EK Releases the EK-FC780 GTX Jetstream Full-Cover Water Block
4,784 (1.00/day)
Still on the East Side
EK Water Blocks, Ljubljana based premium water cooling gear manufacturer, is proud to introduce a new Full-Cover water block for Palit Super Jetstream-, Jetstream as well as Gainward Phantom series NVIDIA GeForce GTX 780 graphics cards - the EK-FC780 GTX Jetstream.
EK-FC780 GTX Jetstream water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas. This allows the graphics card and its VRM to remain stable under high overclocks. EK-FC780 GTX Jetstream water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
The top extends over entine lenght of the circuit board (except for the clear acrylic version) and features two pre-drilled slots for LED diodes (acrylic CSQ top versions only). Up to four EK-FC780 GTX Jetstream series water blocks can be interconnected with EK-FC Terminal or EK-FC Bridge & Link CSQ system - depending on the variant - which allows for hassle-free piping job.
The product comes in three different variants, an aesthetic retention backplate is also available:
  • EK-FC780 GTX DCII - Nickel - 102,95€
  • EK-FC770 GTX DCII - Acetal+Nickel - 104,95€
  • EK-FC770 GTX DCII - Nickel (Original CSQ) - 104,95€
  • EK-FC770 GTX DCII Backplate - Black - 26,38€
Products are readily available for purchase through EK Webshop and Partner Reseller Network.
