Enabling TcpAckFrequency and/or TcpNoDelay in the registry.
EastCoasthandle
6,885 (0.94/day)
System Name MY PC
Processor E8400 @ 3.80Ghz > Q9650 3.60Ghz
Motherboard Maximus Formula
Cooling D5, 7/16" ID Tubing, Maze4 with Fuzion CPU WB
Memory XMS 8500C5D @ 1066MHz
Video Card(s) HD 2900 XT 858/900 to 4870 to 5870 (Keep Vreg area clean)
Storage 2
Display(s) 24"
Case P180
Audio Device(s) X-fi Plantinum
Power Supply Silencer 750
Software XP Pro SP3 to Windows 7
Benchmark Scores This varies from one driver to another.
These dwords can be added in the registry by doing the following:
Registry Key
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\Tcpip\Parameters\Interfaces
Find the correct interface for your active network connection IE the correct {1231-23sd-fsdf-...}. A good way to do this is to look at the IP Addresses listed until you find the correct interface.
Under that key add the following values
TcpAckFrequency=1 (DWORD32)
TCPNoDelay=1 (DWORD32)
This trick from what I've read so far seem to work best for games that use TCP specifically (you can google to see if the protocals used for that game are TCP specific). But for the most part MMORPG type of games, etc which are used to send small packets, etc. So, if a game uses UDP like COD:WAW, COD4, etc then it's not worth making this change?
