- Oct 9, 2007
- 47,407 (7.52/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
EK Water Blocks, Ljubljana based premium liquid cooling gear manufacturer, is proud to introduce motherboard water cooling solution, this time for GIGABYTE X99 SOC Champion motherboard. The EK-FB KIT GA X99-SOC Champion is a complete water cooling solution for GIGABYTE X99 series motherboards consisting of two separate water blocks. Please check our Cooling Configurator online compatibility system for detailed compatibility list.
The water blocks directly cools Intel X99 southbridge (PCH) chip and power regulation (VRM / MOSFETs) module. Please note this water block cools exactly as much heat generating components as GIGABYTE factory cooling solution. It is a high flow water block that can be easily used with systems using weaker water pumps.
Base of the water block is made of nickel-plated electrolytic copper while the top is made of quality POM Acetal or acrylic glass material (depending on the variant). The screw-in standoffs are already pre-installed and allow for easy and trouble-free installation by utilizing original motherboard backplates. This water block kit is already available for purchase through EK Webshop and Partner Reseller Network.
Price (MSRP, including VAT): 114.95€
