Fake Graphics card??!?!
99 (0.06/day)
i got the 1050 oc 2gt from msi and when i got it and launched my pc it said 1050 ti so i was like they must of sent me the wrong gpu but then i evantually got gpu-z and launched it and this is what i saw
and now i dont know if i installed a wrong driver and thats why or if msi legit sent me a fake gpu
18,545 (2.72/day)
System Name AlderLake
Where exactly did you buy the card?
FreedomEclipse
~Technological Technocrat~
23,789 (3.75/day)
London,UK
System Name Codename: RX-7878
Processor AMD 7800X3D
Cooling AM5 Contact Frame + Thermalright PS120SE
Memory G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Video Card(s) Sapphire Nitro+ AMD Radeon™ RX 7800 XT Gaming OC 16GB
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
Send it back and report scammer to amazon
99 (0.06/day)
hey btw i am now aware it was not shiped by msi
haha nice joke the gpu was shiped from china before covid-19 was in the usa im taking no risk plus it would be very hard cause this dude has only 3% bad reviews and 95% good reviews so
FreedomEclipse
23,789 (3.75/day)
London,UK
Alright. Well congratulations. You've been scammed
1,357 (0.23/day)
USA
Personally i would ask for a refund without returning, if they are a scammer they should be ok with loosing a few dollars.
Side Note... Does anyone know how GPUZ verifies the GPU chips? Just curious.
13,778 (3.83/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
Looks like a GTS450 based on the GF116 board.
dorsetknob
9,106 (1.28/day)
Contact Amazon and start a RMA
do not mess with card just RMA
ps Did i forget to mention RMA
99 (0.06/day)
Hi i came here to say i did some digging and it looks like this is a
NVIDIA GeForce GTS 450 Rev. 2
same release date same memory type and bus width i asume they changed the memory of it or its a better version cause it has a higher memory but i cant trick it back to being the attchally graphics card it is cause its not combatble with my motherboard so i half to leave my computer thinking its a 1050 ti so ima half to sit back maybe install drivers it can use and wait till chirstmas to get a new gpu maybe
458 (0.22/day)
In Canada counterfeits can be met with criminal actions.
The standard fraud allegation is usually enough to motivate remedies.
Then there is the postal regulations.
FreedomEclipse
23,789 (3.75/day)
London,UK
The thing is. You don't just report a scammer because you yourself got scammed, Its also a service you do for others because you dont want others to fall prey to the same scam. By not reporting it to amazon youre letting who knows how many other people get cheated by the same scheme and by the time enough reports have come in to shut down the seller. He's already transferred the money to a different account - profiting off it.
41,158 (6.56/day)
Only way to know is to look up the ram chip model and count the chips to get the correct capacity, also looking at the gpu die itself csn determine if its a gts or ti etc...
99 (0.06/day)
Btw i just figured out that if ur gpu fits in the slot it works it does not have to say its combaible pcie slots are backwards combatble but i do still need to find a way to correct the memory otherwise so demanding games will try to use more than the gpu has and it will crash LOL
99 (0.06/day)
I tried to do this but i downloaded all the stuff nvflash file did not work when i typed nvflash it would not let me finish everytime i typed i did something and i cant go in windows cmd cause it wont let me shift right click and windows shell wont work oof
277 (0.14/day)
System Name Cheapskate Maximus
Processor Xeon W3680 @ 3.99Ghz [133x30] [1.375v]
Motherboard HP Z400 Rev 2
Cooling Alpenfohn Brocken v1
Memory 3 x 4GB DDR3-1600
Video Card(s) Sapphire RX570 Nitro+
Storage 240GB WD SSD, 6 x 2TB HDD
Display(s) 27" iiyama XB2783HSU AMVA+
Case AeroCool
Power Supply HP 600w Bronze (Delta)
Keyboard Gots keys
Software W10 x64
As far as I'm aware GPU-Z gets its info directly from the GPU die itself instead of what the bios on the card reports, that's how it can detect fakes etc.
41,158 (6.56/day)
Chip is write protected, only a spi flasher would fix it, id grab a resl card and keep this one as a test card...
Regeneration
NGOHQ.COM
3,103 (0.45/day)
Why are you fiddling with the card rather than just returning it? Are you a millionaire?
1,351 (0.30/day)
Processor i7-13700k
Motherboard Asus Tuf Gaming z790-plus
Cooling Coolermaster Hyper 212 RGB
Memory Corsair Vengeance RGB 32GB DDR5 7000mhz
Video Card(s) Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts)
Storage 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate
Display(s) Acer Predator XB273u 27inch IPS G-Sync 165hz
Power Supply Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service)
Mouse Logitech G502 hero
Keyboard Logitech G710+
Too START it would run at pci-e 3.0, next launch date would be in 2016 not 2011. Next after that the tech would 14/16nm for the chip process. just to name a few and lastly the "GPU" would say GP107 noty GF116. What you got was a cheap attempt at scam gpu where as some higher end scammers change that info to match the real thing. What you got was a Nvidia GTS 450 card with a bios edited to claim a it was a 1050 ti.
