Extension 5.1 surround sound cables
slamminuk
13 (0.00/day)
Evening all!
I recently got a 5.1 surround sound system to run with my PC, the problem is I want the speakers wired to the front room from the PC as I watch films from my PC to my TV.
I can't seem to find the cables needed.
These are the cables that run from my sound card to the sub:
Can anyone post links directly to the 3 cables needed as this will be of great help! Oh and they need to be in the UK and about 10 meters long.
1,775 (0.25/day)
Singapore
System Name Half-fucked overclockedd
Processor Intel Core i7 2600k 3.40Ghz @ 4.20Ghz
Motherboard Gigabyte P67 UD7 B3
Cooling Antec Kuhler H2O 920
Memory G.Skill RipjawsX DDR3 8GB X2 1866Mhz (Model F3-2133C9D-16GXH)
Video Card(s) Gigabyte AORUS 1080Ti Extreme Edition
Storage Samsung 840 Pro 256GB / Western Digital Black Cavier 2TB X2
Display(s) Dell U2715H 2560X1440
Case NZXT Phantom
Audio Device(s) Creative Sound Blaster Recon3D Fatal1ty Professional
Power Supply Cooler Master Silent Pro Gold 1000W
Mouse Logitech G510
Keyboard Tesoro Excalibur Spectrum
Software Microsoft Windows 10 Professional
Well there's a wireless 5.1 by creative. It's a gigaworks. But it's whopping expensive. Around $300USD i think.
225 (0.04/day)
Processor Phenom II X4 965 BE @4 GHz | NB @2600 MHz
Motherboard Gigabyte GA-990XA-UD3
Cooling Noctua NH-D14
Memory 2x 8GB PC12800 @1600 MHz CL7 1T
Video Card(s) Gigabyte HD 7950
Storage 2 x 500 GB -- HD502HJ & WD5000AACS-00ZUB0
Display(s) Iiyama Prolite E2202WS_WVS
Case Corsair Obsidian 550D
Audio Device(s) Asus Xonar D2 w/ Z-5500
Power Supply Seasonic X-750
Mouse Logitech B100
Keyboard Logitech G15 (blue backlight)
Software Windows 7 - SP1 x64
I have no idea how long the cables have to be, but standard jack to jack cables will do, in my opinion. I don't know about the maximum length of optical cables, and coaxial cables are crap unless you get an expensive one, so I think you're better off with the first option.
cdawall
where the hell are my stars
27,683 (4.09/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
there just 3.5mm stereo cables they sell them in a ton of places just buy 3 of them
slamminuk
13 (0.00/day)
Cool, well if thats all I need, I have some laying around somewhere.
I was just unsure as the colours were different, but obviously this must be just a guide to where the plug in.
:toast:
Mussels
Freshwater Moderator
58,413 (7.87/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
the colors are just there to make it easier to know which one goes where.
If you run extensions on those cables, make sure you have each cable the same length, or the audio will go out of sync with your surround sound.
Mussels
58,413 (7.87/day)
Oystralia
Really?! Never knew that, nice one thanks!
i used extensions on mine, and it caused a volume drop - rather annoying when only the rear speakers lost volume, and not the fronts too.
Tau
821 (0.13/day)
On a setup like that you probobly will not notice a diffrence.
That would probobly be caused by diffrent sheilding methods used in teh diffrent cables, or an interferance issue.
With extension you need to worry about interference at the joint.... but with that kind of cable interference will always be there.....
If you get a buzz/whine/hiss - switch to sheilded cable.
Mussels
58,413 (7.87/day)
Oystralia
i used identical cables of the same length from the same packet.
967 (0.13/day)
Danville IL
Processor I7 4770k
Motherboard ASUS z87 pro
Cooling Corsair a50
Memory 4x4 gig Gskil aries ddr3 1866
Video Card(s) Gigabyte r280x windforce
Storage intel 520 120 gig ssd
Display(s) 24 inch Asus IPS
Case Cool Master
Audio Device(s) realtek onboard
Power Supply hiper 880
Software win 7 ult
