Esprimo P520 E85+, boot failure, after battery replacement and FUJITSU D12-250P1A power supply, how to test?
nico_ar
3 (0.00/day)
I got recently an Fujitsu Esprimo P520 E85+ Desktop that won't start.
After replacing the battery on the motherboard, BIOS won't load.
I want to test firstly the FUJITSU D12-250P1A power supply.
I removed it from the desktop. Can anyone tell me, please, how could I start it?
I got 12V on the green wire and 11,7 on the brown/yellow one.
Wil it start with no load?
Thanks!
16,764 (2.33/day)
Short these pins.
nico_ar
3 (0.00/day)
Thank you very much for your answer, LostSwede!
Unfortunately the power supply connector doesn't match your description, it is about a proprietary Fujitsu 16 pin connector. See att. please. I have 12V on pin 7 and 11.7 on pin 8. No idea what pin should I short in order to start it...
733 (0.23/day)
Earth's Troposphere
Mouse various/various/various
VR HMD -
The grey one ,PG (power good) to ground to start it manually.
nico_ar
3 (0.00/day)
Hi, "dont-whant-to-set-it"!
Thank you very much for your answer! Unfortunately, grounding the grey pin didn't work. Finally I was lucky: I replaced the battery on the motherboard and the power supply started with full load. Another problem: bios won't load...
However, thank you again, all, for your effort trying to help me!
