- Oct 9, 2007
- 47,235 (7.55/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
EK Water Blocks, the Slovenia-based premium computer liquid cooling gear manufacturer is proving its market leadership once again by releasing a new AM4 socket based monoblock tailor made for the MSI X370 XPOWER Gaming Titanium motherboard. The EK-FB MSI X370 XPower RGB Monoblock has an integrated 4-pin RGB LED strip which makes it compatible with MSI Mystic Light Sync, thus offering a full lighting customization experience.
This is a complete all-in-one (CPU and motherboard) liquid cooling solution for the new AMD X370 Chipset AM4 socket based MSI X370 XPOWER Gaming Titanium high-end motherboard that supports the latest generation of AMD Ryzen and 7th Generation A-series/Athlon processors.
Designed and engineered in cooperation with MSI, this monoblock uses award-winning EK-Supremacy EVO cooling engine to ensure best possible CPU cooling. This water block directly cools AMD AM4 socket type CPU, as well as the power regulation (MOSFET) module. Liquid flows directly over all critical areas, providing the enthusiasts with a great solution for high and stable overclocks. Like with every EK monoblock, EK-FB MSI X370 XPower RGB features high flow design and this monoblock can be easily used with the system using a weaker water pump as well.
This AM4 socket based monoblock also comes with a new redesigned cold plate. The new design ensures that the monoblock has better mechanical contact with the IHS of AMD AM4 socket based processors, thus enabling better thermal transfer.
The base of the monoblock is made of nickel-plated electrolytic copper while the top is made of quality acrylic glass material. The nickel plated brass screw-in standoffs are pre-installed and allow for easy installation.
The monoblock is equipped with a 4-pin RGB LED strip that connects to the motherboard's 4-pin LED header or it can be connected to any other 4-pin LED controller. The LED strip cover can easily be removed for adjusting the cable orientation or replacing the LED strip with a custom solution as well.
MSRP: 119.95€. For more information, visit the product page.
