy the ultimate all-around cooling set for their GPU, ensuring the best possible cooling and performance uplift.
The combination of the EK-Quantum Vector² Xtreme RTX 3080/90 water block, EK-Quantum Vector² Xtreme RTX 3080/90 Active Backplate, and the EK-Quantum Vector² Xtreme RTX 3080/90 ABP Side cover envelops the GPU from all sides.
EK-Quantum Vector² Backplate
Each Vector² water block now comes with a CNC-machined black-anodized backplate, but an alternative finish of the backplate is also available - Nickel. Captive nickel-plated mounting screws are included with these backplates to replace the original black screws. The backplate has a new L-shaped profile that touches the base of the water block and encloses the entire GPU while increasing the cooling surface resulting in even better performance. Performance is further improved by connecting to the water block, a far more efficient heat transfer solution.
Captive backplate screws make the installation process much easier, always ensuring the use of correct length and preventing any user error or second-guessing.
EK-Quantum Vector² Side Cover
This separate accessory allows you to replace the standard black part, which conceals the entire PCB, with an alternative finish - Nickel.
EK-Quantum Vector² Xtreme RTX 3080/90 ABP D-RGB
This upgrade kit includes all parts required to transform the EK-Quantum Vector² Xtreme RTX 3080/90 water block into an Active Backplate Set (ABP set). It is available in the Nickel + Plexi variant. It incorporates a unique D-RGB lighting and a black side cover. When upgraded with an active backplate, the entire enclosure stays fully EK-Matrix7 compliant on every axis, ensuring simple integration and alignment with all other EK-Matrix7 products.
These new Vector² Active Backplates feature a Direct Link flow solution - the first multiple block solution to implement a conventional 4-port terminal layout. This allows serial and parallel connections from adjacent or opposing sides of the block, which was made possible by adding a machined brass insert that, in a diagonal manner and directly, links the water block to the active backplate inside the acetal terminal. Direct Link proves invaluable when incorporating an ABP with a standard distribution plate or vertical GPU mount.
The base of the Active Backplate is CNC-machined out of nickel-plated electrolytic copper, while the top is CNC-machined out of glass-like cast acrylic. D-RGB LED lighting is deployed on the longest edge of the water block for improved uniformity and brightness. The PCB and diodes are concealed inside a clean aluminium extrusion. A black-anodized aluminium side cover is included with every active backplate to conceal the entire PCB and create a seamless enclosure.
Compatibility
EK-Quantum Vector² Xtreme RTX 3080/90 water blocks, backplates, and active backplates are compatible with Aorus Xtreme GeForce RTX 3080, 3080 Ti, and 3090 GPUs.
Availability and Pricing
The EK-Quantum Vector² Xtreme RTX series liquid cooling products are made in Slovenia, Europe, and are already available for pre-order through the EK Online Shop and Partner Reseller Network. They are expected to start shipping later in 2022.
  • EK-Quantum Vector² Xtreme RTX 3080/90 D-RGB - Nickel + Plexi | 239.90€
  • EK-Quantum Vector² Xtreme RTX 3080/90 ABP Set D-RGB - Nickel + Plexi | 389.90€
  • EK-Quantum Vector² Xtreme RTX 3080/90 ABP D-RGB - Nickel + Plexi | 189.90€
  • EK-Quantum Vector² Xtreme RTX 3080/90 Backplate - Nickel | 44.90€
  • EK-Quantum Vector² Xtreme RTX 3080/90 ABP Side Cover - Nickel | 19.90€
66 (0.05/day)
Belgium
Processor Intel Core Ultra 7 265K
Motherboard Gigabyte Z890 Aorus Master
Cooling Corsair Titan RX 360 with RX MAX fans
Memory Corsair Dominator Titanium DDR5-8000C38
Video Card(s) Intel Arc A770 16GB // Waiting for RTX5000
Storage WD Black SN850X 1TB // WD Black SN850X 2TB // WD Black SN770 2TB
Display(s) Samsung Odyssey G8 OLED
Case Corsair Frame 4000D
Power Supply Corsair HX1500i
Mouse Glorious Model D 2 Pro
Keyboard Corsair K65 Plus
And still no Radeon RX 6800/6900 block in their new Vector2 series...
311 (0.17/day)
Oh, it's the bankrupt company doing more of those $400 USD aftermarket coolers that nobody buys?
I sense next round of layoffs is not far away.
Leiesoldat
lazy gamer & woodworker
130 (0.10/day)
System Name Arda
Processor AMD Ryzen 5800X3D
Motherboard Gigabyte X570-I AORUS Pro WiFi
Cooling Custom Loop - Aquacomputer, Optimus, EK, Bykski
Memory GSkill Trident Z RGB 32 GB (2x16) DDR4-3200
Video Card(s) Gigabyte Gaming OC RX 6800XT
Storage SK Hynix P41 1TB
Display(s) VIOTEK 3440 x 1440 144 Hz Curved
Case XTIA Proto-XL
Audio Device(s) Schiit Modius + Schiit Jotunheim
Power Supply Seasonic Prime 850W Titanium
Mouse Xtrfy MZ1 Zy's Rail Wireless
Keyboard Rainkeebs Yasui - Custom 40% Ortholinear
Here's your problem EK. Stop releasing blocks for graphics cards that no one can buy. Where are the AMD blocks for AIB's? I had to go to Bykski (which has been great btw) for an almost unreleased block because that was the only graphics card I could get from Newegg during their lotteries.
ppn
1,231 (0.35/day)
later 2022 is the EOL date for the 3000 series, kind of defeats the purpose of having one. nobody is selling 980Ti WC blocks anymore for the same reason. it's obsolete.
135 (0.11/day)
USA
System Name Star Killer
Processor Intel 13700K
Motherboard ASUS RO STRIX Z790-H
Cooling Corsair 360mm H150 LCD Radiator
Memory 64GB Corsair Vengence DDR5 5600mhz
Video Card(s) MSI RTX 3080 12GB Gaming Trio
Storage 1TB Samsung 980 x 1 | 1TB Crucial Gen 4 SSD x 1 | 2TB Samsung 990 Pro x 1
Display(s) 32inch ASUS ROG STRIX 1440p 170hz WQHD x 1, 24inch ASUS 165hz 1080p x 1
Case Lian Li O11D White
Audio Device(s) Creative T100 Speakers , Razer Blackshark V2 Pro wireless
Power Supply EVGA 1000watt G6 Gold
Mouse Razer Viper V2 Wireless with dock
Keyboard ASUS ROG AZOTH
Software Windows 11 pro
Sorry but 3000 series is not "obsolete" by the end of this year. Not even close, people will be using the cards for 4+ years from now.
32 (0.03/day)
Thing is, I have one of these, a 3090 Xtreme, and have been complaining for ages that they never released an active backplate for it. Thank god they now have!
