Entry level gaming PC
90 (0.01/day)
Processor QX9650, 4@1.36v 11x365
Motherboard Asus p45q-e
Cooling Prolimatech Super Mega Cooler (Akasa Viper push/pull)
Memory OCZ 8GB (4x2GB) PC2-6400C4 800MHz ReaperX HPC Enhanced Bandwidth Edition Dual Channel DDR2
Video Card(s) HIS 6970 ATI HD
Storage 1TB
Display(s) 30" dell 3008, 2x19" samsumg syncmaster
Case Antec P180
Audio Device(s) PCI XFi SB
Power Supply 800wat Tagan
Software Windows 7 x64
Benchmark Scores 14500 3dmark 06 @ 2500x1600 8AA 22000 3dmark 06 @ defaults 4800 3dmark 11 @ defaults
Hi everyone,
I have been out of the game for a while and now looking to building up a fairly basic gaming rig for my daughter, colours and looks are important to her while I am trying to push the spec as far as I can for the budget.
This is what I have so far as a setup:
Intel Core i5-14400F
ASRock B760M-HDV
Nvidia RTX 4060 Ti OCd
Patriot Viper Steel series ddr4-3600 2x16
WD Black SN770 (1TB)
X= Singularity 700W PSU
Any major errors in choices?
Objective:
*She mainly plays fortnite, looking at getting a silky smooth experience at 1080p
*Just started working so not much cash, obv I am helping and getting a bit carried away (man I forget how addictive designing and pimping PCs was... back in my day... yada yada)
169 (1.22/day)
Processor AMD Ryzen 7 5700X
Motherboard ASUS ROG Strix B550-F Gaming Wifi II
Cooling Noctua NH-U12S Redux
Memory 4x8G Teamgroup Vulcan Z DDR4; 3600MHz @ CL18
Video Card(s) MSI Ventus 2X GeForce RTX 3060 12GB
Storage WD_Black SN770, Leven JPS600, Toshiba DT01ACA
Display(s) Samsung ViewFinity S6
Case Fractal Design Pop Air TG
Power Supply Corsair CX750M
Mouse Corsair Harpoon RGB
Keyboard Keychron C2 Pro
VR HMD Valve Index
I'm not from the UK, so I can't speak on what's the best picks out there. What I can speak on is that power supply, and it gives me bad vibes—can't peg it as a whitelabeled supply from a decent OEM, the warranty is shockingly short for such a unit (5 years is considered 'good'), and at that price the only wattage match was an Aerocool Integrator... bleugh. Best case scenario, they're neglecting to show you that the cables are actually black and won't help a white aesthetic at all. Worst case... well, I wouldn't put it next to anything I value deeply.
If it's all-white you're going for, I would recommend going with an okay unit like the MSI MAG A650BN or Corsair CX650 and using cable extensions for the front-end looks. Just try and gravitate to 16AWG cables if you can.
Besides that, unless the CPU + Mobo/RAM are a bundle, I would recommend saving a handful of pounds by going back a generation to the i5-13400F or even the i5-12400F given the GPU muscle we have on hand. You might also be interested in an Intel GPU, since the latest B580 (AsRock Steel Legend review linked, if ya want white) is a value princess.
90 (0.01/day)
Storage 1TB
Case Antec P180
gives me bad vibes
It gives me bad vibes too, my daughters pick, on the surface a good find but I couldn't find a manufacturer either so though maybe cheap china ali express...... I had a PSU fail years ago and it was a bit of a mess fixing things, vowed at that point to only go branded with PSU's
Awesome, yes, that looks a way better pick. Thanks a bunch!
Thinking the downgrade of the CPU is better given the resolutions she will be running
Q: Intel Core i5-12400K or KF ?
Q: ++Need a white MB board now with built in wifi preferred
I am guessing there is no need for third party cooling? Eg. ID-COOLING FROSTFLOW X 280
Q: Any overclocking potential with a more serious MB and the cooler?
34 (0.30/day)
Yep...just get 12400f box and fan is inckuded. A couple mhz wont give her any noticeable difference and use the rest of the money to buy better psu
169 (1.22/day)
VR HMD Valve Index
Q1: Intel Core i5-12400K or KF ?
Q2: ++Need a white MB board now with built in wifi preferred
Q3: I am guessing there is no need for third party cooling? Eg. ID-COOLING FROSTFLOW X 280
Q4: Any overclocking potential with a more serious MB and the cooler?
A1: 12400 doesn't come with a K version; it's a 12600 with its (likely defective) E-cores cut off. When it comes to the 12600K/KF, either or is asking for way more power and demand for cooling than it's worth in performance, especially given the price & power band we're working within. As a rule, the F chips are the cheaper option to no performance detriment; no iGPU, but that very much should not be an issue.
A2: When it comes to LGA1700 the boards are limited if you insist on going with the cheaper DDR4 memory; the pragmatic option is likely to nab this B760M-HDV model, a passable DDR5 kit, and an Intel AX200/210 module a la carte.
Of course, you could also put your nose to the ground looking for white-on-silver/black boards that suit your fancy; I can't scout as well across the pond.
A3: On the 12400F, nah not really. If you absolutely require a clean white look, nab a Thermalright cooler in the form factor ya like. They're £25-30ish, and better than stock. For a K/KF model though, 240mm AIO or ~155mm dual tower air cooler, minimum. Those things get HOT.
A4: 'Overclocking' and 'beginner build' don't go hand-in-hand very well, and even then things were pushed near the limit thermally on Alder Lake and over the limit electrically on Raptor Lake. AMD has the more fertile soil for overclocking, especially since you don't have to shell out to tinker with those. The boards I would even point you towards were I to recommend overclocking would be somewhere in the £150 range to start, and £170 if you want it in white.
