Experiments with i5 2310
C045
1 (0.50/day)
I was experimenting with my i5 2310 and HD2000.
First, I looked for information on the internet and supposedly the graphics card is not overclockable. However, I found a section in the UEFI, in the OC part, where it says "GT Overclocking Frequency" and I assumed it was the onboard because it says "1100" and the HD has 1.1 GHz.
So I searched with AI and indeed, it's an overclock section for the graphics card. There were also some voltage settings for it.
So I started tweaking. Increasing by 100 MHz increments and testing with Minecraft, which initially ran at 40 fps on version 1.12.
I searched for more information on the internet and found that people had managed to push it up to 1.3 GHz, but I went further, knowing it could handle more. As I kept increasing and testing stability, the FPS in Minecraft and the overall performance also improved. Yes, believe it or not, the Windows graphical interface runs on hardware acceleration.
Something so simple that without good hardware acceleration, the interface feels clunky and slow. I started increasing the voltage to give it more stability. I reached an impressive 2.0 GHz, with a copper heatsink, stable at 45 degrees idle and 60 degrees under full load. Voltages +0.45. Beyond that, I couldn't push further due to artifacts. 900 MHz on an onboard graphics card is not small. An interesting overclock, as it significantly improved the overall performance of the machine. Games like Lineage II, which previously ran at 30 fps, now run at 60 fps even in crowded cities like Giran. Onboard graphics are still a drawback, but I enjoyed tweaking things and seeing what happened.
See you later
1,580 (3.76/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Pretty impressive. I'm guessing OEM, no CPU oc, or do you have a proper Z series board maybe?
Hoping this is not a daily PC for you, going to direct and invite you to the TPU contest. This is the type of hardware people have sitting around and tinker with. But rarely can say "put to use".
33 (0.06/day)
That is pretty good. Am I assuming the CPU is locked? I have the I5-3340 which is also locked but ASRock's motherboard has it locked as usually when you change CPU cores it is on auto and can only disable cores. This one actually has the option to change all cores which unlocks the multiplier and I can run my memory at 2133mhz. You gave me a stupid Idea. To OC the snot out of the hd2500 just for kicks and see what I can achieve as I have a custom copper cooler. Will send photo's if my CPU decides to go to the moon -_-
