error 43
Lazaro1065
8 (0.01/day)
‎Hello good I write because my card began to give error 43 from good to first. It also happens that I work a couple of days without problem and then I arrive I turn on the pc and return to the same. It catches my attention because I start to crack the pc and after restarting error 43. I turn off the pc I disconnect it 20 min and then the card works smoothly for a couple of minutes and then cracks again and error 43 permanent unless I leave it 20 minutes or maybe more and work for a couple of minutes. Please need help.‎
I would like to add that the driver gives me a 300 error and a text regarding compatibility. I have already tried several versions of windows and all kinds of drivers and in all of them the same, currently I use windows 11; when I refer to the fact that the card does not work for me, I mean that it does not take the drivers. It is something intermittent, it gives me the impression that it has to do with temperature because when it has not been working for a while, I put it on and take it for a while until my pc cracks or gives me the error pa 300. I have tried several bios and I currently have this: https://www.techpowerup.com/vgabios/197894/sapphire-rx580-8192-171107
1,891 (1.37/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
Since you already opened the card , please open it again and make a picture from the memory chips.
Also we would like to ask you to make a picture from GPU-z.
Thanks
1,891 (1.37/day)
Romania
Yes, error 43 appears when your card fail to initialise the core.
That means either you have a corrupt driver or BIOS .....or the worst case scenario is to have a burned card.
BEFORE anything else...please move the BIOS switch to the other position and try to start computer again.
If it makes the same problems we go to the next step.
We will try 1st to clean the drivers, install a fresh driver (an older one).
If after the clean install you will still obtain the error, then you will flash the BIOS of your card (we do it cause it could be altered by previous owner for mining purposes)
I would suggest to remove old drivers ONLY by using DDU.
This is a tool exactly for that.
You will do it in safe mode with the network disconnected.
After you restart computer (w/o network) windows won't be able to install auto the drivers due to the lack of network.
Now you will be able to clean install the drivers you desire.
As i said earlier DO NOT use the latest drivers, since AMD is known for ignoring the old video cards in the latest drivers. All they improve (actually they only correct) some errors in games reported by players.
So try to use a 2019-2020 version.
I would suggest the following:
https://www.amd.com/en/support/kb/release-notes/rn-rad-win-19-9-2
or
https://www.amd.com/en/support/kb/release-notes/rn-rad-win-20-2-2
Lazaro1065
8 (0.01/day)
Pendon no tengo como mandarles ahoramismo las fotos de gpu z pero se que no me da los valos de uso de gpu los fanes, reloj etc y tampoco salen la cantidad de banda pasante, filtrado de textura y filtrado de pixeles
1,891 (1.37/day)
Romania
English please :)
Lazaro1065
8 (0.01/day)
Sorry I don't have a way to send you the gpu z photos right now but I know that it doesn't give me the gpu use values for the fans, clock etc and the amount of passband, texture filtering and pixel filtering don't come out either
43,376 (6.75/day)
Thats besides the point there is more stuff to be obtained from the screenshot