134 (0.03/day)
System Name Main Workstation
Processor Ryzen 1700 @ 3800 GHz
Motherboard ASRock Fatal1ty AB350 Gaming K4
Cooling Noctua NH-D15S
Memory 2 x 8 GB G.Skill Flare X 3200 MHz
Video Card(s) EVGA GTX 1800 Classified
Storage Crucial MX200 500 GB
Case BC1 Open Benchtable Silver
Audio Device(s) Sennheiser HD 650 /w Apogee Groove and Moon Audio Silver Dragon cable
Power Supply Seasonic Platinum 860W
Mouse Logitech G Pro
Keyboard Leopold FC980C White /w Hasu controller
Software Windows 10 64 bit
Return it, imo.
Should the seller refuse to take it back, not reply to your request for a return, or fail to refund you the card after it has been shipped back, create an A-to-Z Guarantee claim for a refund:
You may be eligible to request a refund under the A-to-z Guarantee if any of the following apply:
1. You have not received your package and three days have passed since the maximum estimated delivery date or the tracking shows a delivery confirmation, whichever is sooner.
2. You received an order that is different than expected and have requested a return with the seller.
3. You returned your item with a trackable shipping method and the seller has not issued you a refund.
Source: https://www.amazon.com/gp/help/customer/display.html?nodeId=201889410
Amazon.com Marketplace sellers also have to provide a return address within the United States or a prepaid return label:
Third-party sellers must either provide a return address within the United States, provide a prepaid return label, or offer a full refund without requesting the item be returned. If a seller does not offer these methods to return your items, you may file an A-to-z Guarantee claim to seek help with your return.
Source: https://www.amazon.com/gp/help/customer/display.html?nodeId=201819200
70 (0.04/day)
System Name Carnival of Glass
Processor Intel i9 14900K (previously 12900K/9900K, 8086K/Xeon X5670)
Motherboard ASRock Z790 PG SONIC (Gigabyte Z690 Aorus Master, Gigabyte Z370 Aorus Gaming 7/390 Des/X58A-UD7)
Cooling Corsair Hydro open loop, 480mm XR7, 360mm XR5!
Memory 32GB Corsair Dominator 6000MT DDR5 @6466 CL36-38-38-72-114-2
Video Card(s) Zotac RTX 3090 w/Corsair XG7 block (previously 1080Ti/970) +200 core +800 RAM +shunt mod
Storage 1x 500GB Samsung Evo 970 boot, 1TB ADATA, 2TB Sabrent RQ, 2x2TB Crucial MX, 4TB WD SN850X, 16TB NAS!
Display(s) Acer Nitro 27" 4K, dual Acer 24" 1080p LED, 65" Panasonic UHD 4K TV/55" Toshiba 4K UHD in bedroom
Case Corsair 7000X (previously Corsair X570 Crystal SE)
Audio Device(s) Onboard + EVGA Nu Audio Pro 7.1, Yamaha 4K AV Amp, Rotel RX-970B + 4x Kef Coda IIIs :D
Power Supply Corsair HX1500i Modular PSU
Mouse Logitech G502 Lightspeed (previously G600 MMO)
Keyboard Logitech G910 Orion Spectrum (previously G19)
VR HMD Quest 3 + Pro controllers
Software Windows 11 x64 Enterprise (legal!)
Benchmark Scores https://www.3dmark.com/spy/18709841 https://valid.x86.fr/s9zmw1 https://valid.x86.fr/t0vrwy
Not another one.. Oh dear.. As many have said, just start an RMA, give them screenshots plus links to the actual GPU specs used and a link to a real 1050 Ti can help them if they aren't very tech savvy.. It's most definitely fake and if you paid that much you've been screwed over.. You may well get your money back and get to keep the card to play around with, set fire to, put in the oven, the freezer, use as a spare etc.. Whenever i spot a fake on eBay i always report it without fail! So many of them...
Regeneration
NGOHQ.COM
3,103 (0.45/day)
You can have a REAL GTX 1050 or MONEY BACK if you listen to the advice people here given you. Amazon will even pay for the shipping back.
This seller, BuyVPC, has 96 percent positive feedback. So maybe, this was a one time error.
Contact Amazon, tell them you received counterfeit item, link them to this thread, ask a replacement OR refund.
70 (0.04/day)
Good point actually, but if he can manage to get his money back, order a real one and keep the card...well he can destroy or keep the damn thing to make sure it isn't re-sold! Shame it would be hard to re-flash so it shows as what it is..
99 (0.06/day)
for one the everytime i go to the link its like the person selling it changes plus its been 5 months sense orderd in december 3 IT WAS A CHIRSTMAS GIFT
yeah i kinda figured that out like a week or 2 ago BUT MSI MAKES IT TO COMPLACATED TO SEND THEM A EMAIL AND NVIDIA IS LIKE YAY YOU NEED THE COMPANY THAT MADE THE CARD FOR THAT LIKE MSI AND EVAGA WE'RE JUST NOT HELPFULL AT ALL! at most i will probbally try to flash the bios then wait till chirstmas and get anorther gpu amd or a real 1050 ti SOLD BY AMAZON
