Elpida Begins Sample Shipments of Industry's Smallest 2-Gigabit DDR3 SDRAM
47,438 (7.50/day)
Elpida Memory, Inc., Japan's leading global supplier of Dynamic Random Access Memory (DRAM), today announced that it had begun sample shipments of its new 2-gigabit DDR3 SDRAM (product names: EDJ2116DEBG and EDJ2108DEBG) geared for use in consumer electrical appliances. The new SDRAM is the industry's smallest 2-gigabit DDR3 that supports an x16-bit I/O interface.
The new 2-gigabit DDR3 SDRAM is well suited to consumer electrical appliances. It meets the high-speed DDR3-1600 (1600Mbps) standard likely to become the mainstream memory speed standard in 2011, uses energy-efficient 1.35V for the DDR3L-1333 memory speed and is compliant with DDR3-Plus (seamless BL4 access) for upgrading the performance of consumer electrical appliances.
Compared with Elpida's existing x16-bit I/O products for use in consumer electrical appliances the new SDRAM uses 30% less current and its low 1.35V operating voltage increases its attractiveness as an eco-friendly DRAM.
Product Features:
  • x16-bit/x8-bit I/O
  • DDR3-1600 high-speed access
  • 1.35V operation for DDR3L specification
  • DDR3-Plus (seamless BL4 access)
  • Data output buffer can be set to low output (RZQ/5)
Target applications:
  • Digital TV, BD players, BD recorders, set top boxes and other consumer electrical appliances
  • Tablet PCs
Following sample shipments mass production is expected to get underway in the first quarter of CY 2011.
chuchnit
95 (0.02/day)
KY
So none of this will be for PC memory? They need to release some new hypers...
2,792 (0.39/day)
Tre, Suomi Finland
System Name Ladpot ◦◦◦ Desktop
Processor R7 5800H ◦◦◦ i7 4770K, watercooled
Motherboard HP 88D2 ◦◦◦ Asus Z87-C2 Maximus VI Formula
Cooling Mixed gases ◦◦◦ Fuzion V1, MCW60/R2, DDC1/DDCT-01s top, PA120.3, EK200, D12SL-12, liq.metal TIM
Memory 2× 8GB DDR4-3200 ◦◦◦ 2× 8GB Crucial Ballistix Tactical LP DDR3-1600
Video Card(s) RTX 3070 ◦◦◦ heaps of dead GPUs in the garage
Storage Samsung 980 PRO 2TB ◦◦◦ Samsung 840Pro 256@178GB + 4× WD Red 2TB in RAID10 + LaCie Blade Runner 4TB
Display(s) HP ZR30w 30" 2560×1600 (WQXGA) H2-IPS
Case Lian Li PC-A16B
Power Supply Corsair AX860i
Mouse Logitech MX Master 2S / Contour RollerMouse Red+
Keyboard Logitech Elite Keyboard from 2006 / Contour Balance Keyboard / Logitech diNovo Edge
Software W11 x64 ◦◦◦ W10 x64
Benchmark Scores It does boot up? I think.
