External Samsung T7 Speed issue
1,587 (0.21/day)
Poland,Slask
System Name HAL
Processor Core i5 2500K
Motherboard Asus P8P67 Pro Rev3.1
Cooling stock
Memory 2x4GB Kingston 1600Mhz Blu
Video Card(s) Asus 560Ti DirectCuII TOP
Storage Kingston 120 3K SSD,WD Black WD1502FAEX
Display(s) LG 1440x900
Case Chieftec Mesh Midi
Power Supply Corsair TX750V2
Software w8
Hello
Brand new drive, works fine for 10 mins and then this is what happens :/ What can be the problem of such transfer drop?
877 (1.20/day)
Belgium
System Name Prometheus
Processor AMD Ryzen 7 9800X3D
Motherboard ASUS ROG Crosshair X870E Extreme Gaming Wifi
Cooling AIO Cooler Master MasterLiquid 360
Memory 32GB DDR5 6000Mhz CL30
Video Card(s) Gigabyte GeForce RTX 3060 OC Edition 12GB
Storage Samsung 970PRO 2TB, Samsung 990PRO 4TB, WD SN850X 2TB, Samsung 980PRO 2TB. WD GOLD HDD 8TB
Display(s) Corsair XENEON 32UHD144 32" 4K UHD gaming monitor
Case Cooler Master HAF
Audio Device(s) Creative Sound Blaster AE7 + Logitech Z-5500 500W 5.1.
Power Supply Corsair AX850 Titanium.
Mouse Logitech MX Master 3
Keyboard Corsair K95 RGB Platinum Cherry MX
Software W10-11 Enterprise- Linux Mint 22.1 Cinnamon Edition.
Simply enough the SSD it's SLC cache is full and now has to write at the speed of the NAND itself. All SSDs have this behavior more or less, depending on how large the built-in cache is.
1,587 (0.21/day)
Poland,Slask
System Name HAL
Cooling stock
Software w8
I know it should drop but it looks like it crashes tbh, should drop to levels like hdd speed. Im uploading it with 50mb/sec.
877 (1.20/day)
Belgium
Dramatic low speed also does happen if there a lot of small files that has to be written suddenly, like pictures and so on. The same behavior like the old HDD had. Games also have very big file, but also many small files then the write speed goes down instantly.
The speed with many small files is usually shocking.
1,587 (0.21/day)
Poland,Slask
System Name HAL
Cooling stock
Software w8
That was not the case. I just upgraded firmware and seems to be fine now. Im on 60gb of 100gb transfer and it can keep up with HDD.
Anyways thanks for your help.
877 (1.20/day)
Belgium
Strange that firmware have this behavior, this should not happen at all. No idea what was going wrong there, but it has surely nothing to do with the firmware.
But the most important is that it's now okay again. Very low writing speed also does happen if the built in SSD is getting too hot. Even a bad or dirty USB connection can show this problem.
1,587 (0.21/day)
Poland,Slask
System Name HAL
Cooling stock
Software w8
I know. My last screen barely copied 10GB of data.... And all files are 1GB+
I have not even rebooted, same ports etc. I just installed Samsung magician and changed the firmware of that T7
It was giving me these issues before I haven't found the time to investigate until now. Some random post on internet said try firmware...
Looks good now...
877 (1.20/day)
Belgium
I never ever have seen this in my 40 years in the shop. by just putting new firmware... But good it's okay!!:) Because Samsung say's it's blazing fast, but you have to first put new firmware? That can't be right. I keep it for now on a bad USB connection. If the controller is seeing too much error's it's going to lower the connection speed. Clean the contact's for once with IPA, sometimes you will be surprised how dirty they are, with a black cotton swap left over.
By he way, you can get the same speed or even faster with an External USB 3.2 case where you can put in any NVMe drive. Also cheaper.
I use one with inside an Samsung 980PRO 2TB.
234 (0.21/day)
Sometimes they just get the design (or firmware) wrong. I had problems with 60GB Vertex SSDs disappearing and reappearing in the BIOS many years ago. I have seen occasional reports of new firmware updates to overcome bugs on SSD drives, but I cannot recall which ones. Some SSD manufacturers change the RAM and controller chips without changing the part number. Mistakes are made and with inadequate software and hardware regression testing, bad designs can escape the QA net.
