EOLIZE Announces SVD-NC11-4 NAS Enclosure
46,781 (7.63/day)
German brand EOLIZE is hereby announcing its first Mini-ITX Case aiming for private and corporate market. EOLIZE SVD-NC11-4 chassis is ready to be used for NAS and Home Servers based on common aftermarkets Mini-ITX Motherboards.
Prices for Hard Drives are falling constantly while the capacity increases as well as the demand for mass storage solutions from private and corporate users. Hence puts NAS and Home Servers more into focus of end-users, small and medium-sized businesses. EOLIZE SVD-NC11-4 Mini-ITX chassis is a comparatively cheaper solution for these applications. It furthermore comes in a stylish black overall design to fit in most environments.
A total of four Hot-Swap Modules are easy to access behind the front panel. Each Hot-Swap Module is equipped with a lock which can be locked individually and two LEDs for visualization of operation and access of each Hard Drive. Common aftermarket 3.5" (8.89 cm) or 2.5" (6.35 cm) Hard Drives can be mounted inside the Hot-Swap Modules which are compliant with the SATA-II standard. Special backplanes are used to provide support of AHCI (NCQ) and RAID functions. Yet, compatible RAID configurations depend highly on the functions of the Mini-ITX-Motherboard or the built-in RAID Controller.
To assure stable operation an efficient 200 Watt Flex-ATX Power Supply Unit is already built-in. It allows the utilization of one 20/24-pin ATX Power Connector, one 4-pin 12V-P4 CPU Power Connector and two 4-pin Molex Power Connectors for the SATA Backplane. Appropriate airflow inside the EOLIZE SVD-NC11-4 chassis is accomplished by adding a 120 mm case fan which rotates at 1,400 rpm. Furthermore it is possible to use one full-size PCI or PCI-Express expansion card. On the bottom side of the front panel two USB 2.0 connectors, one Power Button, one Reset Button and the corresponding LEDs are located.
SVD-NC11-4 Mini-ITX-Chassis is available as of today in the official EOLIZE online shop for 139 EUR (incl. 19% VAT) or other European shops. For more information, visit the product page.
46,781 (7.63/day)
It's a mini-ITX chassis with hotswap bays.
Wiseblood
1 (0.00/day)
This is also available as the CFI A7879. I've been running my Windows Home Server in one for about a year now. It's a pretty decent case.
680 (0.11/day)
Hungary / Budapest
System Name Kincsem
Processor AMD Ryzen 9 3950X
Motherboard GIGABYTE X570S AERO G
Cooling Be Quiet Black Rock 4 Pro
Memory HyperX 128GB Fury 4×32GB 3200MHz HX432C16FB3K4/128
Video Card(s) Sapphire AMD RX 7900 XT Pulse
Storage Samsung 970PRO 500GB + Samsung 980PRO 2TB + Adata SX8200 2TB + WD Ultrastar HC550 16TB
Display(s) Acer QHD 27"@144Hz 1ms + UHD 27"@60Hz
Case Cooler Master CM 690 III
Power Supply Seasonic PRIME GOLD 850W
Keyboard HyperX Alloy Elite RGB
Software Windows 10-64
Benchmark Scores https://valid.x86.fr/4d8n02 https://www.techpowerup.com/gpuz/g46uc
Whaow!!
I want this with a 16 disk solution!!!
5,614 (1.05/day)
San Diego, CA
System Name White Boy
Cooling CORSAIR H100
Display(s) 1 Dell 30U11 30"
Case BIT FENIX Prodigy
Audio Device(s) none
601 (0.09/day)
Under Columbus, Ohio
System Name Gen0cide
Processor AMD Phenom x4 920 2.8 @ 3.36 1.44v
Motherboard Asus M2N-Deluxe + WiFi
Cooling Thermoright True Rev C
Memory 2x 2gig of Gskill DDR2 1066 @ 5-5-5-15 20 2.125v
Video Card(s) Gigabyte 250 GTS 1 Gig
Storage 5x 730gig 7,200 RPM Raid 5 Western Digital Black
Display(s) Neovo F-417
Case Antec Twelve Hundred
Audio Device(s) On-Board
Power Supply SeaSonic M12 SS-600HM
Software Windows 7 x64 / Arch Linux-fluxbox(duel Boot)
I really like it but its 202 bucks you can damn near get a qnap for the same price after you get everything in it
Frick
Fishfaced Nincompoop
19,041 (2.84/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
It will not be $200, probably more like $150. Taxes and whatnot you know.
601 (0.09/day)
i mean from euro to usd ... I am american >.<
Frick
19,041 (2.84/day)
Piteå
That's what I meant. We pay a lot more in tax. Most things, at least in sweden, are about €1 per 1 USD.
601 (0.09/day)
cool thats sweet i need to build me a nas box .... now just getting wake on demand figured out lmao
