Electrical sub panel fix
98 (0.03/day)
A dusty server room
System Name HP DL380 G5
Processor 2x Intel Xeon X5460 @3.16 Ghz
Motherboard HP DL 380
Cooling 6 60mm intake fans rated for 14k RPM max load
Memory 16GB of DDR2 667Mhz
Video Card(s) AMD XFX R7 360
Storage 3x 140GB 10K SAS JBOD
Display(s) 1x Hisense 42" TV
Case DL 380 G5
Audio Device(s) HDMI Out
Power Supply 2x 800w Proprietary PSUs
Mouse A cheap logitech wireless mouse
Keyboard Acer KU-0355
Software Windows 10!
Benchmark Scores Ill get around to em soon
Been in this house a few years now and doing the walls in this house.
This is a feeder into a sub panel I have on the outside wall of the house.(this feeds directly into the back of the panel).This doesn’t look mounted correctly. It looks like someone just glued on a metal wire clamp to the ply because in the panel, the actual grommet tightening ring isn’t there. Is there a better way of doing this? This doesn’t look code. (I am comfortable working on panels and the sort as a diy electrician. Just this install irks me, even. )
If anyone knows of a better way of feeding the wire into the panel. Lmk
I want it to be safe.
this is some 50 Amp wire feeding into this panel. Anyone got any idea what a better mounting solution would be so this wire doesn’t fray and short?
Frick
Fishfaced Nincompoop
19,718 (2.86/day)
w
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
You call an electrician.
13,418 (1.99/day)
Nebraska, USA
Mouse Logitech M190
Software W10 Pro 64-bit
I agree with Frick.
Beyond that, are you saying that cable goes to the outside of the house? If so, then I reiterate - I agree with Frick. It is not a matter of what you feel comfortable with. It is a matter of it complying with local codes for your area. Should you decide to move in the future, if a new buyer gets an inspection first (as they should) you need everything up to code. Might as well do it correctly now.
sneekypeet
not-so supermod
29,634 (4.33/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
I'm no electrician by any means, but i have tinkered with similar stuff in the past.
My guess is that it got glued as the wall is too thick to allow the nut to be threaded on the clip. That clip is not made to be externally used either. Locally, not where you are, it is also a must that the Romex not be exposed, it needs to be in conduit of some form.
While I may not want to putz around inside the panel, you may find a lot of help in DIY home stores, as many times they hire people in the profession they are found in.
98 (0.03/day)
A dusty server room
Case DL 380 G5
Some more peering around and I agree with your deduction . The wall is half inch ply.
The clamp isn't being used externally as it is still inside of the building I initially logicked, however I do see what you're saying however, as the cable runs into the panel which is outside. I could try an NM conduit fitting with long threads and feed it in that way.
13,418 (1.99/day)
Nebraska, USA
Mouse Logitech M190
I wonder if that stuff is really meant as glue or as a sealant/barrier to keep critters and the weather out?
98 (0.03/day)
A dusty server room
Case DL 380 G5
The issue is, there's no locking nut for that clamp in the panel and the threads don't make it into the panel. (I stuck a plastic grommet so the panel knockouts don't chafe the wire.)
I suppose it's to hold the clamp in place.
13,418 (1.99/day)
Nebraska, USA
Mouse Logitech M190
So to be clear in my mind, none of this is exposed to the outdoors, right?
50Amps is a lot. Where does that go? That really does not matter. It needs to be cleaned up and done properly - and probably with some sort of outlet box on this side of the wood panel.
98 (0.03/day)
A dusty server room
Case DL 380 G5
This wire feeds a subpanel on the other side of the wall(Fed in through the back of the panel). Panel is located under roofed porch(no walls, only supporting pillars)
13,418 (1.99/day)
Nebraska, USA
Mouse Logitech M190
Since critters could get in there, it needs to be done right - and to code.
2,583 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 4X D5T Vario, 2X HK Res, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01
Video Card(s) MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724
Storage Samsung 990 PRO 1TB M.2
Display(s) LG 32GK650F
Case Custom open frame chassis
Mouse Logitech MX700
Keyboard Logitech LX700
Software Win11PRO
Is the outdoor panel even 3R?
Also, the penetration needs to be below the lowest point of connection in the panel, which it is not.
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
Display(s) DELL U2311H
Keyboard Microsoft Wired 600
It is recommended of you to ask for professional help, the entire electrical installation it must be renewed with fresh materials which them follow latest specifications.
There is no chance this house to be insured against fire by any company, if this is not fixed and inspected by a professional electrician.
Electrical inspection this is now made by special equipment, and you do receive signed verification about it.
