- Dec 8, 2020
- 3,002 (2.10/day)
- United Kingdom
Downloads: Equalizer APO | E-APO Stereo Upmixer.
1A: Disable the device(s) you want to add EAPO to using Windows 'Sound Control Panel' | 1B: For [DTS DCH] run 'Equalizer APO.reg' from 'DTS Settings' on the device(s):
2: Install EAPO, at the device config, tick the device(s) you want, at the bottom tick troubleshoot, and set SFX/MFX, pre-mix, no post-mix (per device):
3: Say no to the restart, then run 'Configure.reg' from my 'Upmixer Config', then copy the [.txt] files to [C:\Program Files\EqualizerAPO\Config]:
4: Run the EAPO config editor, and add your already setup device(s) to the main panel:
5: Restart, then enable the device(s).
