Error at 96EAC0
LucasH15
3 (0.60/day)
I run test and throw this error. Anyone knows anything about this? I dont find information! Thanks!
Solaris17
Super Dainty Moderator
26,197 (3.80/day)
Alabama
System Name Rocinante
Processor I9 14900KS
Motherboard MSI MPG Z790I Edge WiFi Gaming
Cooling be quiet! Pure Loop 240mm
Memory 64GB Gskill Trident Z5 DDR5 6000
Storage 1x 500GB 980 Pro | 1x 1TB 980 Pro | 1x 8TB Corsair MP400
Display(s) Odyssey OLED G9 (G95SC)
Case LANCOOL 205M MESH Snow
Audio Device(s) Moondrop S8's on schitt Modi+ & Valhalla 2
Power Supply ASUS ROG Loki SFX-L 1000W
Keyboard Monsgeek M3 Lavender, Akko Crystal Blues
VR HMD Quest 3
Software openSUSE Tumbleweed
It means you got an error at that memory address.
4,693 (3.90/day)
Colorado, U.S.A.
Power Supply EVGA 500W1
Software Windows 11 Home
Replace the RAM
But first try resetting the RAM and running: Windows Memory Diagnostic
W1zzard
Administrator
27,223 (3.70/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Also try lowering memory clock / relaxing timings / increasing voltage
3,004 (1.03/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Storage Too much
Case Thermaltake Core X9
Mouse G305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
I recommend trying to run MemTest86 to ensure windows or anything higher on the software stack isn't potentially causing the error.
If the error persists in MemTest86, as Wizard points out it's worthwhile to try lowering the mem clock / timings / increasing voltage and then re-testing to see if the error still occurs. You can try using the JEDEC defaults if you aren't using them already.
Memory errors are most often the fault of the RAM itself but it can also be caused by the motherboard (whether that be via poorly set sub-timings or poor traces to the RAM slots) or even an over-tightened CPU cooler.
