ethernet cable lights not flashing
H3roin
2 (0.00/day)
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.42/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
Unplug the cable on both ends and examine the port to make sure all of the electrical contacts are not bent. If they all look good, try a different cable. Another thing to easily check is make sure the LAN is not disabled in the computer BIOS.
If that black box is a gateway someone else set up previously, you may want to try the other ports on it. It may be configured to only use one of the ports and disable the rest.
18,584 (2.67/day)
System Name AlderLake
467 (0.14/day)
South Africa ,Lions Everywhere..
System Name Ground Control
Processor Intel i5 2500k 4 Ghz
Motherboard MSI P67A-GD80 B3
Cooling Cooler Master Hyper 212x
Memory 2 x 4GB DDR3 1600mhz Apacer Black Panther
Video Card(s) Msi GTX 1060 OC 3Gb
Storage 2 x 250Gb WD Blue raid 0 + 1Tb Wd Green
Display(s) Samsung BX2450 24" Led
Case GMC X7 X-Station
Power Supply HEC Raptor 500watt
Mouse Logitech G9
Software Windows 8.1
Benchmark Scores Power Level over 9000
Network card could be disabled
Make sure its enabled in Network and Sharing center>adapter setting
Are the drivers installed?
14,186 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
If it is a solid green light, it means it is connected, if it is flashing, it indicates data being sent or received.
The light appears to be a solid green light on the right on the back of your P.C.
Solaris17
Super Dainty Moderator
27,186 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
