D32 K41532
- Apr 6, 2021
- 19 (0.01/day)
Hi
...any idea how to flash this card?
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
What version are you using? Are the gpu drivers installed?
Thats good in all but 90-97% use Windows stillPiece of cake in Linux
He's using a bootable USB freedos, just as easy could be using live linux distro, some AMD cards are locked though have managed to do it in the linux version in minutesWhat version are you using? Are the gpu drivers installed?
I know about that already.He's using a bootable USB freedos, just as easy could be using live linux distro, some AMD cards are locked though have managed to do it in the linux version in minutes
Try amdvbflash -p 0 ***.romView attachment 223033btw i allrdy tryd all DOS versions i think the one with -f is the best...
System Name | KHR-1 |
Processor | Ryzen 9 5900X |
Motherboard | ASRock B550 PG Velocita (UEFI-BIOS P3.40) |
Memory | 32 GB G.Skill RipJawsV F4-3200C16D-32GVR |
Video Card(s) | Sapphire Nitro+ Radeon RX 6750 XT |
Storage | Western Digital Black SN850 1 TB NVMe SSD |
Display(s) | Alienware AW3423DWF OLED-ASRock PG27Q15R2A (backup) |
Case | Corsair 275R |
Audio Device(s) | Technics SA-EX140 receiver with Polk VT60 speakers |
Power Supply | eVGA Supernova G3 750W |
Mouse | Logitech G Pro (Hero) |
Software | Windows 11 Pro x64 23H2 |
No, it's because it is locked, he should use the unlockrom cmd and try the Linux amdvbflash cmd I posted aboveLooks like a bad ROM chip! Because even with just the "-i" parameter, it reports a failure.
