System Name | RogueOne |
Processor | Xeon W9-3495x |
Motherboard | ASUS w790E Sage SE |
Cooling | SilverStone XE360-4677 |
Memory | 128gb Gskill Zeta R5 DDR5 RDIMMs |
Video Card(s) | MSI SUPRIM Liquid X 4090 |
Storage | 1x 2TB WD SN850X | 2x 8TB GAMMIX S70 |
Display(s) | 49" Philips Evnia OLED (49M2C8900) |
Case | Thermaltake Core P3 Pro Snow |
Audio Device(s) | Moondrop S8's on schitt Gunnr |
Power Supply | Seasonic Prime TX-1600 |
Mouse | Razer Viper mini signature edition (mercury white) |
Keyboard | Monsgeek M3 Lavender, Moondrop Luna lights |
VR HMD | Quest 3 |
Software | Windows 11 Pro Workstation |
Benchmark Scores | I dont have time for that. |
No wasn’t thinking at the timeIt’s ok you have the bios backup right?
VR HMD | Quest 3 |
What if I can borrow a Gpu from a friend would it be easier or is that way better optionTechPowerUp
Extensive repository of graphics card BIOS image files. Our database covers submissions categorized by GPU vendor, type, and board partner variant.www.techpowerup.com
Guide: Flashing with a hardware programmer
Lets get physical So; you tried flashing your GPU and you didn't backup. Now you have some dude on the forum linking you a BIOS but you have no way to apply it because you don't have a spare GPU either. Well no worries friend. In this guide we are going to cover the simple procedures of...www.techpowerup.com
VR HMD | Quest 3 |
It might show up, probably won’t; but it’s worth a try. That card doesn’t have a switch.What if I can borrow a Gpu from a friend would it be easier or is that way better option
If it does show up what would be the next stepIt might show up, probably won’t; but it’s worth a try. That card doesn’t have a
VR HMD | Quest 3 |
ThanksGoogling and doing any of the leg work.
or downloading nvflash, downloading the bios, opening the command prompt, using -6, hitting Y, hitting enter, reinstalling the drivers.
and finally never updating the thread.
all very standard procedure
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
Get a picture of the model and part number sticker pleaseThanks
System Name | Veral |
Processor | 7800x3D |
Motherboard | x670e Asus Crosshair Hero |
Cooling | Corsair H150i RGB Elite |
Memory | 2x24 Klevv Cras V RGB |
Video Card(s) | Powercolor 7900XTX Red Devil |
Storage | Crucial P5 Plus 1TB, Samsung 980 1TB, Teamgroup MP34 4TB |
Display(s) | Acer Nitro XZ342CK Pbmiiphx, 2x AOC 2425W, AOC I1601FWUX |
Case | Fractal Design Meshify Lite 2 |
Audio Device(s) | Blue Yeti + SteelSeries Arctis 5 / Samsung HW-T550 |
Power Supply | Corsair HX850 |
Mouse | Corsair Nightsword |
Keyboard | Corsair K55 |
VR HMD | HP Reverb G2 |
Software | Windows 11 Professional |
Benchmark Scores | PEBCAK |
You have an iGPU you could run display off of.What if I can borrow a Gpu from a friend would it be easier or is that way better option
I’ve tried that but then once I plug the gpu in everything stop working, I set it in my bios to run off igpuYou have an iGPU you could run display off of.
Ordered a ch341 last option@Mango whats the story?
