Eurocom has launched the C315 Blitz Superlaptop with 15.6" display, Intel Core i7 processor, Intel Iris Xe graphics, 16 TB storage, 64 GB DDR5 memory, up to 8 hrs of battery life in a robust and durable Titanium black aluminium case.
"The C315 Blitz 15.6" laptop is lightweight and heavy duty, with its durable aluminium body and 8 hours of battery life it is perfectly suited for corporate all-day, all-night computing." Mark Bialic, Eurocom President said. "The EUROCOM C315 Blitz is the ultimate laptop companion for professionals on the go."
Processor
The EUROCOM C315 Blitz utilizes the Intel Core i7-1360P processor with 12 cores and 16 threads. The Intel Core i5-1340P processor is also available.
Graphics
The EUROCOM C315 Blitz supports the Intel Iris Xe iGPU. The Intel Iris Xe graphics chips will roughly double the graphics performance of the previous generation. Intel Iris Xe graphics are capable of 3D performance gaming in the thin-and-light EUROCOM C315 Blitz. The ability of capable 1080p gaming performance in the EUROCOM C315 Blitz is a huge development for on the go users.
Robust Design
The EUROCOM C315 Blitz utilizes a Titanium black aluminium case to keep the high performance components inside safe and secure for on the go users while offering a classy and sleek form factor design. Weighing under 2 kilograms is an astounding accomplishment for the EUROCOM C315 laptop that holds so much performance inside.
Battery
The EUROCOM C315 Blitz supports two different capacities of Polymer Lithium Ion batteries, a 36WH and a 73WH battery that customers can choose when purchasing. The 73WH battery provides users with 8 hrs of battery life that is perfect for all day long computing at work/home and in-between.
Connectivity
The EUROCOM C315 Blitz is loaded with connectivity options to ensure customers can connect to as much technology as possible to get the job done. The EUROCOM C315 Blitz comes equipped with the following ports:
Storage
The EUROCOM C315 Blitz has two M.2 NVMe storage slots and supports up to 16TB of customizable SSD storage.
there following options are being offered per drive:
Memory
The EUROCOM C315 Blitz comes equipped with two 262 pin SODIMM sockets and can support a whopping 64 GB of DDR5 memory. The following options are being offered:
Display
The EUROCOM C315 Blitz is based on a 15.6" laptop form factor and supports a variety of displays for customers to choose from.
There are two choices available:
![](https://www.techpowerup.com/img/IF6PB9kEl6OTbqgS_thm.jpg)
![](https://www.techpowerup.com/img/PNyopG1mpkjMJqDi_thm.jpg)
![](https://www.techpowerup.com/img/1pgQNBJJBCAxyPYC_thm.jpg)
![](https://www.techpowerup.com/img/Csb6IhsblU1wRMeJ_thm.jpg)
Processor
- Intel i7-1360P Processor 12C/16T on-board; w/ Intel Iris Xe Graphics;
- Intel i5-1340P Processor 12C/16T on-board; w/ Intel Iris Xe Graphics;
Graphics
Robust Design
Battery
Connectivity
- Thunderbolt 4
- 2x USB 3.2
- USB 2.0
- HDMI 2.0
- 2-in-1 Audio Jack
- RJ-45 LAN
Storage
- 500GB; M.2; SSD; NVMe 1.4; PCIe 3.0 x4; SAMSUNG 980
- 500GB; M.2 SAMSUNG 980 Pro; SSD; PCIe 4.0; NVMe;
- 1TB SSD; SAMSUNG 980 Pro; PCIe 4.0 NVMe M.2 2280;
- 1TB; M.2; SSD; NVMe 1.4; PCIe 4.0; SAMSUNG 980
- 2TB SSD; SAMSUNG 980 Pro; PCIe 4.0 NVMe M.2 2280;
- 4TB; NVMe PCIe 4.0; M.2; SSD; 22x80mm; Sabrent Rocket Q
- 8TB; M.2 NVMe PCIe 4.0; SSD; 22x80mm; Sabrent Rocket 4 Plus
Memory
- 16GB; 1x 16GB; DDR5-4800; Micron/Crucial; 262-pin; 1.1V; 1 SODIMM
- 16GB; 1x 16GB; DDR5-5600; Kingston; 262-pin; 1 SODIMM
- 32GB; 2x 16GB; DDR5-4800; Micron/Crucial; 262-pin; 1.1V; 2 SODIMMs
- 32GB; 2x 16GB; DDR5-5600; Kingston; 262-pin; 1 SODIMMs
- 32GB; 1x 32GB; DDR5-4800; Micron/Crucial; 262-pin; 1.1V; 1 SODIMM
- 32GB; 1x 32GB; DDR5-5600; Kingston; 262-pin; 1 SODIMM
- 64GB; 2x 32GB; DDR5-4800; Micron/Crucial; 262-pin; 1.1V; 2 SODIMMs
- 64GB; 2x 32GB; DDR5-5600; Kingston; 262-pin; 2 SODIMMs
Display
- 15.6in (39.6cm); FHD 1920x1080; 60Hz; Matte; IPS; 700:1; NTSC 72%; eDP
- 15.6in (39.6cm); UHD; 60Hz; Matte; IPS; 25ms; 800:1; NTSC 72%; 300 cd/m2; eDP 40pin
- Display: 15.6in FHD or UHD; 60Hz; IPS LCD Panel
- Processor: Intel Core i7-1360P (12C/16T); 18MB cache; up to 5GHz; 28W-64W; on-board
- iGPU: Intel Iris Xe; Intel X Micro Architecture
- Display Technology: supports total 3 active displays
- Robust Design: Titanium Black Aluminum Alloy (AL-5052): back cover and bottom case.
- Memory: Two 262-pin SODIMM sockets; DDR5-4800/5600; up to 64GB
- Storage: up to 16TB of SSD storage with two M.2 NVMe slots
- Communications: 1Gigabit Realtek RTL8168/8111 PCIe NIC and WLAN + Bluetooth
- Audio System: High Definition Audio; SoundBlaster Studio
- Connectivity: Thunderbolt4, 2x USB 3.2; USB 2,0; HDMI 2.0; 2-in-1 Audio Jack; RJ-45 LAN; DC-in
- Security: Kensington Lock and Embedded TPM 2.0 Encryption
- Battery: Polymer Smart Lithium-Ion; 36WH or high capacity 73WH (8hrs+)
- Weight: 1.59kg w/ 36WH battery; 1.74kg w/ 73WH battery
- Dimensions: WxDxH: 357x220.5x19.9mm
