Elitegroup (ECS) Advances Motherboard Durability and Stability with Hyper Alloy Choke
46,835 (7.63/day)
Elitegroup Computer Systems (ECS) is pleased to announce their newest advancement in motherboard durability and stability with the implementation of Hyper Alloy Choke. The next generation of ECS' gold plated Alloy Choke technology, the Hyper Alloy Choke are ideal for overclocking because of their high energy efficiency and heat reduction.
Under unstable currents or high stress workloads, standard chokes are more likely to burn out or result in a system shutdown. ECS' Hyper Alloy Choke offer 1.5x more stability thanks to ECS' advancements in choke technology and the high-quality raw materials that make up these chokes.
Compared to standard chokes, ECS Hyper Alloy Choke are able to reduce heat 13% better, and they have a tolerating temperature range that is 50 degrees wider. The ECS Hyper Allow Choke also achieve much higher energy efficiency with 30% higher energy savings compared to the industry standard. With extremely wide stable operating temperatures and greater energy efficiency, ECS boards with Hyper Alloy Choke thrive in punishing overclocking and heavy power users' scenarios.
ECS's gold plated Hyper Alloy Choke are resistant to corrosion and oxidation which leads to longer and more dependable life spans. These ECS chokes are also more energy efficient, reducing power consumption and EMI (Electromagnetic Interference). This provides a safer and more stable operating environment for users.
The ECS Z77H2-A4 will be the first motherboard to benefit from the greater stability, higher efficiency, long life span of the ECS Hyper Alloy Choke. ECS will also implement their Hyper Alloy Choke technology on more boards in the future.
16,824 (2.34/day)
Oh look, ECS copied ASRock...
brandonwh64
19,542 (3.59/day)
Wow this board looks like the bottom of the barrel quality Z77 board I have seen yet. Intel looks to have better Z77 boards than this...
13,791 (1.90/day)
Seriously, 2x PCI on a 2012 motherboard? I have one on my Rampage II Gene and i still hate it. I could have my soundcard there and gfx card in first PCIe slot, instad i have it inverted. Soundcard in PCIe slot on top and gfx on last PCIe at the bottom.
3,051 (0.63/day)
System Name The SwagMachine / The Sister
Processor Core i5 3570K @5.2ghz 1.3V/ 1100T
Motherboard ASUS P8Z77-V / ASUS M5A99X EVO
Cooling Phanteks PH TC14PE / Corsair H40
Memory M379B5273DH0-YK0 2X4GB + PVI316G213C1QK 2X4GB / 2x4GB Patriot 2133
Video Card(s) PNY 780Ti /Windforce 7950
Storage 2xSamsung 840 EVO 250gb+WD10EZEX + WD30EZRX/ 1x WD1500 Black
Display(s) AOC Q2963PM+Acer S200HL / Acer S200L+ LG 22LD350
Case Fractal Define R4 / NZXT Trinity
Audio Device(s) Asus Xonar DG / Asus Xonar DG
Power Supply Seasonic 750X / ROSEWILL RG630-S12 630W R
Mouse Razer Deathadder Chroma / Roccat Kone+
Keyboard Razer Blackwidow 2013 Stealth / Roccat Isku
Software Windows 8.1 Pro / Windows 7 Ultimate
Benchmark Scores one time I scored a 3 on 3dmark 11
Looks like someone threw up on a motherboard.
brandonwh64
19,542 (3.59/day)
The lack of higher end power management and the 4 pin CPU power suggests to me that it is not good for anything over stock clocks but I could be wrong.
5,426 (1.06/day)
The G1.Sniper M3 also have a 4PIN CPU connector, no problem there overclocking the 3770K
11,878 (2.26/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
yeh but they are Crap compared to ultra hyper alloy chokes, Thankgod plated chokes have arrived:rockout::eek::rockout::roll::laugh::laugh::laugh:
